2 Replies Latest reply on Mar 7, 2008 7:58 AM by Solerous
    sending java objects to create a flex chart
    Solerous
      Does anyone know the best practice for transferring data from a database to generate a flex chart?
      I have a Java class Axis with these variables:
      String ID;
      Date start;
      Date end;
      int min;
      int max;
      int incr;
      String title;
      String signal;
      String type;
      List data;
      And the List is an array of points defined in a class called DataPoint:
      public Date point1;
      public long point2;
      I pass an array of Axis objects to the Flex app and try to convert it to an actionscript object:
      package factory.data {
      [Bindable]
      [RemoteClass(alias="factory.data.Axis")]
      public class AxisObject {
      public var ID:String;
      public var start:Date;
      public var end:Date;
      public var min:int;
      public var max:int;
      public var incr:int;
      public var title:String;
      public var signal:String;
      public var type:String;
      public var data:Array;
      and I can access the title for example, but cannot get the DataPoint array into the chart. Furthermore, when I debug it gives me the following errors:
      ReferenceError: Error #1056: Cannot create property endDate on factory.data.AxisObject.
      ReferenceError: Error #1056: Cannot create property dataList on factory.data.AxisObject.
      Thanks for any help you can offer.
