1 Reply Latest reply on Mar 5, 2008 5:19 AM by bitwize3
    transparent window, Flash in html is invisble
    baseky
      If transparency set to false then flash shows up correctly. However, if transparency is set to true with same settings then the flash display disappears (isn't visible any more but the space that it should use is used, but nothing is showning up).
      Has someone else this problem? Or is it a bug air?
