8 Replies Latest reply on Nov 13, 2012 3:46 AM by davidl11
    Extensions Aren't Installed in PS CS6
    davidl11 Level 1
      I have Photoshop CS6 (13.0.1), 64 bit.  As part of one e-book and one printed book I have received 3 .zxp extensions (panels?) to install.  I have Adobe Extension Manager installed (6.0.4.8) and have used it to install all 3 extensions.  It appears that all 3 were installed:
      However, in PS when I go to Window > Extensions, none of the extensions appear.  If I look in the C:\Program Files\Adobe\Adobe Photoshop CS6 (64 bit)\Plug-Ins\Panels folder, not surprisingly these extensions are not there.
      Am I doing something wrong, or is the problem with either my installation of PS or Extension Manager?
      Thanks and best regards,
      David
      P.S., I don't know if it is related, but I have also been unsuccessful in installing .jsx programs that I have purchased.
        • 1. Re: Extensions Aren't Installed in PS CS6
          Xiaoyi Tong Adobe Employee
          Hi davidl11,
          You can try to launch Extension Manager as administrator and install your extensions again, and you can send us the MXI files or ZXP files of these extensions( xtong@adobe.com ). You can also generate Extension Manager log file and post the content here( Please refer to http://forums.adobe.com/message/4275082#4275082 ). Thanks.
          Xiaoyi
          • 2. Re: Extensions Aren't Installed in PS CS6
            Carl Sun Level 4
            Not all extensions will appear in the Window -> Extensions. Generally the extension author will provide some descriptions about where to find the extension (panels, menu items, buttons or something else) in the Photoshop UI, and the description will be displayed in Extension Manager. Please select the extension in the upper right panel of Extension Manager, then read the description in the lower right panel. You should find the description.
            • 3. Re: Extensions Aren't Installed in PS CS6
              davidl11 Level 1
              I have just emailed the extensions I am trying to install.  Below I am pasting the contents of ExtensionManager.log.  Let me know if this is the correct log file, as there are two others in the directory:  log1.log and log0.log.
              Thanks for your help.
              Regards,
              David
              [DEBUG] Fri Nov 02 11:46:18 2012 [.443] (OWLMain.cpp,899) -APE environment initializd OK
              [DEBUG] Fri Nov 02 11:46:18 2012 [.444] (OWLMain.cpp,902) -C:\Program Files (x86)\Adobe\Adobe Extension Manager CS6
              [DEBUG] Fri Nov 02 11:46:18 2012 [.512] (OWLMain.cpp,937) -Create APE stage window OK
              [INFO] Fri Nov 02 11:46:18 2012 [.607] (OWLMain.cpp,969) -Load swf file succeed.
              [DEBUG] Fri Nov 02 11:46:19 2012 [.328] (OWLMain.cpp,143) -AIR is ready for the invocation from C++ side
              [TRACE] Fri Nov 02 11:46:19 2012 [.328] (CommandExecutorMfc.cpp,35) -MESSAGE
              [DEBUG] Fri Nov 02 11:46:19 2012 [.329] (..\Control\GetSupportedLocalList.cpp,56) -Sending Get Locale list request to AIR
              [DEBUG] Fri Nov 02 11:46:19 2012 [.329] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.329] (..\Control\OWLFrontController.cpp,407) -Method Name: airGetLocaleList
              [DEBUG] Fri Nov 02 11:46:19 2012 [.329] (..\Control\OWLFrontController.cpp,424) --1
              [DEBUG] Fri Nov 02 11:46:19 2012 [.329] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.384] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.384] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalCallBack
              [DEBUG] Fri Nov 02 11:46:19 2012 [.384] (..\Control\OWLFrontController.cpp,118) --1
              [DEBUG] Fri Nov 02 11:46:19 2012 [.384] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:19 2012 [.384] (..\Control\OWLFrontController.cpp,118) -en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,nb_NO,nl_NL,pl_PL,pt_B R,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
              [DEBUG] Fri Nov 02 11:46:19 2012 [.384] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.385] (..\Control\PumpBridgeTalkMessageCommand.cpp,67) -PumpBridgeTalkMessageCommand::execute(), register bridge talk message handler.
              [DEBUG] Fri Nov 02 11:46:19 2012 [.385] (..\Control\OWLFrontController.cpp,165) -RequestId is-1. It is a request used to unlock OK/Cancel
              [DEBUG] Fri Nov 02 11:46:19 2012 [.385] (..\Control\GetSupportedLocalList.cpp,81) -Get Locale list completed
              [DEBUG] Fri Nov 02 11:46:19 2012 [.403] (..\MMFC\Source\MacrOS.cpp,1726) -=====Supported locales list items:=====
              [DEBUG] Fri Nov 02 11:46:19 2012 [.403] (..\MMFC\Source\MacrOS.cpp,1730) -en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.403] (..\MMFC\Source\MacrOS.cpp,1730) -da_DK
              [DEBUG] Fri Nov 02 11:46:19 2012 [.403] (..\MMFC\Source\MacrOS.cpp,1730) -de_DE
              [DEBUG] Fri Nov 02 11:46:19 2012 [.403] (..\MMFC\Source\MacrOS.cpp,1730) -es_ES
              [DEBUG] Fri Nov 02 11:46:19 2012 [.403] (..\MMFC\Source\MacrOS.cpp,1730) -fi_FI
              [DEBUG] Fri Nov 02 11:46:19 2012 [.403] (..\MMFC\Source\MacrOS.cpp,1730) -fr_FR
              [DEBUG] Fri Nov 02 11:46:19 2012 [.403] (..\MMFC\Source\MacrOS.cpp,1730) -it_IT
              [DEBUG] Fri Nov 02 11:46:19 2012 [.403] (..\MMFC\Source\MacrOS.cpp,1730) -nb_NO
              [DEBUG] Fri Nov 02 11:46:19 2012 [.403] (..\MMFC\Source\MacrOS.cpp,1730) -nl_NL
              [DEBUG] Fri Nov 02 11:46:19 2012 [.403] (..\MMFC\Source\MacrOS.cpp,1730) -pt_BR
              [DEBUG] Fri Nov 02 11:46:19 2012 [.403] (..\MMFC\Source\MacrOS.cpp,1730) -sv_SE
              [DEBUG] Fri Nov 02 11:46:19 2012 [.404] (..\MMFC\Source\MacrOS.cpp,1750) -The User preferred language code is en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.404] (..\MMFC\Source\MacrOS.cpp,1753) -en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.404] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.404] (..\Control\OWLFrontController.cpp,407) -Method Name: airSetLocale
              [DEBUG] Fri Nov 02 11:46:19 2012 [.404] (..\Control\OWLFrontController.cpp,424) --2
              [DEBUG] Fri Nov 02 11:46:19 2012 [.404] (..\Control\OWLFrontController.cpp,424) -en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.404] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.405] (..\MacrExtensionManager.cpp,1280) -Extension Mnaager starts initializing
              [DEBUG] Fri Nov 02 11:46:19 2012 [.407] (..\MMFC\Source\MacrOS.cpp,4262) -Bare version is
              [DEBUG] Fri Nov 02 11:46:19 2012 [.407] (..\MMFC\Source\MacrOS.cpp,4263) -6.0.4.8
              [DEBUG] Fri Nov 02 11:46:19 2012 [.407] (..\MMFC\Source\MacrOS.cpp,4268) -Formal version is
              [DEBUG] Fri Nov 02 11:46:19 2012 [.407] (..\MMFC\Source\MacrOS.cpp,4269) -6.0.4.8
              [DEBUG] Fri Nov 02 11:46:19 2012 [.407] (..\Products\MacrExtensionManagerProduct.cpp,193) -Application name is Adobe Extension Manager CS6.exe
              [DEBUG] Fri Nov 02 11:46:19 2012 [.408] (..\Products\MacrCommonProduct.cpp,90) -Application path is C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)
              [INFO] Fri Nov 02 11:46:19 2012 [.414] (..\MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (C:\Program Files\Adobe\Adobe Bridge CS6 (64 Bit)), with value (en_US).
              [INFO] Fri Nov 02 11:46:19 2012 [.415] (..\MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (C:\Program Files (x86)\Common Files\Adobe\XMP\Custom File Info Panels\4.0), with value (en_US).
              [INFO] Fri Nov 02 11:46:19 2012 [.417] (..\MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)), with value (en_US).
              [INFO] Fri Nov 02 11:46:19 2012 [.421] (..\MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (C:\Program Files (x86)\Adobe\Adobe Extension Manager CS6), with value (en_US).
              [INFO] Fri Nov 02 11:46:19 2012 [.426] (..\MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (C:\Program Files (x86)\Common Files\Adobe\SwitchBoard), with value (en_US).
              [INFO] Fri Nov 02 11:46:19 2012 [.428] (..\MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (C:\Program Files (x86)\Adobe\Adobe Utilities - CS6\ExtendScript Toolkit CS6), with value (en_US).
              [DEBUG] Fri Nov 02 11:46:19 2012 [.433] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.434] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:19 2012 [.434] (..\Control\OWLFrontController.cpp,424) -0
              [DEBUG] Fri Nov 02 11:46:19 2012 [.434] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [INFO] Fri Nov 02 11:46:19 2012 [.434] (..\MacrProductInfoFromCapsLib.cpp,360) -For product (C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)), the installed languages are (en_US)
              [DEBUG] Fri Nov 02 11:46:19 2012 [.435] (..\MactProductInfoFromBridge.cpp,75) ----Begin to read xman configuration data file---
              [DEBUG] Fri Nov 02 11:46:19 2012 [.435] (..\MactProductInfoFromBridge.cpp,76) -The present xman data file is:
              [DEBUG] Fri Nov 02 11:46:19 2012 [.435] (..\MactProductInfoFromBridge.cpp,77) -C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Configuration\XManConfig.xml
              [DEBUG] Fri Nov 02 11:46:19 2012 [.435] (..\MactProductInfoFromBridge.cpp,86) ----End to read  xman configuration data file---
              [DEBUG] Fri Nov 02 11:46:19 2012 [.435] (..\Control\macrgetXml_impl.cpp,68) -Sending XML contents to AIR
              [DEBUG] Fri Nov 02 11:46:19 2012 [.435] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.435] (..\Control\OWLFrontController.cpp,407) -Method Name: airParseXML
              [DEBUG] Fri Nov 02 11:46:19 2012 [.435] (..\Control\OWLFrontController.cpp,424) --3
              [DEBUG] Fri Nov 02 11:46:19 2012 [.435] (..\Control\OWLFrontController.cpp,424) -C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Configuration\XManConfig.xml
              [DEBUG] Fri Nov 02 11:46:19 2012 [.435] (..\Control\OWLFrontController.cpp,424) -Configuration.VariableForExMan.Data
              [DEBUG] Fri Nov 02 11:46:19 2012 [.435] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalCallBack
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) --3
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -EmStorePath
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -$SharedRibsDataFolder/Adobe/Extension Manager
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -$photoshopappfolder
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -$installfolder
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -$photoshopappfolder/Plug-Ins
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -$presetsfolder
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -$photoshopappfolder/Presets
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -$platform
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -Win
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -$actions
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Actions
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -$blackandwhite
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Black and White
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -$brushes
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Brushes
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -$channelmixer
              [DEBUG] Fri Nov 02 11:46:19 2012 [.464] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Channel Mixer
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$colorbooks
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Color Books
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$colorrange
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Color Range
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$colorswatches
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Color Swatches
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$contours
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Contours
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$curves
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Curves
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$customshapes
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Custom Shapes
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$duotones
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Duotones
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$exposure
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Exposure
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$gradients
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Gradients
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$huesat
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Hue Sat
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$imagestatistics
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Image Statistics
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$keyboardshortcuts
              [DEBUG] Fri Nov 02 11:46:19 2012 [.465] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Keyboard Shortcuts
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$layouts
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Layouts
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$lenscorrection
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Lens Correction
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$levels
