0 Replies Latest reply on Nov 1, 2012 9:01 AM by kt03
    kt03 Level 1
      I download this code as the example from one of the website and play around to make sure it works before i can apply to my real project but i got error of " Error while calling cfc:Searvice flashRemotingResponder not found".  I am not sure but i do have flashRemotingResponder.cfc from the same root..  My guess could be the connection string but don't really understand it.  Can anyone can help me with this?
      <cfsavecontent variable="getData">
          //create connection
          var connection:mx.remoting.Connection = mx.remoting.NetServices.createGatewayConnection("http://#cgi.HTTP_HOST#/flashservices/gateway/");
          //declare service
          var myService:mx.remoting.NetServiceProxy;
          var responseHandler = {};
          //put the controls in scope to avoid calling _root
          var categories = categories;
          var folder_home = folder_home;
          responseHandler.onResult = function( results: Object ):Void {
              //when results are back, populate the cftree
              categories.dataProvider = results;
          responseHandler.onStatus  = function( stat: Object ):Void {
              //if there is any error, show an alert
              alert("Error while calling cfc:" + stat.description);
          //get service
          myService = connection.getService("flashRemotingResponder", responseHandler );
          //make call
          //change icons
          categories.setStyle("disclosureOpenIcon", arrowDown.icon);
          categories.setStyle("disclosureClosedIcon", arrow.icon);
      <cfform name="myform" height="250" width="300" format="Flash" skin="haloSilver" timeout="300" >
          <cftree name="categories"><!--- an empty tree --->
          <cfinput type="text" label="Selected Item:" name="display" bind="{categories.selectedNode.getProperty('id')} = {categories.selectedNode.getProperty('label')} " disabled="true" style="borderStyle:none;disabledColor:##000000">
          <cfinput type="button" name="getValues" value="Populate tree" style="borderThickness:0;corner-radius: 0;fill-colors: ##0066ff, ##00ccff;  theme-color: ##0099ff; color: ##ffffff;" onClick="#getData#">
              <cfinput type="Image" name="folder" src="images/folder.png" visible="false" height="0" width="0">
          <cfinput type="Image" name="folder_open" src="images/folder_open.png" visible="false" height="0" width="0">
          <cfinput type="Image" name="folder_home" src="images/folder_home.png" visible="false" height="0" width="0">
          <cfinput type="Image" name="doc" src="images/font_type1.png" visible="false" height="0" width="0">
          <cfinput type="Image" name="arrow" src="images/forward.png" visible="false" height="0" width="0">
          <cfinput type="Image" name="arrowDown" src="images/arrowDown.png" visible="false" height="0" width="0">
