I successfully created a package for Adobe CS6 using AAMEE 3.1 on Mac OS X 10.7.5, however the package will not install silently. Adobe Extension Manager opens at the end of an install. I tried skipping the 6.0.4 update to Extension Manager, leaving it at 6.0.0.412. That fixed a bunch of errors that were appearing in Extension Manager, but I can't figure out how to stop it from launching altogether. It still opens to a EULA that needs to be accepted and then displays an error that says "The extension 'Adobe Flash Professional Toolkit for CreateJS' does not contain a valid signature. The extension will not be installed." I found this KB article with an update to Toolkit for CreateJS that is supposed to address the issue, however I can't figure out how to include it in a package created with AAMEE.
http://helpx.adobe.com/flash/kb/error-installing-toolkit-createjs-11.html
Thanks!
-- Jorge
A new update to fix this problem has been posted on http://www.adobe.com/support/flash/downloads.html. You need to download this update and add it manually when creating a package using AAMEE. There is a "Add manually" button on updates screen of AAMEE. You that to add this update manually and create a package. please follow this forum post - http://forums.adobe.com/message/4790883#4790883. It has more details regarding this.
Saransh katariya | Adobe Systems | skatariy@adobe.com
Hello Saransh,
That fixed it. The only problem was that manually adding the update did not give me any kind of feedback that it worked. I had to finish building the package and then install it to know if it worked.
Thank you!
-- Jorge
Adobe come on. Manually seriously. Sort it out please to download and install it in AAMEE.