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Levels
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$liquifymeshes
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Liquify Meshes
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$menucustomization
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Menu Customization
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$optimizedcolors
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Optimized Colors
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$optimizedoutputSettings
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Optimized Output Settings
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$optimizedsettings
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Optimized Settings
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$patterns
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Patterns
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$reducenoise
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Reduce Noise
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$replacecolor
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Replace Color
              [DEBUG] Fri Nov 02 11:46:19 2012 [.466] (..\Control\OWLFrontController.cpp,118) -$scripts
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Scripts
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$selectivecolor
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Selective Color
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$shadowhighlight
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Shadow Highlight
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$smartsharpen
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Smart Sharpen
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$styles
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Styles
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$textures
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Textures
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$tools
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Tools
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$variations
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Variations
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$webphotogallery
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Web Photo Gallery
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$workspaces
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Workspaces
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$zoomify
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Zoomify
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$hueandsaturation
              [DEBUG] Fri Nov 02 11:46:19 2012 [.467] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Hue and Saturation
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$lights
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Lights
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$materials
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Materials
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$meshes
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Meshes
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$rendersettings
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Render Settings
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$volumes
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Volumes
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$widgets
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$presetsfolder/Widgets
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$localesfolder
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$photoshopappfolder/Locales
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$additionalplugins
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$localesfolder/$LOCALE/Additional Plug-ins
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$additionalpresets
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$localesfolder/$LOCALE/Additional Presets
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$localeskeyboardshortcuts
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$localesfolder/$LOCALE/Additional Presets/$platform/Keyboard Shortcuts
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$localesmenucustomization
              [DEBUG] Fri Nov 02 11:46:19 2012 [.468] (..\Control\OWLFrontController.cpp,118) -$localesfolder/$LOCALE/Additional Presets/$platform/Menu Customization
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$localesworkspaces
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$localesfolder/$LOCALE/Additional Presets/$platform/Workspaces
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$automate
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Automate
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$digimarc
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Digimarc
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$displacementmaps
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Displacement Maps
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$effects
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Effects
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$extensions
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Extensions
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$fileformats
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/File Formats
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$filters
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Filters
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$imagestacks
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Image Stacks
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$importexport
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Import-Export
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$measurements
              [DEBUG] Fri Nov 02 11:46:19 2012 [.469] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Measurements
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -$panels
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Panels
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -$parser
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Parser
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -$3dengines
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/3D Engines
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -$lightingstyles
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -$pluginsfolder/Filters/Lighting Styles
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -$matlab
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -$photoshopappfolder/MATLAB
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -UserExtensionFolder
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -$UserDataFolder/Adobe/Adobe Photoshop CS6/Configuration
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -DisplayName
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -Photoshop CS6 64
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -ProductName
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -Photoshop64
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -FamilyName
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -ProductVersion
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -13.0
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -IconPath
              [DEBUG] Fri Nov 02 11:46:19 2012 [.470] (..\Control\OWLFrontController.cpp,118) -Configuration/PS_exman_24px.png
              [DEBUG] Fri Nov 02 11:46:19 2012 [.471] (..\Control\OWLFrontController.cpp,118) -SupportedInSuite
              [DEBUG] Fri Nov 02 11:46:19 2012 [.471] (..\Control\OWLFrontController.cpp,118) -CS6
              [DEBUG] Fri Nov 02 11:46:19 2012 [.471] (..\Control\OWLFrontController.cpp,118) -HostNameForCSXS
              [DEBUG] Fri Nov 02 11:46:19 2012 [.471] (..\Control\OWLFrontController.cpp,118) -PHSP
              [DEBUG] Fri Nov 02 11:46:19 2012 [.471] (..\Control\OWLFrontController.cpp,118) -Bit
              [DEBUG] Fri Nov 02 11:46:19 2012 [.471] (..\Control\OWLFrontController.cpp,118) -64
              [DEBUG] Fri Nov 02 11:46:19 2012 [.471] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.471] (..\Control\OWLFrontController.cpp,165) -RequestId is-3. It is a request used to unlock OK/Cancel
              [DEBUG] Fri Nov 02 11:46:19 2012 [.472] (..\Control\macrgetXml_impl.cpp,111) -XML contents parse completed
              [DEBUG] Fri Nov 02 11:46:19 2012 [.473] (..\Products\MacrCommonProduct.cpp,401) -Product Name for photoshop-60.064 is Photoshop64
              [DEBUG] Fri Nov 02 11:46:19 2012 [.473] (..\MacrProduct.cpp,1317) -Display Name for photoshop-60.064 is Photoshop CS6 64
              [DEBUG] Fri Nov 02 11:46:19 2012 [.473] (..\Products\MacrCommonProduct.cpp,444) -Product version forPhotoshop CS6 64 is 13.0
              [DEBUG] Fri Nov 02 11:46:19 2012 [.473] (..\Products\MacrCommonProduct.cpp,463) -Language code for Photoshop CS6 64 is en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.473] (..\Products\MacrCommonProduct.cpp,191) -Icon Path for Photoshop CS6 64 is C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Configuration\PS_exman_24px.png
              [DEBUG] Fri Nov 02 11:46:19 2012 [.473] (..\Products\MacrCommonProduct.cpp,382) -Product Family Name for photoshop-60.064 is Photoshop
              [DEBUG] Fri Nov 02 11:46:19 2012 [.473] (..\MacrProduct.cpp,203) -The product photoshop-60.064 is supported by CS6
              [DEBUG] Fri Nov 02 11:46:19 2012 [.474] (..\MacrProduct.cpp,1459) -EMStore path per-machine for photoshop-60.064 is C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Photoshop CS6 64\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.474] (..\MacrProduct.cpp,203) -The product photoshop-60.064 is supported by CS6
              [DEBUG] Fri Nov 02 11:46:19 2012 [.474] (..\MacrProduct.cpp,1528) -MxiFlag path per-machine for photoshop-60.064 is C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 64\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.475] (..\MacrProduct.cpp,203) -The product photoshop-60.064 is supported by CS6
              [DEBUG] Fri Nov 02 11:46:19 2012 [.475] (..\MacrProduct.cpp,1283) -Preferred folder for Photoshop CS6 64 is
              [DEBUG] Fri Nov 02 11:46:19 2012 [.476] (..\Products\MacrDreamweaver11_5.cpp,93) -Application path is
              [DEBUG] Fri Nov 02 11:46:19 2012 [.476] (..\MMFC\Source\MacrOS.cpp,1726) -=====Supported locales list items:=====
              [DEBUG] Fri Nov 02 11:46:19 2012 [.476] (..\MMFC\Source\MacrOS.cpp,1730) -en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.476] (..\MMFC\Source\MacrOS.cpp,1730) -da_DK
              [DEBUG] Fri Nov 02 11:46:19 2012 [.476] (..\MMFC\Source\MacrOS.cpp,1730) -de_DE
              [DEBUG] Fri Nov 02 11:46:19 2012 [.476] (..\MMFC\Source\MacrOS.cpp,1730) -es_ES
              [DEBUG] Fri Nov 02 11:46:19 2012 [.476] (..\MMFC\Source\MacrOS.cpp,1730) -fi_FI
              [DEBUG] Fri Nov 02 11:46:19 2012 [.476] (..\MMFC\Source\MacrOS.cpp,1730) -fr_FR
              [DEBUG] Fri Nov 02 11:46:19 2012 [.476] (..\MMFC\Source\MacrOS.cpp,1730) -it_IT
              [DEBUG] Fri Nov 02 11:46:19 2012 [.476] (..\MMFC\Source\MacrOS.cpp,1730) -nb_NO
              [DEBUG] Fri Nov 02 11:46:19 2012 [.476] (..\MMFC\Source\MacrOS.cpp,1730) -nl_NL
              [DEBUG] Fri Nov 02 11:46:19 2012 [.476] (..\MMFC\Source\MacrOS.cpp,1730) -pt_BR
              [DEBUG] Fri Nov 02 11:46:19 2012 [.476] (..\MMFC\Source\MacrOS.cpp,1730) -sv_SE
              [DEBUG] Fri Nov 02 11:46:19 2012 [.477] (..\MMFC\Source\MacrOS.cpp,1750) -The User preferred language code is en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.477] (..\MMFC\Source\MacrOS.cpp,1753) -en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.477] (..\Products\MacrDreamweaver9.cpp,237) -Language code for Dreamweaver is en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.477] (..\MacrProduct.cpp,211) -The product dreamweaver-11.5 is not supported by CS6
              [DEBUG] Fri Nov 02 11:46:19 2012 [.477] (..\MacrProduct.cpp,182) -The product dreamweaver-11.5 is not supported by CS5.5
              [DEBUG] Fri Nov 02 11:46:19 2012 [.477] (..\MacrProduct.cpp,1283) -Preferred folder for Dreamweaver CS5.5 is
              [DEBUG] Fri Nov 02 11:46:19 2012 [.477] (..\Products\MacrDreamweaver12.cpp,95) -Application path is
              [DEBUG] Fri Nov 02 11:46:19 2012 [.478] (..\MMFC\Source\MacrOS.cpp,1726) -=====Supported locales list items:=====
              [DEBUG] Fri Nov 02 11:46:19 2012 [.478] (..\MMFC\Source\MacrOS.cpp,1730) -en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.478] (..\MMFC\Source\MacrOS.cpp,1730) -da_DK
              [DEBUG] Fri Nov 02 11:46:19 2012 [.478] (..\MMFC\Source\MacrOS.cpp,1730) -de_DE
              [DEBUG] Fri Nov 02 11:46:19 2012 [.478] (..\MMFC\Source\MacrOS.cpp,1730) -es_ES
              [DEBUG] Fri Nov 02 11:46:19 2012 [.478] (..\MMFC\Source\MacrOS.cpp,1730) -fi_FI
              [DEBUG] Fri Nov 02 11:46:19 2012 [.478] (..\MMFC\Source\MacrOS.cpp,1730) -fr_FR
              [DEBUG] Fri Nov 02 11:46:19 2012 [.478] (..\MMFC\Source\MacrOS.cpp,1730) -it_IT
              [DEBUG] Fri Nov 02 11:46:19 2012 [.478] (..\MMFC\Source\MacrOS.cpp,1730) -nb_NO
