3 Replies Latest reply on Mar 5, 2008 12:11 PM by Keith Dodd
    Beta 3 to Final Version: Flash
    Keith Dodd
      I have a couple of AIR apps in beta 3, created in Flash CS3Pro.
      I assume that I should recompile them in the new Version 1?
      I downloaded/installed the latest FlashPro Air stuff and the latest AIR.
      Do I just simply now recompile and replace earlier items with new? I have no other changes to make in the apps.
      Keith
        • 1. Re: Beta 3 to Final Version: Flash
          san_flash Level 2
          Hi Keith,
          The namespace is changed from 1.0.M6 to 1.0. Open your application descriptor file (.xml) and change 1.0.M6 to 1.0. Save a copy of that just in case the descriptor file is overwritten and you still have a copy of your AIR app settings. Just recompile or republish AIR and you're all set.
          San
          • 2. Re: Beta 3 to Final Version: Flash
            rotoole Level 1
            Thanks san,
            i knew it was something in the .xml since thats what it was from beta2 to beta3.
            figuring out which tag to change was what brought me here.
            i just tested and it compiled great. luckily its only this small fix.
            • 3. Re: Beta 3 to Final Version: Flash
              Keith Dodd Level 1
              Thanks, San!
              All went fine. Just opening the fla automatically changed the xml sheet to the right version. I think it may have also changed my "browser can open" to false. ( I *think* I had it true). So changed that back. Someone may want to confirm whether it changes some other nodes or not.
              Thanks for quick help!
              Keith
