3 Replies Latest reply on Nov 1, 2012 12:33 PM by try67
    javascript custom dialog with checkbox
    nahni00
      i want to create a dialog with an input-field and a checkbox, but I can't get the value of the checkbox.
      Here is my code:
      var oDlg = {
              strName: "test",
              cB: "",
          initialize: function(dialog) {
              dialog.load({"usnm":this.strName,});
          commit: function(dialog) {
              var data = dialog.store();
                      this.strName = data[ "usnm"];
              checkB: function (dialog){
                  this.cB = "CB pressed";
                  console.println("CB fct " + this.cB);
          description: {
              elements: [ {
                  type: "view",
                  elements: [
                      type: "static_text"
                      item_id: "usnm",
                      type: "edit_text",
                      char_width: 30
                                      item_id: "checkB",
                                     type: "check_box",
                                      name: "   CB Title"
                      type: "ok_cancel",
      if( "ok" == app.execDialog(oDlg)) {
              console.println("Name " + oDlg.strName);
             console.println("Name " + oDlg.cB);
      The part with the checkB: function have I found in the javascript API. I thougth this function will be called if the user cklicked the checkbox
      but no output in the console is displayed.
      Can anyone help me?
        • 1. Re: javascript custom dialog with checkbox
          - You're not committing the value of the check-box.
          - A field id must be 4 characters long.
          - The method associated with the check-box is not necessary.
          • 2. Re: javascript custom dialog with checkbox
            nahni00 Level 1
            ah ok, exactly 4 characters. thanks, that was the problem. First I tried to get the value similar to the inputfield like:
                    strName: "test",
                    cBFlag: "",
                            this.cBFlag = data[ "checkB"];
                                            item_id: "checkB",
                                           type: "check_box",
                                            name: "   CB Title"
            but then I get "undefined" so I thought perhaps you can't access the value of the checkbox and tried it similar to an example in the api with the   checkB: function.
            The failure was the id. Thank you very much.
            so the code works:
                    strName: "test",
                    cBFlag: "",
                            this.cBFlag = data[ "chec"];
                                            item_id: "chec",
                                           type: "check_box",
                                            name: "   CB Title"
            • 3. Re: javascript custom dialog with checkbox
              I mean the item_id property of the of the check-box. Change it to "chk1",
              for example.
              And then add this code to your commit function:
              this.cB = data["chk1"];
              And remove the "checkB" function.
              If you do that, it should work fine...