              [DEBUG] Fri Nov 02 11:46:19 2012 [.478] (..\MMFC\Source\MacrOS.cpp,1730) -nl_NL
              [DEBUG] Fri Nov 02 11:46:19 2012 [.478] (..\MMFC\Source\MacrOS.cpp,1730) -pt_BR
              [DEBUG] Fri Nov 02 11:46:19 2012 [.478] (..\MMFC\Source\MacrOS.cpp,1730) -sv_SE
              [DEBUG] Fri Nov 02 11:46:19 2012 [.478] (..\MMFC\Source\MacrOS.cpp,1750) -The User preferred language code is en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.478] (..\MMFC\Source\MacrOS.cpp,1753) -en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.478] (..\Products\MacrDreamweaver9.cpp,237) -Language code for Dreamweaver is en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.478] (..\MacrProduct.cpp,211) -The product dreamweaver-12.0 is not supported by CS6
              [DEBUG] Fri Nov 02 11:46:19 2012 [.478] (..\MacrProduct.cpp,182) -The product dreamweaver-12.0 is not supported by CS5.5
              [DEBUG] Fri Nov 02 11:46:19 2012 [.479] (..\MacrProduct.cpp,211) -The product dreamweaver-12.0 is not supported by CS6
              [DEBUG] Fri Nov 02 11:46:19 2012 [.479] (..\MacrProduct.cpp,1283) -Preferred folder for Dreamweaver CS6 is
              [DEBUG] Fri Nov 02 11:46:19 2012 [.479] (..\Products\MacrFireworks11_5.cpp,100) -Application path is
              [DEBUG] Fri Nov 02 11:46:19 2012 [.479] (..\MMFC\Source\MacrOS.cpp,1726) -=====Supported locales list items:=====
              [DEBUG] Fri Nov 02 11:46:19 2012 [.479] (..\MMFC\Source\MacrOS.cpp,1730) -en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.479] (..\MMFC\Source\MacrOS.cpp,1730) -da_DK
              [DEBUG] Fri Nov 02 11:46:19 2012 [.479] (..\MMFC\Source\MacrOS.cpp,1730) -de_DE
              [DEBUG] Fri Nov 02 11:46:19 2012 [.479] (..\MMFC\Source\MacrOS.cpp,1730) -es_ES
              [DEBUG] Fri Nov 02 11:46:19 2012 [.479] (..\MMFC\Source\MacrOS.cpp,1730) -fi_FI
              [DEBUG] Fri Nov 02 11:46:19 2012 [.479] (..\MMFC\Source\MacrOS.cpp,1730) -fr_FR
              [DEBUG] Fri Nov 02 11:46:19 2012 [.479] (..\MMFC\Source\MacrOS.cpp,1730) -it_IT
              [DEBUG] Fri Nov 02 11:46:19 2012 [.479] (..\MMFC\Source\MacrOS.cpp,1730) -nb_NO
              [DEBUG] Fri Nov 02 11:46:19 2012 [.479] (..\MMFC\Source\MacrOS.cpp,1730) -nl_NL
              [DEBUG] Fri Nov 02 11:46:19 2012 [.479] (..\MMFC\Source\MacrOS.cpp,1730) -pt_BR
              [DEBUG] Fri Nov 02 11:46:19 2012 [.479] (..\MMFC\Source\MacrOS.cpp,1730) -sv_SE
              [DEBUG] Fri Nov 02 11:46:19 2012 [.480] (..\MMFC\Source\MacrOS.cpp,1750) -The User preferred language code is en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.480] (..\MMFC\Source\MacrOS.cpp,1753) -en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.480] (..\Products\MacrFireworks9.cpp,375) -Language code for Fireworks CS4 is en
              [DEBUG] Fri Nov 02 11:46:19 2012 [.480] (..\MacrProduct.cpp,211) -The product fireworks-11.1 is not supported by CS6
              [DEBUG] Fri Nov 02 11:46:19 2012 [.480] (..\MacrProduct.cpp,182) -The product fireworks-11.1 is not supported by CS5.5
              [DEBUG] Fri Nov 02 11:46:19 2012 [.480] (..\MacrProduct.cpp,1283) -Preferred folder for Fireworks CS5.1 is
              [DEBUG] Fri Nov 02 11:46:19 2012 [.480] (..\Products\MacrFireworks12.cpp,100) -Application path is
              [DEBUG] Fri Nov 02 11:46:19 2012 [.481] (..\MMFC\Source\MacrOS.cpp,1726) -=====Supported locales list items:=====
              [DEBUG] Fri Nov 02 11:46:19 2012 [.481] (..\MMFC\Source\MacrOS.cpp,1730) -en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.481] (..\MMFC\Source\MacrOS.cpp,1730) -da_DK
              [DEBUG] Fri Nov 02 11:46:19 2012 [.481] (..\MMFC\Source\MacrOS.cpp,1730) -de_DE
              [DEBUG] Fri Nov 02 11:46:19 2012 [.481] (..\MMFC\Source\MacrOS.cpp,1730) -es_ES
              [DEBUG] Fri Nov 02 11:46:19 2012 [.481] (..\MMFC\Source\MacrOS.cpp,1730) -fi_FI
              [DEBUG] Fri Nov 02 11:46:19 2012 [.481] (..\MMFC\Source\MacrOS.cpp,1730) -fr_FR
              [DEBUG] Fri Nov 02 11:46:19 2012 [.481] (..\MMFC\Source\MacrOS.cpp,1730) -it_IT
              [DEBUG] Fri Nov 02 11:46:19 2012 [.481] (..\MMFC\Source\MacrOS.cpp,1730) -nb_NO
              [DEBUG] Fri Nov 02 11:46:19 2012 [.481] (..\MMFC\Source\MacrOS.cpp,1730) -nl_NL
              [DEBUG] Fri Nov 02 11:46:19 2012 [.481] (..\MMFC\Source\MacrOS.cpp,1730) -pt_BR
              [DEBUG] Fri Nov 02 11:46:19 2012 [.481] (..\MMFC\Source\MacrOS.cpp,1730) -sv_SE
              [DEBUG] Fri Nov 02 11:46:19 2012 [.481] (..\MMFC\Source\MacrOS.cpp,1750) -The User preferred language code is en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.481] (..\MMFC\Source\MacrOS.cpp,1753) -en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.481] (..\Products\MacrFireworks9.cpp,375) -Language code for Fireworks CS4 is en
              [DEBUG] Fri Nov 02 11:46:19 2012 [.481] (..\MacrProduct.cpp,211) -The product fireworks-12.0 is not supported by CS6
              [DEBUG] Fri Nov 02 11:46:19 2012 [.481] (..\MacrProduct.cpp,182) -The product fireworks-12.0 is not supported by CS5.5
              [DEBUG] Fri Nov 02 11:46:19 2012 [.482] (..\MacrProduct.cpp,1283) -Preferred folder for Fireworks CS6 is
              [DEBUG] Fri Nov 02 11:46:19 2012 [.482] (..\MMFC\Source\MacrOS.cpp,4366) -The current operating system is 2,major version is 6,minor version is 1***********
              [DEBUG] Fri Nov 02 11:46:19 2012 [.483] (..\MMFC\Source\MacrOS.cpp,1726) -=====Supported locales list items:=====
              [DEBUG] Fri Nov 02 11:46:19 2012 [.483] (..\MMFC\Source\MacrOS.cpp,1730) -en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.483] (..\MMFC\Source\MacrOS.cpp,1730) -da_DK
              [DEBUG] Fri Nov 02 11:46:19 2012 [.483] (..\MMFC\Source\MacrOS.cpp,1730) -de_DE
              [DEBUG] Fri Nov 02 11:46:19 2012 [.483] (..\MMFC\Source\MacrOS.cpp,1730) -es_ES
              [DEBUG] Fri Nov 02 11:46:19 2012 [.483] (..\MMFC\Source\MacrOS.cpp,1730) -fi_FI
              [DEBUG] Fri Nov 02 11:46:19 2012 [.483] (..\MMFC\Source\MacrOS.cpp,1730) -fr_FR
              [DEBUG] Fri Nov 02 11:46:19 2012 [.483] (..\MMFC\Source\MacrOS.cpp,1730) -it_IT
              [DEBUG] Fri Nov 02 11:46:19 2012 [.483] (..\MMFC\Source\MacrOS.cpp,1730) -nb_NO
              [DEBUG] Fri Nov 02 11:46:19 2012 [.483] (..\MMFC\Source\MacrOS.cpp,1730) -nl_NL
              [DEBUG] Fri Nov 02 11:46:19 2012 [.483] (..\MMFC\Source\MacrOS.cpp,1730) -pt_BR
              [DEBUG] Fri Nov 02 11:46:19 2012 [.484] (..\MMFC\Source\MacrOS.cpp,1730) -sv_SE
              [DEBUG] Fri Nov 02 11:46:19 2012 [.484] (..\MMFC\Source\MacrOS.cpp,1750) -The User preferred language code is en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.484] (..\MMFC\Source\MacrOS.cpp,1753) -en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.484] (..\Products\MacrFlash11_5.cpp,580) -The User perferred language code is en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.484] (..\Products\MacrFlash11_5.cpp,449) -The present language code for Flash CS5 is en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.484] (..\Products\MacrFlash11_5.cpp,472) -Application path is
              [DEBUG] Fri Nov 02 11:46:19 2012 [.484] (..\MMFC\Source\MacrOS.cpp,1726) -=====Supported locales list items:=====
              [DEBUG] Fri Nov 02 11:46:19 2012 [.484] (..\MMFC\Source\MacrOS.cpp,1730) -en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.484] (..\MMFC\Source\MacrOS.cpp,1730) -da_DK
              [DEBUG] Fri Nov 02 11:46:19 2012 [.484] (..\MMFC\Source\MacrOS.cpp,1730) -de_DE
              [DEBUG] Fri Nov 02 11:46:19 2012 [.484] (..\MMFC\Source\MacrOS.cpp,1730) -es_ES
              [DEBUG] Fri Nov 02 11:46:19 2012 [.484] (..\MMFC\Source\MacrOS.cpp,1730) -fi_FI
              [DEBUG] Fri Nov 02 11:46:19 2012 [.484] (..\MMFC\Source\MacrOS.cpp,1730) -fr_FR
              [DEBUG] Fri Nov 02 11:46:19 2012 [.484] (..\MMFC\Source\MacrOS.cpp,1730) -it_IT
              [DEBUG] Fri Nov 02 11:46:19 2012 [.484] (..\MMFC\Source\MacrOS.cpp,1730) -nb_NO
              [DEBUG] Fri Nov 02 11:46:19 2012 [.484] (..\MMFC\Source\MacrOS.cpp,1730) -nl_NL
              [DEBUG] Fri Nov 02 11:46:19 2012 [.484] (..\MMFC\Source\MacrOS.cpp,1730) -pt_BR
              [DEBUG] Fri Nov 02 11:46:19 2012 [.485] (..\MMFC\Source\MacrOS.cpp,1750) -The User preferred language code is en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.485] (..\MMFC\Source\MacrOS.cpp,1753) -en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.485] (..\Products\MacrFlash11_5.cpp,580) -The User perferred language code is en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.485] (..\Products\MacrFlash9.cpp,183) -Language code for Flash is en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.485] (..\MacrProduct.cpp,211) -The product flash-11.5 is not supported by CS6
              [DEBUG] Fri Nov 02 11:46:19 2012 [.485] (..\MacrProduct.cpp,182) -The product flash-11.5 is not supported by CS5.5
              [DEBUG] Fri Nov 02 11:46:19 2012 [.485] (..\MMFC\Source\MacrOS.cpp,4366) -The current operating system is 2,major version is 6,minor version is 1***********
              [DEBUG] Fri Nov 02 11:46:19 2012 [.486] (..\Products\MacrFlash12.cpp,464) -Application path is
              [DEBUG] Fri Nov 02 11:46:19 2012 [.486] (..\MMFC\Source\MacrOS.cpp,1726) -=====Supported locales list items:=====
              [DEBUG] Fri Nov 02 11:46:19 2012 [.486] (..\MMFC\Source\MacrOS.cpp,1730) -en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.486] (..\MMFC\Source\MacrOS.cpp,1730) -da_DK
              [DEBUG] Fri Nov 02 11:46:19 2012 [.486] (..\MMFC\Source\MacrOS.cpp,1730) -de_DE
              [DEBUG] Fri Nov 02 11:46:19 2012 [.486] (..\MMFC\Source\MacrOS.cpp,1730) -es_ES
              [DEBUG] Fri Nov 02 11:46:19 2012 [.486] (..\MMFC\Source\MacrOS.cpp,1730) -fi_FI
              [DEBUG] Fri Nov 02 11:46:19 2012 [.486] (..\MMFC\Source\MacrOS.cpp,1730) -fr_FR
              [DEBUG] Fri Nov 02 11:46:19 2012 [.486] (..\MMFC\Source\MacrOS.cpp,1730) -it_IT
              [DEBUG] Fri Nov 02 11:46:19 2012 [.486] (..\MMFC\Source\MacrOS.cpp,1730) -nb_NO
              [DEBUG] Fri Nov 02 11:46:19 2012 [.486] (..\MMFC\Source\MacrOS.cpp,1730) -nl_NL
              [DEBUG] Fri Nov 02 11:46:19 2012 [.486] (..\MMFC\Source\MacrOS.cpp,1730) -pt_BR
              [DEBUG] Fri Nov 02 11:46:19 2012 [.486] (..\MMFC\Source\MacrOS.cpp,1730) -sv_SE
              [DEBUG] Fri Nov 02 11:46:19 2012 [.486] (..\MMFC\Source\MacrOS.cpp,1750) -The User preferred language code is en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.486] (..\MMFC\Source\MacrOS.cpp,1753) -en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.487] (..\Products\MacrFlash12.cpp,588) -The User perferred language code is en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.487] (..\Products\MacrFlash9.cpp,183) -Language code for Flash is en_US
              [DEBUG] Fri Nov 02 11:46:19 2012 [.487] (..\MacrProduct.cpp,211) -The product flash-12.0 is not supported by CS6
              [DEBUG] Fri Nov 02 11:46:19 2012 [.487] (..\MacrProduct.cpp,182) -The product flash-12.0 is not supported by CS5.5
              [DEBUG] Fri Nov 02 11:46:19 2012 [.488] (..\MMFC\Source\MacrOS.cpp,2356) -Going to change the permission of folder [C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Photoshop CS6 64], with command: [cacls.exe], parameter: ["C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Photoshop CS6 64" /T /E /C /G BUILTIN\Users:F]
              [DEBUG] Fri Nov 02 11:46:19 2012 [.519] (..\MMFC\Source\MacrOS.cpp,2361) -Succeed to make this folder writable for all users.
              [DEBUG] Fri Nov 02 11:46:19 2012 [.519] (..\MMFC\Source\MacrOS.cpp,2356) -Going to change the permission of folder [C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 64], with command: [cacls.exe], parameter: ["C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 64" /T /E /C /G BUILTIN\Users:F]
              [DEBUG] Fri Nov 02 11:46:19 2012 [.531] (..\MMFC\Source\MacrOS.cpp,2361) -Succeed to make this folder writable for all users.
              [DEBUG] Fri Nov 02 11:46:19 2012 [.532] (..\MMFC\Source\MacrOS.cpp,2356) -Going to change the permission of folder [C:\ProgramData\Adobe\Extension Manager CS6\Configuration], with command: [cacls.exe], parameter: ["C:\ProgramData\Adobe\Extension Manager CS6\Configuration" /T /E /C /G BUILTIN\Users:F]
              [DEBUG] Fri Nov 02 11:46:19 2012 [.544] (..\MMFC\Source\MacrOS.cpp,2361) -Succeed to make this folder writable for all users.
              [DEBUG] Fri Nov 02 11:46:19 2012 [.544] (..\MMFC\Source\MacrOS.cpp,2356) -Going to change the permission of folder [C:\ProgramData\Adobe\Extension Manager CS6\Configuration\DB], with command: [cacls.exe], parameter: ["C:\ProgramData\Adobe\Extension Manager CS6\Configuration\DB" /T /E /C /G BUILTIN\Users:F]
              [DEBUG] Fri Nov 02 11:46:19 2012 [.556] (..\MMFC\Source\MacrOS.cpp,2361) -Succeed to make this folder writable for all users.
              [INFO] Fri Nov 02 11:46:19 2012 [.557] (..\DBWrapper.cpp,2126) -Database connection is established successfully.
              [INFO] Fri Nov 02 11:46:19 2012 [.559] (..\DBWrapper.cpp,2249) -User database is attached successfully.
              [DEBUG] Fri Nov 02 11:46:19 2012 [.559] (..\MacrExtensionManager.cpp,1385) -All products hav been processed and saved in DB
              [DEBUG] Fri Nov 02 11:46:19 2012 [.560] (..\MacrExtensionManager.cpp,1486) -Extension Manager initialization finished.
