6 Replies Latest reply on May 25, 2013 3:47 PM by aghanchi
    Coldfusion 10 Scheduled Tasks Not Working
    parkercep022
      I'm trying to schedule a task that will run every Sunday. I have tried several options and I continue to get the following message...
      • An error occured scheduling the task.
        Advance Scheduling support is not available in this edition of ColdFusion server.
      My version is the following..
      Server Product ColdFusion
      Version ColdFusion 10,283111
      Edition Standard
      Operating System Windows Server 2008 R2
      OS Version 6.1
      Update Level /C:/ColdFusion10/cfusion/lib/updates/hf1000-3332326.jar
      Adobe Driver Version 4.1 (Build 0001)
      I've updated with the Mandatory update and still have this issue.
      Is there a work around or when should this be resolved?
        • 1. Re: Coldfusion 10 Scheduled Tasks Not Working
          Sharma Nimit Adobe Employee
          Hi Parkercep022,
          It seems to me that ColdFusion 10 Update 2 has not been applied properly because applying this update, your Update Level: /C:/ColdFusion10/cfusion/lib/updates/chf10000002.jar
          Can you please check if you have chf10000002.jar file listed under "CF Server Java Class Path"?
          Thanks & Regards,
          Nimit
          • 2. Re: Coldfusion 10 Scheduled Tasks Not Working
            parkercep022 Level 1
            I do not. Where do I get this update ?
            • 3. Re: Coldfusion 10 Scheduled Tasks Not Working
              Is there any update notification on the top right corner of your CF admin page?
              If not, then please check if you have hotfix_002.jar file or hf-10-00002 folder inside "[Install Dir]\ColdFusion10\cfusion\hf-updates\" folder.
              If you have hotfix_002.jar then execute it using "java -jar hotfix_002.jar" command. But make sure on 64-bit computer, use 32-bit JRE for 32-bit ColdFusion and 64-bit JRE for 64-bit ColdFusion.
              Regards,
              Nimit
              • 4. Re: Coldfusion 10 Scheduled Tasks Not Working
                It is not listed and I don't have either of those files.
                • 5. Re: Coldfusion 10 Scheduled Tasks Not Working
                  This fixed the issue... -Dhttp.proxyHost=wwwgate0.mot.com -Dhttp.proxyPort=1080  please note where to put the information.
                  # VM configuration
                  # Where to find JVM, if {java.home}/jre exists then that JVM is used
                  # if not then it must be the path to the JRE itself
                  java.home=C:\\ColdFusion10\\jre
                  application.home=C:\\ColdFusion10\\cfusion
                  # If no java.home is specified a VM is located by looking in these places in this
                  # order:
                  #  1) ../runtime/jre
                  #  2) registry (windows only)
                  #  3) JAVA_HOME env var plus jre (ie $JAVA_HOME/jre)
                  #  4) java.exe in path
                  # Arguments to VM
                  java.args=-server -Xms256m -Xmx512m -XX:MaxPermSize=192m -XX:+UseParallelGC -Xbatch -Dcoldfusion.home={application.home} -
                  Djava.awt.headless=true -Dcoldfusion.rootDir={application.home} -Djava.security.policy=
                  {application.home}/lib/coldfusion.policy -Djava.security.auth.policy={application.home}/lib/neo_jaas.policy  -
                  Dcoldfusion.classPath={application.home}/lib/updates,{application.home}/lib,{application.h ome}/lib/axis2,
                  {application.home}/gateway/lib/,{application.home}/wwwroot/WEB-INF/cfform/jars,{applicatio n.home}/wwwroot/WEB-
                  INF/flex/jars,{application.home}/lib/oosdk/lib,{application.home}/lib/oosdk/classes -Dcoldfusion.libPath=
                  {application.home}/lib -Dorg.apache.coyote.USE_CUSTOM_STATUS_MSG_IN_HEADER=true -Dcoldfusion.jsafe.defaultalgo=FIPS186Random
                  # Comma separated list of shared library path
                  java.library.path={application.home}/lib,{application.home}/jintegra/bin,{application.home }/jintegra/bin/international,
                  {application.home}/lib/oosdk/classes/win
                  java.class.path={application.home}/lib/oosdk/lib,{application.home}/lib/oosdk/classes
                  • 6. Re: Coldfusion 10 Scheduled Tasks Not Working
                    aghanchi Level 1
                    Hi parkercep022.
                    Can you please elaborate on this solution. We are having the similar issue since we upgraded to  CF10. We are on update 9 on CF10 server, but this problem still persists. Is this some kind of cnfiguration file that you modified?
                    I'll appreciate your help.
                    Thanks.
                    Aamir.