              [DEBUG] Fri Nov 02 11:46:19 2012 [.560] (..\Control\commandExecutor.cpp,40) -OWL Controller initialized succeed
              [DEBUG] Fri Nov 02 11:46:19 2012 [.560] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.560] (..\Control\OWLFrontController.cpp,407) -Method Name: airNotifyReady
              [DEBUG] Fri Nov 02 11:46:19 2012 [.560] (..\Control\OWLFrontController.cpp,424) --5
              [DEBUG] Fri Nov 02 11:46:19 2012 [.560] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.564] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.564] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalGetExManConfigPath
              [DEBUG] Fri Nov 02 11:46:19 2012 [.564] (..\Control\OWLFrontController.cpp,118) -2
              [DEBUG] Fri Nov 02 11:46:19 2012 [.565] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.565] (..\Control\getExManConfigPathCommand.cpp,66) -ExMan machine EMStore path: C:\ProgramData\Adobe\Extension Manager CS6\EM Store\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.565] (..\Control\getExManConfigPathCommand.cpp,85) -ExMan my EMStore path: C:\Users\*****\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.565] (..\Control\getExManConfigPathCommand.cpp,92) -Version number is:
              [DEBUG] Fri Nov 02 11:46:19 2012 [.565] (..\Control\getExManConfigPathCommand.cpp,93) -6.0.4.8
              [DEBUG] Fri Nov 02 11:46:19 2012 [.565][ (DEBUG..\Control\OWLFrontController.cpp] ,Fri Nov 02 11:46:19 2012 [.565]404 () -..\Control\OWLFrontController.cpp-------------------Request (C++ side To AIR part ) Start--------------------------
              ,95[) -DEBUG-----------------AIR request To C++ Start-----------------------------------------------
              ] Fri Nov 02 11:46:19 2012 [.565][ (DEBUG..\Control\OWLFrontController.cpp] ,Fri Nov 02 11:46:19 2012 [.565]407 () -..\Control\OWLFrontController.cppMethod Name: airCallBack,
              98) -Receive the request from AIR, Request name is externalGetSupportedProducts[
              DEBUG] Fri Nov 02 11:46:19 2012 [.565][ (DEBUG..\Control\OWLFrontController.cpp] ,Fri Nov 02 11:46:19 2012 [.566]424 () -..\Control\OWLFrontController.cpp2,
              118) -3
              [DEBUG] Fri Nov 02 11:46:19 2012 [.566][ (DEBUG..\Control\OWLFrontController.cpp] ,Fri Nov 02 11:46:19 2012 [.566]142 () -..\Control\OWLFrontController.cpp----------------AIR request To C++ End--------------------------------------------------
              ,424) -0
              [DEBUG] Fri Nov 02 11:46:19 2012 [.566] (..\Control\OWLFrontController.cpp,424) -C:\ProgramData\Adobe\Extension Manager CS6\EM Store\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.566] (..\Control\OWLFrontController.cpp,424) -C:\Users\*****\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.566] (..\Control\OWLFrontController.cpp,424) -6.0.4.8
              [DEBUG] Fri Nov 02 11:46:19 2012 [.566] (..\Control\OWLFrontController.cpp,424) -C:\Users\*****\AppData\Roaming\Adobe\Extension Manager CS5.5\Configuration\Extensions\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.566] (..\Control\OWLFrontController.cpp,424) -C:\ProgramData\Adobe\Extension Manager CS5.5\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.566] (..\Control\OWLFrontController.cpp,424) -C:\Program Files (x86)
              [DEBUG] Fri Nov 02 11:46:19 2012 [.566] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.567] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
              [DEBUG] Fri Nov 02 11:46:19 2012 [.567] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Photoshop CS6 64
              [DEBUG] Fri Nov 02 11:46:19 2012 [.567] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Photoshop64
              [DEBUG] Fri Nov 02 11:46:19 2012 [.567] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 13.0.0
              [DEBUG] Fri Nov 02 11:46:19 2012 [.567] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 64\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.567] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Users\*****\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 64\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.567] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Users\*****\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 64\    C:\Users\***********\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 64\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.567] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/go/exchange
              [DEBUG] Fri Nov 02 11:46:19 2012 [.567] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Configuration\PS_exman_24px.png
              [DEBUG] Fri Nov 02 11:46:19 2012 [.568] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/cfusion/exchange/upload/index.cfm
              [DEBUG] Fri Nov 02 11:46:19 2012 [.568] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Photoshop
              [DEBUG] Fri Nov 02 11:46:19 2012 [.568] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Photoshop CS6 64\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.568] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Users\*****\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\Photoshop CS6 64\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.568] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Users\*****\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\Photoshop CS6 64\    C:\Users\***********\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\Photoshop CS6 64
              [DEBUG] Fri Nov 02 11:46:19 2012 [.568] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
              [DEBUG] Fri Nov 02 11:46:19 2012 [.568] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : PHSP
              [DEBUG] Fri Nov 02 11:46:19 2012 [.568] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 2
              [DEBUG] Fri Nov 02 11:46:19 2012 [.568] (..\Control\GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Configuration\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.568] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.568] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:19 2012 [.568] (..\Control\OWLFrontController.cpp,424) -3
              [DEBUG] Fri Nov 02 11:46:19 2012 [.568] (..\Control\OWLFrontController.cpp,424) -0
              [DEBUG] Fri Nov 02 11:46:19 2012 [.569] (..\Control\OWLFrontController.cpp,424) -0
              [DEBUG] Fri Nov 02 11:46:19 2012 [.569] (..\Control\OWLFrontController.cpp,424) -Photoshop CS6 64
              [DEBUG] Fri Nov 02 11:46:19 2012 [.569] (..\Control\OWLFrontController.cpp,424) -Photoshop64
              [DEBUG] Fri Nov 02 11:46:19 2012 [.569] (..\Control\OWLFrontController.cpp,424) -13.0.0
              [DEBUG] Fri Nov 02 11:46:19 2012 [.569] (..\Control\OWLFrontController.cpp,424) -C:\ProgramData\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 64\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.569] (..\Control\OWLFrontController.cpp,424) -C:\Users\*****\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 64\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.569] (..\Control\OWLFrontController.cpp,424) -C:\Users\*****\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 64\    C:\Users\***********\AppData\Roaming\Adobe\Extension Manager CS6\Mxi Flag\Photoshop CS6 64\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.569] (..\Control\OWLFrontController.cpp,424) -http://www.adobe.com/go/exchange
              [DEBUG] Fri Nov 02 11:46:19 2012 [.569] (..\Control\OWLFrontController.cpp,424) -C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Configuration\PS_exman_24px.png
              [DEBUG] Fri Nov 02 11:46:19 2012 [.569] (..\Control\OWLFrontController.cpp,424) -http://www.adobe.com/cfusion/exchange/upload/index.cfm
              [DEBUG] Fri Nov 02 11:46:19 2012 [.569] (..\Control\OWLFrontController.cpp,424) -C:\ProgramData\Adobe\Extension Manager CS6\EM Store\Photoshop CS6 64\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.569] (..\Control\OWLFrontController.cpp,424) -C:\Users\*****\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\Photoshop CS6 64\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.569] (..\Control\OWLFrontController.cpp,424) -C:\Users\*****\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\Photoshop CS6 64\    C:\Users\***********\AppData\Roaming\Adobe\Extension Manager CS6\EM Store\Photoshop CS6 64
              [DEBUG] Fri Nov 02 11:46:19 2012 [.569] (..\Control\OWLFrontController.cpp,424) -PHSP
              [DEBUG] Fri Nov 02 11:46:19 2012 [.570] (..\Control\OWLFrontController.cpp,424) -
              [DEBUG] Fri Nov 02 11:46:19 2012 [.570] (..\Control\OWLFrontController.cpp,424) -2
              [DEBUG] Fri Nov 02 11:46:19 2012 [.570] (..\Control\OWLFrontController.cpp,424) -C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Configuration\
              [DEBUG] Fri Nov 02 11:46:19 2012 [.570] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.598] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.598] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:46:19 2012 [.598] (..\Control\OWLFrontController.cpp,118) -7
              [DEBUG] Fri Nov 02 11:46:19 2012 [.598] (..\Control\OWLFrontController.cpp,118) -preinstall
              [DEBUG] Fri Nov 02 11:46:19 2012 [.598] (..\Control\OWLFrontController.cpp,118) -1
              [DEBUG] Fri Nov 02 11:46:19 2012 [.598] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:19 2012 [.598] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.599] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.599] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalMigratePreferredExtension
              [DEBUG] Fri Nov 02 11:46:19 2012 [.599] (..\Control\OWLFrontController.cpp,118) -4
              [DEBUG] Fri Nov 02 11:46:19 2012 [.599] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.599] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.599] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:19 2012 [.599] (..\Control\OWLFrontController.cpp,424) -4
              [DEBUG] Fri Nov 02 11:46:19 2012 [.599] (..\Control\OWLFrontController.cpp,424) -0
              [DEBUG] Fri Nov 02 11:46:19 2012 [.599] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.605] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.605] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:46:19 2012 [.605] (..\Control\OWLFrontController.cpp,118) -8
              [DEBUG] Fri Nov 02 11:46:19 2012 [.605] (..\Control\OWLFrontController.cpp,118) -preinstall
              [DEBUG] Fri Nov 02 11:46:19 2012 [.605] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:19 2012 [.605] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.612] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.612] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalGetLastVersionPointProducts
              [DEBUG] Fri Nov 02 11:46:19 2012 [.612] (..\Control\OWLFrontController.cpp,118) -9
              [DEBUG] Fri Nov 02 11:46:19 2012 [.612] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.612] (..\MacrProduct.cpp,182) -The product photoshop-60.064 is not supported by CS5.5
              [DEBUG] Fri Nov 02 11:46:19 2012 [.612] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.612] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:19 2012 [.612] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:19 2012 [.613] (..\Control\OWLFrontController.cpp,424) -0
              [DEBUG] Fri Nov 02 11:46:19 2012 [.613] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.621] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.621] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalLoadExtension
              [DEBUG] Fri Nov 02 11:46:19 2012 [.621] (..\Control\OWLFrontController.cpp,118) -12
              [DEBUG] Fri Nov 02 11:46:19 2012 [.621] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.621] (..\MacrExtensionManager.cpp,1787) -Begin to load extensions...
              [DEBUG] Fri Nov 02 11:46:19 2012 [.621] (..\Control\OWLExtensionMgrUI.cpp,244) -SetProgressCount:20
              [DEBUG] Fri Nov 02 11:46:19 2012 [.623] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.623] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:19 2012 [.623] (..\Control\OWLFrontController.cpp,424) -12
              [DEBUG] Fri Nov 02 11:46:19 2012 [.623] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:19 2012 [.623] (..\Control\OWLFrontController.cpp,424) -10
              [DEBUG] Fri Nov 02 11:46:19 2012 [.623] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.624] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.624] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:19 2012 [.624] (..\Control\OWLFrontController.cpp,424) -12
              [DEBUG] Fri Nov 02 11:46:19 2012 [.624] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:19 2012 [.624] (..\Control\OWLFrontController.cpp,424) -25
              [DEBUG] Fri Nov 02 11:46:19 2012 [.624] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.625] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.625] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:19 2012 [.625] (..\Control\OWLFrontController.cpp,424) -12
              [DEBUG] Fri Nov 02 11:46:19 2012 [.625] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:19 2012 [.625] (..\Control\OWLFrontController.cpp,424) -35
              [DEBUG] Fri Nov 02 11:46:19 2012 [.625] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.626] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.626] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:19 2012 [.626] (..\Control\OWLFrontController.cpp,424) -12
              [DEBUG] Fri Nov 02 11:46:19 2012 [.626] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:19 2012 [.626] (..\Control\OWLFrontController.cpp,424) -50
              [DEBUG] Fri Nov 02 11:46:19 2012 [.626] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.627] (..\MacrExtensionManager.cpp,1772) -Load: Photoshop CS6 64 firstLaunch is true
              [DEBUG] Fri Nov 02 11:46:19 2012 [.628] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.628] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:19 2012 [.628] (..\Control\OWLFrontController.cpp,424) -12
              [DEBUG] Fri Nov 02 11:46:19 2012 [.628] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:19 2012 [.628] (..\Control\OWLFrontController.cpp,424) -60
              [DEBUG] Fri Nov 02 11:46:19 2012 [.628] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.628] (..\DBWrapper.cpp,3301) -UpdateExtensionSets: not dirty for porductId 1
              [DEBUG] Fri Nov 02 11:46:19 2012 [.628] (..\DBWrapper.cpp,2609) -InitPredefinedExtensionSetTbl: clean up dirty table
              [DEBUG] Fri Nov 02 11:46:19 2012 [.632] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.632] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:19 2012 [.632] (..\Control\OWLFrontController.cpp,424) -12
              [DEBUG] Fri Nov 02 11:46:19 2012 [.632] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:19 2012 [.632] (..\Control\OWLFrontController.cpp,424) -70
              [DEBUG] Fri Nov 02 11:46:19 2012 [.632] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.632] (..\MacrExtensionManager.cpp,1890) -End to load extensions...
              [INFO] Fri Nov 02 11:46:19 2012 [.632] (..\Control\LoadExtensionCommand.cpp,46) -Load extension finished
              [DEBUG] Fri Nov 02 11:46:19 2012 [.632] (..\Control\OWLFrontController.cpp,424) -0
              [DEBUG] Fri Nov 02 11:46:19 2012 [.779] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.779] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airCommandLineRequestReady
              [DEBUG] Fri Nov 02 11:46:19 2012 [.779] (..\Control\OWLFrontController.cpp,118) -15
              [DEBUG] Fri Nov 02 11:46:19 2012 [.779] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.779] (..\Control\CLIReadyCommand.cpp,29) -C++ start to parse CLI and execute it
              [DEBUG] Fri Nov 02 11:46:19 2012 [.779] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.779] (..\Control\OWLFrontController.cpp,407) -Method Name: airEnableUI
              [DEBUG] Fri Nov 02 11:46:19 2012 [.779] (..\Control\OWLFrontController.cpp,424) --6
              [DEBUG] Fri Nov 02 11:46:19 2012 [.779] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:19 2012 [.852] (..\Control\HeadLightsMgr.cpp,208) -Initialize: +++
              [DEBUG] Fri Nov 02 11:46:19 2012 [.880] (..\Control\HeadLightsMgr.cpp,238) -Initialize: OptOut
              [ERROR] Fri Nov 02 11:46:19 2012 [.880] (..\Control\HeadLightsMgr.cpp,261) -Initialize: AdobePIPGetLogHandle() failed!
              [DEBUG] Fri Nov 02 11:46:22 2012 [.783] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:22 2012 [.783] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:22 2012 [.783] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:22 2012 [.783] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:25 2012 [.815] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:25 2012 [.815] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:25 2012 [.815] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:25 2012 [.815] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:28 2012 [.867] (..\Control\HeadLightsMgr.cpp,1104) -LogEvent: cat is ExtensionManagement, subCat is Remove, eventName is RemoveExtensionByButton
              [DEBUG] Fri Nov 02 11:46:28 2012 [.871] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:28 2012 [.871] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:28 2012 [.871] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:28 2012 [.871] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:30 2012 [.736] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:30 2012 [.736] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:46:30 2012 [.736] (..\Control\OWLFrontController.cpp,118) -24
              [DEBUG] Fri Nov 02 11:46:30 2012 [.736] (..\Control\OWLFrontController.cpp,118) -remove
              [DEBUG] Fri Nov 02 11:46:30 2012 [.736] (..\Control\OWLFrontController.cpp,118) -1
              [DEBUG] Fri Nov 02 11:46:30 2012 [.736] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:30 2012 [.736] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:30 2012 [.740] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:30 2012 [.740] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:46:30 2012 [.740] (..\Control\OWLFrontController.cpp,118) -25
              [DEBUG] Fri Nov 02 11:46:30 2012 [.740] (..\Control\OWLFrontController.cpp,118) -remove
              [DEBUG] Fri Nov 02 11:46:30 2012 [.740] (..\Control\OWLFrontController.cpp,118) -1
              [DEBUG] Fri Nov 02 11:46:30 2012 [.740] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:30 2012 [.740] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:30 2012 [.757] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:30 2012 [.757] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalRemoveExtension
              [DEBUG] Fri Nov 02 11:46:30 2012 [.757] (..\Control\OWLFrontController.cpp,118) -26
              [DEBUG] Fri Nov 02 11:46:30 2012 [.757] (..\Control\OWLFrontController.cpp,118) -Photoshop CS6 64
              [DEBUG] Fri Nov 02 11:46:30 2012 [.757] (..\Control\OWLFrontController.cpp,118) -com.configurator.extension
              [DEBUG] Fri Nov 02 11:46:30 2012 [.757] (..\Control\OWLFrontController.cpp,118) -com.configurator.extension.mxi
              [DEBUG] Fri Nov 02 11:46:30 2012 [.758] (..\Control\OWLFrontController.cpp,118) -1.0.0
              [DEBUG] Fri Nov 02 11:46:30 2012 [.758] (..\Control\OWLFrontController.cpp,118) -5
              [DEBUG] Fri Nov 02 11:46:30 2012 [.758] (..\Control\OWLFrontController.cpp,118) -false
              [DEBUG] Fri Nov 02 11:46:30 2012 [.758] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:30 2012 [.758] (..\Control\OWLExtensionMgrUI.cpp,238) -Show progress
              [DEBUG] Fri Nov 02 11:46:30 2012 [.758] (..\Control\OWLExtensionMgrUI.cpp,244) -SetProgressCount:2
              [DEBUG] Fri Nov 02 11:46:30 2012 [.758] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:30 2012 [.758] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:30 2012 [.758] (..\Control\OWLFrontController.cpp,424) -26
              [DEBUG] Fri Nov 02 11:46:30 2012 [.758] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:30 2012 [.758] (..\Control\OWLFrontController.cpp,424) -50
              [DEBUG] Fri Nov 02 11:46:30 2012 [.758] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:30 2012 [.759] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:30 2012 [.759] (..\Control\OWLFrontController.cpp,424) -100
              [DEBUG] Fri Nov 02 11:46:30 2012 [.759] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:31 2012 [.203] (..\Control\OWLExtensionMgrUI.cpp,301) -Hide progress
              [DEBUG] Fri Nov 02 11:46:31 2012 [.203] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:31 2012 [.204] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:31 2012 [.204] (..\Control\OWLFrontController.cpp,424) -26
              [DEBUG] Fri Nov 02 11:46:31 2012 [.204] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:31 2012 [.204] (..\Control\OWLFrontController.cpp,424) -100
              [DEBUG] Fri Nov 02 11:46:31 2012 [.204] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:31 2012 [.207] (..\DBWrapper.cpp,4467) -HandleSetForUninstallExtension: +++ extId 2
              [DEBUG] Fri Nov 02 11:46:31 2012 [.207] (..\Control\RemoveExtensionCommand.cpp,135) -Remove extension successful
              [DEBUG] Fri Nov 02 11:46:31 2012 [.207] (..\Control\RemoveExtensionCommand.cpp,231) -CRemoveExCommand::SetResponse: set extId to 2, prodId to 1
              [DEBUG] Fri Nov 02 11:46:31 2012 [.207] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:31 2012 [.207] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:31 2012 [.207] (..\Control\OWLFrontController.cpp,424) -26
              [DEBUG] Fri Nov 02 11:46:31 2012 [.207] (..\Control\OWLFrontController.cpp,424) -0
              [DEBUG] Fri Nov 02 11:46:31 2012 [.207] (..\Control\OWLFrontController.cpp,424) -1
              [DEBUG] Fri Nov 02 11:46:31 2012 [.207] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:31 2012 [.216] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:31 2012 [.217] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:46:31 2012 [.217] (..\Control\OWLFrontController.cpp,118) -27
              [DEBUG] Fri Nov 02 11:46:31 2012 [.217] (..\Control\OWLFrontController.cpp,118) -remove
              [DEBUG] Fri Nov 02 11:46:31 2012 [.217] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:31 2012 [.217] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:31 2012 [.893] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:31 2012 [.893] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:31 2012 [.893] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:31 2012 [.893] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:34 2012 [.927] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:34 2012 [.927] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:34 2012 [.927] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:34 2012 [.927] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:36 2012 [.422] (..\Control\HeadLightsMgr.cpp,1104) -LogEvent: cat is ExtensionManagement, subCat is Remove, eventName is RemoveExtensionByButton
              [DEBUG] Fri Nov 02 11:46:37 2012 [.932] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:37 2012 [.933] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:37 2012 [.933] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:37 2012 [.933] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:38 2012 [.379] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:38 2012 [.379] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:46:38 2012 [.379] (..\Control\OWLFrontController.cpp,118) -33
              [DEBUG] Fri Nov 02 11:46:38 2012 [.379] (..\Control\OWLFrontController.cpp,118) -remove
              [DEBUG] Fri Nov 02 11:46:38 2012 [.379] (..\Control\OWLFrontController.cpp,118) -1
              [DEBUG] Fri Nov 02 11:46:38 2012 [.379] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:38 2012 [.379] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:38 2012 [.381] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:38 2012 [.381] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:46:38 2012 [.381] (..\Control\OWLFrontController.cpp,118) -34
              [DEBUG] Fri Nov 02 11:46:38 2012 [.382] (..\Control\OWLFrontController.cpp,118) -remove
              [DEBUG] Fri Nov 02 11:46:38 2012 [.382] (..\Control\OWLFrontController.cpp,118) -1
              [DEBUG] Fri Nov 02 11:46:38 2012 [.382] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:38 2012 [.382] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:38 2012 [.394] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:38 2012 [.394] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalRemoveExtension
              [DEBUG] Fri Nov 02 11:46:38 2012 [.394] (..\Control\OWLFrontController.cpp,118) -35
              [DEBUG] Fri Nov 02 11:46:38 2012 [.394] (..\Control\OWLFrontController.cpp,118) -Photoshop CS6 64
              [DEBUG] Fri Nov 02 11:46:38 2012 [.394] (..\Control\OWLFrontController.cpp,118) -EasyDodgeFullCS6
              [DEBUG] Fri Nov 02 11:46:38 2012 [.395] (..\Control\OWLFrontController.cpp,118) -EasyDodgeFullCS6.mxi
              [DEBUG] Fri Nov 02 11:46:38 2012 [.395] (..\Control\OWLFrontController.cpp,118) -1.0
              [DEBUG] Fri Nov 02 11:46:38 2012 [.395] (..\Control\OWLFrontController.cpp,118) -5
              [DEBUG] Fri Nov 02 11:46:38 2012 [.395] (..\Control\OWLFrontController.cpp,118) -false
              [DEBUG] Fri Nov 02 11:46:38 2012 [.395] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:38 2012 [.395] (..\Control\OWLExtensionMgrUI.cpp,238) -Show progress
              [DEBUG] Fri Nov 02 11:46:38 2012 [.395] (..\Control\OWLExtensionMgrUI.cpp,244) -SetProgressCount:2
              [DEBUG] Fri Nov 02 11:46:38 2012 [.395] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:38 2012 [.395] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:38 2012 [.395] (..\Control\OWLFrontController.cpp,424) -35
              [DEBUG] Fri Nov 02 11:46:38 2012 [.396] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:38 2012 [.396] (..\Control\OWLFrontController.cpp,424) -50
              [DEBUG] Fri Nov 02 11:46:38 2012 [.396] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:38 2012 [.396] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:38 2012 [.396] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:38 2012 [.396] (..\Control\OWLFrontController.cpp,424) -35
              [DEBUG] Fri Nov 02 11:46:38 2012 [.396] (..\Control\OWLFrontController.cpp,424) -100
              [DEBUG] Fri Nov 02 11:46:38 2012 [.847] (..\Control\OWLExtensionMgrUI.cpp,301) -Hide progress
              [DEBUG] Fri Nov 02 11:46:38 2012 [.847] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:38 2012 [.847] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:38 2012 [.847] (..\Control\OWLFrontController.cpp,424) -35
              [DEBUG] Fri Nov 02 11:46:38 2012 [.847] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:38 2012 [.847] (..\Control\OWLFrontController.cpp,424) -100
              [DEBUG] Fri Nov 02 11:46:38 2012 [.847] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:38 2012 [.850] (..\DBWrapper.cpp,4467) -HandleSetForUninstallExtension: +++ extId 1
              [DEBUG] Fri Nov 02 11:46:38 2012 [.850] (..\Control\RemoveExtensionCommand.cpp,135) -Remove extension successful
              [DEBUG] Fri Nov 02 11:46:38 2012 [.850] (..\Control\RemoveExtensionCommand.cpp,231) -CRemoveExCommand::SetResponse: set extId to 1, prodId to 1
              [DEBUG] Fri Nov 02 11:46:38 2012 [.850] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:38 2012 [.850] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:38 2012 [.850] (..\Control\OWLFrontController.cpp,424) -35
              [DEBUG] Fri Nov 02 11:46:38 2012 [.850] (..\Control\OWLFrontController.cpp,424) -0
              [DEBUG] Fri Nov 02 11:46:38 2012 [.850] (..\Control\OWLFrontController.cpp,424) -1
              [DEBUG] Fri Nov 02 11:46:38 2012 [.850] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:38 2012 [.857] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:38 2012 [.857] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:46:38 2012 [.857] (..\Control\OWLFrontController.cpp,118) -36
              [DEBUG] Fri Nov 02 11:46:38 2012 [.857] (..\Control\OWLFrontController.cpp,118) -remove
              [DEBUG] Fri Nov 02 11:46:38 2012 [.857] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:38 2012 [.857] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:40 2012 [.969] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:40 2012 [.970] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:40 2012 [.970] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:40 2012 [.970] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:41 2012 [.147] (..\Control\HeadLightsMgr.cpp,1104) -LogEvent: cat is ExtensionManagement, subCat is Remove, eventName is RemoveExtensionByButton
              [DEBUG] Fri Nov 02 11:46:42 2012 [.858] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:42 2012 [.858] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:46:42 2012 [.858] (..\Control\OWLFrontController.cpp,118) -42
              [DEBUG] Fri Nov 02 11:46:42 2012 [.858] (..\Control\OWLFrontController.cpp,118) -remove
              [DEBUG] Fri Nov 02 11:46:42 2012 [.858] (..\Control\OWLFrontController.cpp,118) -1
              [DEBUG] Fri Nov 02 11:46:42 2012 [.858] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:42 2012 [.859] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:42 2012 [.861] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:42 2012 [.861] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:46:42 2012 [.861] (..\Control\OWLFrontController.cpp,118) -43
              [DEBUG] Fri Nov 02 11:46:42 2012 [.861] (..\Control\OWLFrontController.cpp,118) -remove
              [DEBUG] Fri Nov 02 11:46:42 2012 [.861] (..\Control\OWLFrontController.cpp,118) -1
              [DEBUG] Fri Nov 02 11:46:42 2012 [.861] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:42 2012 [.861] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:42 2012 [.873] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:42 2012 [.873] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalRemoveExtension
              [DEBUG] Fri Nov 02 11:46:42 2012 [.873] (..\Control\OWLFrontController.cpp,118) -44
              [DEBUG] Fri Nov 02 11:46:42 2012 [.873] (..\Control\OWLFrontController.cpp,118) -Photoshop CS6 64
              [DEBUG] Fri Nov 02 11:46:42 2012 [.873] (..\Control\OWLFrontController.cpp,118) -FromOztoKansasPowerTools
              [DEBUG] Fri Nov 02 11:46:42 2012 [.873] (..\Control\OWLFrontController.cpp,118) -FromOztoKansasPowerTools.mxi
              [DEBUG] Fri Nov 02 11:46:42 2012 [.874] (..\Control\OWLFrontController.cpp,118) -1.0.0
              [DEBUG] Fri Nov 02 11:46:42 2012 [.874] (..\Control\OWLFrontController.cpp,118) -5
              [DEBUG] Fri Nov 02 11:46:42 2012 [.874] (..\Control\OWLFrontController.cpp,118) -false
              [DEBUG] Fri Nov 02 11:46:42 2012 [.874] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:42 2012 [.874] (..\Control\OWLExtensionMgrUI.cpp,238) -Show progress
              [DEBUG] Fri Nov 02 11:46:42 2012 [.874] (..\Control\OWLExtensionMgrUI.cpp,244) -SetProgressCount:2
              [DEBUG] Fri Nov 02 11:46:42 2012 [.874] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:42 2012 [.874] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:42 2012 [.874] (..\Control\OWLFrontController.cpp,424) -44
              [DEBUG] Fri Nov 02 11:46:42 2012 [.874] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:42 2012 [.874] (..\Control\OWLFrontController.cpp,424) -50
              [DEBUG] Fri Nov 02 11:46:42 2012 [.874] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:42 2012 [.875] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:42 2012 [.875] (..\Control\OWLFrontController.cpp,424) -100
              [DEBUG] Fri Nov 02 11:46:42 2012 [.875] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:43 2012 [.309] (..\Control\OWLExtensionMgrUI.cpp,301) -Hide progress
              [DEBUG] Fri Nov 02 11:46:43 2012 [.309] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:43 2012 [.309] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:43 2012 [.309] (..\Control\OWLFrontController.cpp,424) -44
              [DEBUG] Fri Nov 02 11:46:43 2012 [.309] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:43 2012 [.309] (..\Control\OWLFrontController.cpp,424) -100
              [DEBUG] Fri Nov 02 11:46:43 2012 [.309] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:43 2012 [.314] (..\DBWrapper.cpp,4467) -HandleSetForUninstallExtension: +++ extId 3
              [DEBUG] Fri Nov 02 11:46:43 2012 [.314] (..\Control\RemoveExtensionCommand.cpp,135) -Remove extension successful
              [DEBUG] Fri Nov 02 11:46:43 2012 [.314] (..\Control\RemoveExtensionCommand.cpp,231) -CRemoveExCommand::SetResponse: set extId to 3, prodId to 1
              [DEBUG] Fri Nov 02 11:46:43 2012 [.315] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:43 2012 [.315] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:43 2012 [.315] (..\Control\OWLFrontController.cpp,424) -44
              [DEBUG] Fri Nov 02 11:46:43 2012 [.315] (..\Control\OWLFrontController.cpp,424) -0
              [DEBUG] Fri Nov 02 11:46:43 2012 [.315] (..\Control\OWLFrontController.cpp,424) -3
              [DEBUG] Fri Nov 02 11:46:43 2012 [.315] (..\Control\OWLFrontController.cpp,424) -1
              [DEBUG] Fri Nov 02 11:46:43 2012 [.315] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:43 2012 [.321] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:43 2012 [.321] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:46:43 2012 [.321] (..\Control\OWLFrontController.cpp,118) -45
              [DEBUG] Fri Nov 02 11:46:43 2012 [.321] (..\Control\OWLFrontController.cpp,118) -remove
              [DEBUG] Fri Nov 02 11:46:43 2012 [.321] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:43 2012 [.321] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:43 2012 [.993] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:43 2012 [.993] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:43 2012 [.993] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:43 2012 [.993] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:46 2012 [.724] (..\Control\HeadLightsMgr.cpp,1104) -LogEvent: cat is ExtensionManagement, subCat is Install, eventName is InstallExtensionByToolbar
              [DEBUG] Fri Nov 02 11:46:46 2012 [.993] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:46 2012 [.993] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:46 2012 [.993] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:46 2012 [.993] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:49 2012 [.993] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:49 2012 [.993] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:49 2012 [.993] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:49 2012 [.993] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:50 2012 [.875] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:50 2012 [.875] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:46:50 2012 [.876] (..\Control\OWLFrontController.cpp,118) -51
              [DEBUG] Fri Nov 02 11:46:50 2012 [.876] (..\Control\OWLFrontController.cpp,118) -install
              [DEBUG] Fri Nov 02 11:46:50 2012 [.876] (..\Control\OWLFrontController.cpp,118) -1
              [DEBUG] Fri Nov 02 11:46:50 2012 [.876] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:50 2012 [.876] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:50 2012 [.882] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:50 2012 [.882] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:46:50 2012 [.882] (..\Control\OWLFrontController.cpp,118) -53
              [DEBUG] Fri Nov 02 11:46:50 2012 [.882] (..\Control\OWLFrontController.cpp,118) -install
              [DEBUG] Fri Nov 02 11:46:50 2012 [.882] (..\Control\OWLFrontController.cpp,118) -1
              [DEBUG] Fri Nov 02 11:46:50 2012 [.882] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:50 2012 [.882] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:50 2012 [.889] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:50 2012 [.889] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalInstallExtension
              [DEBUG] Fri Nov 02 11:46:50 2012 [.889] (..\Control\OWLFrontController.cpp,118) -50
              [DEBUG] Fri Nov 02 11:46:50 2012 [.889] (..\Control\OWLFrontController.cpp,118) -Photoshop CS6 64
              [DEBUG] Fri Nov 02 11:46:50 2012 [.889] (..\Control\OWLFrontController.cpp,118) -D:\Photography\duChemin, David\DodgeBurnFullPackage\EasyDodgeFull\EasyDodgeFullCS6.zxp
              [DEBUG] Fri Nov 02 11:46:50 2012 [.889] (..\Control\OWLFrontController.cpp,118) -false
              [DEBUG] Fri Nov 02 11:46:50 2012 [.889] (..\Control\OWLFrontController.cpp,118) -true
              [DEBUG] Fri Nov 02 11:46:50 2012 [.889] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:50 2012 [.890] (..\Control\InstallExtensionCommand.cpp,407) -CInstallExCommand::parseArguments(): +++
              [DEBUG] Fri Nov 02 11:46:50 2012 [.890] (..\Control\InstallExtensionCommand.cpp,461) -CInstallExCommand::parseArguments(): isRollback false
              [DEBUG] Fri Nov 02 11:46:50 2012 [.890] (..\Control\InstallExtensionCommand.cpp,49) -CInstallExCommand::execute(): non-rollback session, reset g_exitCode
              [DEBUG] Fri Nov 02 11:46:50 2012 [.890] (..\MacrExtensionManager.cpp,3819) -CMacrExtensionManager::InstallExtension: isRollback false
              [DEBUG] Fri Nov 02 11:46:50 2012 [.890] (..\Control\OWLExtensionMgrUI.cpp,238) -Show progress
              [DEBUG] Fri Nov 02 11:46:50 2012 [.890] (..\Control\OWLExtensionMgrUI.cpp,244) -SetProgressCount:20
              [DEBUG] Fri Nov 02 11:46:50 2012 [.890] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:50 2012 [.890] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:50 2012 [.890] (..\Control\OWLFrontController.cpp,424) -50
              [DEBUG] Fri Nov 02 11:46:50 2012 [.890] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:50 2012 [.890] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:51 2012 [.62] (..\Control\OWLExtensionMgrUI.cpp,244) -SetProgressCount:16
              [DEBUG] Fri Nov 02 11:46:51 2012 [.62] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:51 2012 [.62] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:51 2012 [.62] (..\Control\OWLFrontController.cpp,424) -50
              [DEBUG] Fri Nov 02 11:46:51 2012 [.62] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:51 2012 [.62] (..\Control\OWLFrontController.cpp,424) -6
              [DEBUG] Fri Nov 02 11:46:51 2012 [.62] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:51 2012 [.74] (..\Control\OWLExtensionMgrUI.cpp,446) -to generate mxi file for dir: C:\Users\*****\AppData\Local\Temp\SCZ1A5A.tmp\CSXS\manifest.xml and zxp name is EasyDodgeFullCS6.zxp
              [DEBUG] Fri Nov 02 11:46:51 2012 [.74] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:51 2012 [.74] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:51 2012 [.74] (..\Control\OWLFrontController.cpp,424) -50
              [DEBUG] Fri Nov 02 11:46:51 2012 [.74] (..\Control\OWLFrontController.cpp,424) -101
              [DEBUG] Fri Nov 02 11:46:51 2012 [.74] (..\Control\OWLFrontController.cpp,424) -C:\Users\*****\AppData\Local\Temp\SCZ1A5A.tmp\CSXS\manifest.xml
              [DEBUG] Fri Nov 02 11:46:51 2012 [.74] (..\Control\OWLFrontController.cpp,424) -EasyDodgeFullCS6.zxp
              [DEBUG] Fri Nov 02 11:46:51 2012 [.75] (..\Control\OWLFrontController.cpp,424) -C:\Users\*****\AppData\Local\Temp\EasyDodgeFullCS6_mxi\EasyDodgeFullCS6.mxi
              [DEBUG] Fri Nov 02 11:46:51 2012 [.75] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:51 2012 [.104] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:51 2012 [.104] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalRespondFromAIR
              [DEBUG] Fri Nov 02 11:46:51 2012 [.104] (..\Control\OWLFrontController.cpp,118) -50
              [DEBUG] Fri Nov 02 11:46:51 2012 [.104] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:51 2012 [.104] (..\Control\OWLFrontController.cpp,118) -EasyDodgeFullCS6.zxp
              [DEBUG] Fri Nov 02 11:46:51 2012 [.104] (..\Control\OWLFrontController.cpp,118) -C:\Users\*****\AppData\Local\Temp\EasyDodgeFullCS6_mxi\EasyDodgeFullCS6.mxi
              [DEBUG] Fri Nov 02 11:46:51 2012 [.104] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:51 2012 [.104] (..\Control\OWLFrontController.cpp,165) -RequestId is50. It is a request used to unlock OK/Cancel
              [DEBUG] Fri Nov 02 11:46:51 2012 [.111] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:51 2012 [.111] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:51 2012 [.111] (..\Control\OWLFrontController.cpp,424) -50
              [DEBUG] Fri Nov 02 11:46:51 2012 [.111] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:51 2012 [.111] (..\Control\OWLFrontController.cpp,424) -12
              [DEBUG] Fri Nov 02 11:46:51 2012 [.111] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:51 2012 [.112] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:51 2012 [.112] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:51 2012 [.112] (..\Control\OWLFrontController.cpp,424) -50
              [DEBUG] Fri Nov 02 11:46:51 2012 [.112] (..\Control\OWLFrontController.cpp,424) -7
              [DEBUG] Fri Nov 02 11:46:51 2012 [.112] (..\Control\OWLFrontController.cpp,424) -You are about to install the 'EasyDodgeFullCS6' extension. Please read the following carefully before you continue.
              [DEBUG] Fri Nov 02 11:46:51 2012 [.112] (..\Control\OWLFrontController.cpp,424) -"EasyDodgeFullCS6" is a customized panel for Photoshop CS6 developed by Configurator 3. Once this extension is installed, "EasyDodgeFullCS6" can be launched from Window > Extension > EasyDodgeFullCS6. Select, Window > Extension > to close the EasyDodgeFullCS6 panel.
              [DEBUG] Fri Nov 02 11:46:51 2012 [.112] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:53 2012 [.24] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:53 2012 [.24] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:53 2012 [.24] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:53 2012 [.24] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:53 2012 [.293] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:53 2012 [.293] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalRespondFromAIR
              [DEBUG] Fri Nov 02 11:46:53 2012 [.293] (..\Control\OWLFrontController.cpp,118) -50
              [DEBUG] Fri Nov 02 11:46:53 2012 [.293] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:53 2012 [.293] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:53 2012 [.293] (..\Control\OWLFrontController.cpp,165) -RequestId is50. It is a request used to unlock OK/Cancel
              [DEBUG] Fri Nov 02 11:46:53 2012 [.294] (..\Control\HeadLightsMgr.cpp,1104) -LogEvent: cat is ExtensionManagement, subCat is InstallType, eventName is PerMachineExtensionInstalledPerMachine
              [DEBUG] Fri Nov 02 11:46:53 2012 [.294] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:53 2012 [.295] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:53 2012 [.295] (..\Control\OWLFrontController.cpp,424) -50
              [DEBUG] Fri Nov 02 11:46:53 2012 [.295] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:53 2012 [.295] (..\Control\OWLFrontController.cpp,424) -18
              [DEBUG] Fri Nov 02 11:46:53 2012 [.295] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:53 2012 [.308] (..\Control\OWLExtensionMgrUI.cpp,623) -to request air to validation:  1; EasyDodgeFullCS6; EasyDodgeFullCS6; EasyDodgeFullCS6; EasyDodgeFullCS6; C:\Users\*****\AppData\Local\Temp\SCZ1A5A.tmp; 1.0;
              [DEBUG] Fri Nov 02 11:46:53 2012 [.308] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:53 2012 [.308] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:53 2012 [.308] (..\Control\OWLFrontController.cpp,424) -50
              [DEBUG] Fri Nov 02 11:46:53 2012 [.308] (..\Control\OWLFrontController.cpp,424) -102
              [DEBUG] Fri Nov 02 11:46:53 2012 [.308] (..\Control\OWLFrontController.cpp,424) -EasyDodgeFullCS6
              [DEBUG] Fri Nov 02 11:46:53 2012 [.309] (..\Control\OWLFrontController.cpp,424) -EasyDodgeFullCS6
              [DEBUG] Fri Nov 02 11:46:53 2012 [.309] (..\Control\OWLFrontController.cpp,424) -C:\Users\*****\AppData\Local\Temp\SCZ1A5A.tmp
              [DEBUG] Fri Nov 02 11:46:53 2012 [.309] (..\Control\OWLFrontController.cpp,424) -1.0
              [DEBUG] Fri Nov 02 11:46:53 2012 [.309] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:53 2012 [.929] (..\Control\HeadLightsMgr.cpp,1104) -LogEvent: cat is ExtensionManagement, subCat is Install, eventName is PopUpSignatureDialogByInstallExtension
              [DEBUG] Fri Nov 02 11:46:55 2012 [.420] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:55 2012 [.420] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalRespondFromAIR
              [DEBUG] Fri Nov 02 11:46:55 2012 [.420] (..\Control\OWLFrontController.cpp,118) -50
              [DEBUG] Fri Nov 02 11:46:55 2012 [.420] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:55 2012 [.420] (..\Control\OWLFrontController.cpp,118) -EasyDodgeFullCS6
              [DEBUG] Fri Nov 02 11:46:55 2012 [.420] (..\Control\OWLFrontController.cpp,118) -1
              [DEBUG] Fri Nov 02 11:46:55 2012 [.420] (..\Control\OWLFrontController.cpp,118) -2
              [DEBUG] Fri Nov 02 11:46:55 2012 [.420] (..\Control\OWLFrontController.cpp,118) -CraftAndVision
              [DEBUG] Fri Nov 02 11:46:55 2012 [.420] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:55 2012 [.421] (..\Control\OWLFrontController.cpp,165) -RequestId is50. It is a request used to unlock OK/Cancel
              [DEBUG] Fri Nov 02 11:46:55 2012 [.421] (..\Control\OWLExtensionMgrUI.cpp,662) -EasyDodgeFullCS6
              [DEBUG] Fri Nov 02 11:46:55 2012 [.421] (..\Control\OWLExtensionMgrUI.cpp,662) -1
              [DEBUG] Fri Nov 02 11:46:55 2012 [.421] (..\Control\OWLExtensionMgrUI.cpp,662) -2
              [DEBUG] Fri Nov 02 11:46:55 2012 [.421] (..\Control\OWLExtensionMgrUI.cpp,662) -CraftAndVision
              [DEBUG] Fri Nov 02 11:46:55 2012 [.421] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:55 2012 [.421] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:55 2012 [.421] (..\Control\OWLFrontController.cpp,424) -50
              [DEBUG] Fri Nov 02 11:46:55 2012 [.421] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:55 2012 [.421] (..\Control\OWLFrontController.cpp,424) -25
              [DEBUG] Fri Nov 02 11:46:55 2012 [.421] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:55 2012 [.467] (..\Control\OWLExtensionMgrUI.cpp,301) -Hide progress
              [DEBUG] Fri Nov 02 11:46:55 2012 [.467] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:55 2012 [.467] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:55 2012 [.467] (..\Control\OWLFrontController.cpp,424) -50
              [DEBUG] Fri Nov 02 11:46:55 2012 [.467] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:55 2012 [.468] (..\Control\OWLFrontController.cpp,424) -100
              [DEBUG] Fri Nov 02 11:46:55 2012 [.468] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:55 2012 [.649] (..\Control\OWLExtensionMgrUI.cpp,301) -Hide progress
              [DEBUG] Fri Nov 02 11:46:55 2012 [.649] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:55 2012 [.649] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:55 2012 [.649] (..\Control\OWLFrontController.cpp,424) -50
              [DEBUG] Fri Nov 02 11:46:55 2012 [.649] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:46:55 2012 [.649] (..\Control\OWLFrontController.cpp,424) -100
              [DEBUG] Fri Nov 02 11:46:55 2012 [.649] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:55 2012 [.649] (..\MacrExtensionManager.cpp,7318) -CMacrExtensionManager::InstallExtension(): non-rollback session, reset g_exitCode
              [DEBUG] Fri Nov 02 11:46:55 2012 [.664] (..\DBWrapper.cpp,4328) -HandleSetForInstallExtension:+++ extId 5
              [DEBUG] Fri Nov 02 11:46:55 2012 [.664] (..\DBWrapper.cpp,4357) -HandleSetForInstallExtension: extId 5, extName EasyDodgeFullCS6, prodId 1
              [DEBUG] Fri Nov 02 11:46:55 2012 [.671] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:46:55 2012 [.671] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:46:55 2012 [.671] (..\Control\OWLFrontController.cpp,424) -50
              [DEBUG] Fri Nov 02 11:46:55 2012 [.671] (..\Control\OWLFrontController.cpp,424) -0
              [DEBUG] Fri Nov 02 11:46:55 2012 [.671] (..\Control\OWLFrontController.cpp,424) -Photoshop CS6 64
              [DEBUG] Fri Nov 02 11:46:55 2012 [.671] (..\Control\OWLFrontController.cpp,424) -EasyDodgeFullCS6.mxi
              [DEBUG] Fri Nov 02 11:46:55 2012 [.671] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:46:55 2012 [.697] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:55 2012 [.697] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:46:55 2012 [.697] (..\Control\OWLFrontController.cpp,118) -55
              [DEBUG] Fri Nov 02 11:46:55 2012 [.697] (..\Control\OWLFrontController.cpp,118) -install
              [DEBUG] Fri Nov 02 11:46:55 2012 [.697] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:46:55 2012 [.697] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:56 2012 [.28] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:56 2012 [.29] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:56 2012 [.29] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:56 2012 [.29] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:46:58 2012 [.667] (..\Control\HeadLightsMgr.cpp,1104) -LogEvent: cat is ExtensionManagement, subCat is Install, eventName is InstallExtensionByToolbar
              [DEBUG] Fri Nov 02 11:46:59 2012 [.28] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:46:59 2012 [.29] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:59 2012 [.29] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:46:59 2012 [.29] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:02 2012 [.28] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:02 2012 [.29] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:02 2012 [.29] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:02 2012 [.29] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:05 2012 [.29] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:05 2012 [.29] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:05 2012 [.29] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:05 2012 [.29] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:08 2012 [.30] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:08 2012 [.30] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:08 2012 [.30] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:08 2012 [.30] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:11 2012 [.29] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:11 2012 [.29] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:11 2012 [.29] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:11 2012 [.29] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:13 2012 [.740] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:13 2012 [.740] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:47:13 2012 [.740] (..\Control\OWLFrontController.cpp,118) -61
              [DEBUG] Fri Nov 02 11:47:13 2012 [.740] (..\Control\OWLFrontController.cpp,118) -install
              [DEBUG] Fri Nov 02 11:47:13 2012 [.740] (..\Control\OWLFrontController.cpp,118) -1
              [DEBUG] Fri Nov 02 11:47:13 2012 [.740] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:47:13 2012 [.740] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:13 2012 [.746] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:13 2012 [.746] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:47:13 2012 [.746] (..\Control\OWLFrontController.cpp,118) -63
              [DEBUG] Fri Nov 02 11:47:13 2012 [.746] (..\Control\OWLFrontController.cpp,118) -install
              [DEBUG] Fri Nov 02 11:47:13 2012 [.746] (..\Control\OWLFrontController.cpp,118) -1
              [DEBUG] Fri Nov 02 11:47:13 2012 [.746] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:47:13 2012 [.746] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:13 2012 [.755] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:13 2012 [.756] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalInstallExtension
              [DEBUG] Fri Nov 02 11:47:13 2012 [.756] (..\Control\OWLFrontController.cpp,118) -60
              [DEBUG] Fri Nov 02 11:47:13 2012 [.756] (..\Control\OWLFrontController.cpp,118) -Photoshop CS6 64
              [DEBUG] Fri Nov 02 11:47:13 2012 [.756] (..\Control\OWLFrontController.cpp,118) -D:\Photography\Versace - From Oz to Kansas\Unzipped\OZ_2_KANSAS_12_CONFIGURATORS\From Oz to Kansas Power Tools.zxp
              [DEBUG] Fri Nov 02 11:47:13 2012 [.756] (..\Control\OWLFrontController.cpp,118) -5
              [DEBUG] Fri Nov 02 11:47:13 2012 [.756] (..\Control\OWLFrontController.cpp,118) -false
              [DEBUG] Fri Nov 02 11:47:13 2012 [.756] (..\Control\OWLFrontController.cpp,118) -true
              [DEBUG] Fri Nov 02 11:47:13 2012 [.756] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:13 2012 [.756] (..\Control\InstallExtensionCommand.cpp,407) -CInstallExCommand::parseArguments(): +++
              [DEBUG] Fri Nov 02 11:47:13 2012 [.757] (..\Control\InstallExtensionCommand.cpp,461) -CInstallExCommand::parseArguments(): isRollback false
              [DEBUG] Fri Nov 02 11:47:13 2012 [.757] (..\Control\InstallExtensionCommand.cpp,49) -CInstallExCommand::execute(): non-rollback session, reset g_exitCode
              [DEBUG] Fri Nov 02 11:47:13 2012 [.757] (..\MacrExtensionManager.cpp,3819) -CMacrExtensionManager::InstallExtension: isRollback false
              [DEBUG] Fri Nov 02 11:47:13 2012 [.757] (..\Control\OWLExtensionMgrUI.cpp,238) -Show progress
              [DEBUG] Fri Nov 02 11:47:13 2012 [.757] (..\Control\OWLExtensionMgrUI.cpp,244) -SetProgressCount:20
              [DEBUG] Fri Nov 02 11:47:13 2012 [.757] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:13 2012 [.757] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:13 2012 [.757] (..\Control\OWLFrontController.cpp,424) -60
              [DEBUG] Fri Nov 02 11:47:13 2012 [.758] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:47:13 2012 [.758] (..\Control\OWLFrontController.cpp,424) -5
              [DEBUG] Fri Nov 02 11:47:13 2012 [.758] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:13 2012 [.935] (..\Control\OWLExtensionMgrUI.cpp,244) -SetProgressCount:16
              [DEBUG] Fri Nov 02 11:47:13 2012 [.935] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:13 2012 [.935] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:13 2012 [.935] (..\Control\OWLFrontController.cpp,424) -60
              [DEBUG] Fri Nov 02 11:47:13 2012 [.935] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:47:13 2012 [.935] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:13 2012 [.947] (..\Control\OWLExtensionMgrUI.cpp,446) -to generate mxi file for dir: C:\Users\*****\AppData\Local\Temp\SCZ73B6.tmp\CSXS\manifest.xml and zxp name is From Oz to Kansas Power Tools.zxp
              [DEBUG] Fri Nov 02 11:47:13 2012 [.947] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:13 2012 [.947] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:13 2012 [.947] (..\Control\OWLFrontController.cpp,424) -60
              [DEBUG] Fri Nov 02 11:47:13 2012 [.947] (..\Control\OWLFrontController.cpp,424) -101
              [DEBUG] Fri Nov 02 11:47:13 2012 [.947] (..\Control\OWLFrontController.cpp,424) -C:\Users\*****\AppData\Local\Temp\SCZ73B6.tmp\CSXS\manifest.xml
              [DEBUG] Fri Nov 02 11:47:13 2012 [.947] (..\Control\OWLFrontController.cpp,424) -From Oz to Kansas Power Tools.zxp
              [DEBUG] Fri Nov 02 11:47:13 2012 [.947] (..\Control\OWLFrontController.cpp,424) -C:\Users\*****\AppData\Local\Temp\From Oz to Kansas Power Tools_mxi\From Oz to Kansas Power Tools.mxi
              [DEBUG] Fri Nov 02 11:47:13 2012 [.947] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:13 2012 [.970] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:13 2012 [.970] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalRespondFromAIR
              [DEBUG] Fri Nov 02 11:47:13 2012 [.970] (..\Control\OWLFrontController.cpp,118) -60
              [DEBUG] Fri Nov 02 11:47:13 2012 [.970] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:47:13 2012 [.970] (..\Control\OWLFrontController.cpp,118) -FromOztoKansasPowerTools.zxp
              [DEBUG] Fri Nov 02 11:47:13 2012 [.970] (..\Control\OWLFrontController.cpp,118) -C:\Users\*****\AppData\Local\Temp\From Oz to Kansas Power Tools_mxi\FromOztoKansasPowerTools.mxi
              [DEBUG] Fri Nov 02 11:47:13 2012 [.970] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:13 2012 [.970] (..\Control\OWLFrontController.cpp,165) -RequestId is60. It is a request used to unlock OK/Cancel
              [INFO] Fri Nov 02 11:47:13 2012 [.970] (..\MacrExtensionManager.cpp,13368) -mxi file name has been changed to ExtensionBundleId.
              [DEBUG] Fri Nov 02 11:47:13 2012 [.977] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:13 2012 [.977] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:13 2012 [.977] (..\Control\OWLFrontController.cpp,424) -60
              [DEBUG] Fri Nov 02 11:47:13 2012 [.977] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:47:13 2012 [.977] (..\Control\OWLFrontController.cpp,424) -12
              [DEBUG] Fri Nov 02 11:47:13 2012 [.977] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:13 2012 [.978] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:13 2012 [.978] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:13 2012 [.978] (..\Control\OWLFrontController.cpp,424) -60
              [DEBUG] Fri Nov 02 11:47:13 2012 [.978] (..\Control\OWLFrontController.cpp,424) -7
              [DEBUG] Fri Nov 02 11:47:13 2012 [.978] (..\Control\OWLFrontController.cpp,424) -You are about to install the 'FromOztoKansasPowerTools' extension. Please read the following carefully before you continue.
              [DEBUG] Fri Nov 02 11:47:13 2012 [.978] (..\Control\OWLFrontController.cpp,424) -"Configurator-Panel" is a customized panel for Photoshop CS6 developed by Configurator 3. Once this extension is installed, "Configurator-Panel" can be launched from Window > Extension > From Oz to Kansas Power Tools. Select, Window > Extension > to close the From Oz to Kansas Power Tools panel.
              [DEBUG] Fri Nov 02 11:47:13 2012 [.978] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:14 2012 [.79] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:14 2012 [.79] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:14 2012 [.79] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:14 2012 [.79] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:15 2012 [.939] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:15 2012 [.940] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalRespondFromAIR
              [DEBUG] Fri Nov 02 11:47:15 2012 [.940] (..\Control\OWLFrontController.cpp,118) -60
              [DEBUG] Fri Nov 02 11:47:15 2012 [.940] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:47:15 2012 [.940] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:15 2012 [.940] (..\Control\OWLFrontController.cpp,165) -RequestId is60. It is a request used to unlock OK/Cancel
              [DEBUG] Fri Nov 02 11:47:15 2012 [.940] (..\Control\HeadLightsMgr.cpp,1104) -LogEvent: cat is ExtensionManagement, subCat is InstallType, eventName is PerMachineExtensionInstalledPerMachine
              [DEBUG] Fri Nov 02 11:47:15 2012 [.941] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:15 2012 [.941] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:15 2012 [.941] (..\Control\OWLFrontController.cpp,424) -60
              [DEBUG] Fri Nov 02 11:47:15 2012 [.941] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:47:15 2012 [.941] (..\Control\OWLFrontController.cpp,424) -18
              [DEBUG] Fri Nov 02 11:47:15 2012 [.941] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:15 2012 [.954] (..\Control\OWLExtensionMgrUI.cpp,623) -to request air to validation:  1; FromOztoKansasPowerTools; FromOztoKansasPowerTools; FromOztoKansasPowerTools; FromOztoKansasPowerTools; C:\Users\*****\AppData\Local\Temp\SCZ73B6.tmp; 1.0.0;
              [DEBUG] Fri Nov 02 11:47:15 2012 [.955] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:15 2012 [.955] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:15 2012 [.955] (..\Control\OWLFrontController.cpp,424) -60
              [DEBUG] Fri Nov 02 11:47:15 2012 [.955] (..\Control\OWLFrontController.cpp,424) -102
              [DEBUG] Fri Nov 02 11:47:15 2012 [.955] (..\Control\OWLFrontController.cpp,424) -FromOztoKansasPowerTools
              [DEBUG] Fri Nov 02 11:47:15 2012 [.955] (..\Control\OWLFrontController.cpp,424) -C:\Users\*****\AppData\Local\Temp\SCZ73B6.tmp
              [DEBUG] Fri Nov 02 11:47:15 2012 [.955] (..\Control\OWLFrontController.cpp,424) -1.0.0
              [DEBUG] Fri Nov 02 11:47:15 2012 [.955] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:16 2012 [.519] (..\Control\HeadLightsMgr.cpp,1104) -LogEvent: cat is ExtensionManagement, subCat is Install, eventName is PopUpSignatureDialogByInstallExtension
              [DEBUG] Fri Nov 02 11:47:17 2012 [.106] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:17 2012 [.107] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:17 2012 [.107] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:17 2012 [.107] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:17 2012 [.979] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:17 2012 [.979] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalRespondFromAIR
              [DEBUG] Fri Nov 02 11:47:17 2012 [.979] (..\Control\OWLFrontController.cpp,118) -60
              [DEBUG] Fri Nov 02 11:47:17 2012 [.979] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:47:17 2012 [.979] (..\Control\OWLFrontController.cpp,118) -FromOztoKansasPowerTools
              [DEBUG] Fri Nov 02 11:47:17 2012 [.979] (..\Control\OWLFrontController.cpp,118) -1
              [DEBUG] Fri Nov 02 11:47:17 2012 [.979] (..\Control\OWLFrontController.cpp,118) -2
              [DEBUG] Fri Nov 02 11:47:17 2012 [.979] (..\Control\OWLFrontController.cpp,118) -Sean Dyroff #B Vincent Versace
              [DEBUG] Fri Nov 02 11:47:17 2012 [.979] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:17 2012 [.979] (..\Control\OWLFrontController.cpp,165) -RequestId is60. It is a request used to unlock OK/Cancel
              [DEBUG] Fri Nov 02 11:47:17 2012 [.979] (..\Control\OWLExtensionMgrUI.cpp,662) -FromOztoKansasPowerTools
              [DEBUG] Fri Nov 02 11:47:17 2012 [.980] (..\Control\OWLExtensionMgrUI.cpp,662) -1
              [DEBUG] Fri Nov 02 11:47:17 2012 [.980] (..\Control\OWLExtensionMgrUI.cpp,662) -2
              [DEBUG] Fri Nov 02 11:47:17 2012 [.980] (..\Control\OWLExtensionMgrUI.cpp,662) -Sean Dyroff & Vincent Versace
              [DEBUG] Fri Nov 02 11:47:17 2012 [.980] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:17 2012 [.980] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:17 2012 [.980] (..\Control\OWLFrontController.cpp,424) -60
              [DEBUG] Fri Nov 02 11:47:17 2012 [.980] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:47:17 2012 [.980] (..\Control\OWLFrontController.cpp,424) -25
              [DEBUG] Fri Nov 02 11:47:17 2012 [.980] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:18 2012 [.27] (..\Control\OWLExtensionMgrUI.cpp,301) -Hide progress
              [DEBUG] Fri Nov 02 11:47:18 2012 [.27] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:18 2012 [.27] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:18 2012 [.27] (..\Control\OWLFrontController.cpp,424) -60
              [DEBUG] Fri Nov 02 11:47:18 2012 [.27] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:47:18 2012 [.27] (..\Control\OWLFrontController.cpp,424) -100
              [DEBUG] Fri Nov 02 11:47:18 2012 [.27] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:18 2012 [.210] (..\Control\OWLExtensionMgrUI.cpp,301) -Hide progress
              [DEBUG] Fri Nov 02 11:47:18 2012 [.210] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:18 2012 [.210] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:18 2012 [.210] (..\Control\OWLFrontController.cpp,424) -60
              [DEBUG] Fri Nov 02 11:47:18 2012 [.210] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:47:18 2012 [.210] (..\Control\OWLFrontController.cpp,424) -100
              [DEBUG] Fri Nov 02 11:47:18 2012 [.210] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:18 2012 [.211] (..\MacrExtensionManager.cpp,7318) -CMacrExtensionManager::InstallExtension(): non-rollback session, reset g_exitCode
              [DEBUG] Fri Nov 02 11:47:18 2012 [.215] (..\DBWrapper.cpp,4328) -HandleSetForInstallExtension:+++ extId 6
              [DEBUG] Fri Nov 02 11:47:18 2012 [.215] (..\DBWrapper.cpp,4357) -HandleSetForInstallExtension: extId 6, extName FromOztoKansasPowerTools, prodId 1
              [DEBUG] Fri Nov 02 11:47:18 2012 [.224] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:18 2012 [.224] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:18 2012 [.224] (..\Control\OWLFrontController.cpp,424) -60
              [DEBUG] Fri Nov 02 11:47:18 2012 [.224] (..\Control\OWLFrontController.cpp,424) -0
              [DEBUG] Fri Nov 02 11:47:18 2012 [.224] (..\Control\OWLFrontController.cpp,424) -Photoshop CS6 64
              [DEBUG] Fri Nov 02 11:47:18 2012 [.224] (..\Control\OWLFrontController.cpp,424) -FromOztoKansasPowerTools.mxi
              [DEBUG] Fri Nov 02 11:47:18 2012 [.224] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:18 2012 [.245] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:18 2012 [.245] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:47:18 2012 [.245] (..\Control\OWLFrontController.cpp,118) -65
              [DEBUG] Fri Nov 02 11:47:18 2012 [.245] (..\Control\OWLFrontController.cpp,118) -install
              [DEBUG] Fri Nov 02 11:47:18 2012 [.245] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:47:18 2012 [.245] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:20 2012 [.106] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:20 2012 [.107] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:20 2012 [.107] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:20 2012 [.107] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:21 2012 [.354] (..\Control\HeadLightsMgr.cpp,1104) -LogEvent: cat is ExtensionManagement, subCat is Install, eventName is InstallExtensionByToolbar
              [DEBUG] Fri Nov 02 11:47:23 2012 [.106] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:23 2012 [.107] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:23 2012 [.107] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:23 2012 [.107] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:23 2012 [.776] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:23 2012 [.776] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:47:23 2012 [.776] (..\Control\OWLFrontController.cpp,118) -71
              [DEBUG] Fri Nov 02 11:47:23 2012 [.776] (..\Control\OWLFrontController.cpp,118) -install
              [DEBUG] Fri Nov 02 11:47:23 2012 [.776] (..\Control\OWLFrontController.cpp,118) -1
              [DEBUG] Fri Nov 02 11:47:23 2012 [.776] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:47:23 2012 [.776] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:23 2012 [.781] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:23 2012 [.781] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:47:23 2012 [.781] (..\Control\OWLFrontController.cpp,118) -73
              [DEBUG] Fri Nov 02 11:47:23 2012 [.781] (..\Control\OWLFrontController.cpp,118) -install
              [DEBUG] Fri Nov 02 11:47:23 2012 [.781] (..\Control\OWLFrontController.cpp,118) -1
              [DEBUG] Fri Nov 02 11:47:23 2012 [.782] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:47:23 2012 [.782] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:23 2012 [.791] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:23 2012 [.791] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalInstallExtension
              [DEBUG] Fri Nov 02 11:47:23 2012 [.791] (..\Control\OWLFrontController.cpp,118) -70
              [DEBUG] Fri Nov 02 11:47:23 2012 [.791] (..\Control\OWLFrontController.cpp,118) -Photoshop CS6 64
              [DEBUG] Fri Nov 02 11:47:23 2012 [.791] (..\Control\OWLFrontController.cpp,118) -D:\Photography\Versace - From Oz to Kansas\Unzipped\OZ_2_KANSAS_12_CONFIGURATORS\From Oz to Kansas.zxp
              [DEBUG] Fri Nov 02 11:47:23 2012 [.792] (..\Control\OWLFrontController.cpp,118) -5
              [DEBUG] Fri Nov 02 11:47:23 2012 [.792] (..\Control\OWLFrontController.cpp,118) -false
              [DEBUG] Fri Nov 02 11:47:23 2012 [.792] (..\Control\OWLFrontController.cpp,118) -true
              [DEBUG] Fri Nov 02 11:47:23 2012 [.792] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:23 2012 [.792] (..\Control\InstallExtensionCommand.cpp,407) -CInstallExCommand::parseArguments(): +++
              [DEBUG] Fri Nov 02 11:47:23 2012 [.792] (..\Control\InstallExtensionCommand.cpp,461) -CInstallExCommand::parseArguments(): isRollback false
              [DEBUG] Fri Nov 02 11:47:23 2012 [.792] (..\Control\InstallExtensionCommand.cpp,49) -CInstallExCommand::execute(): non-rollback session, reset g_exitCode
              [DEBUG] Fri Nov 02 11:47:23 2012 [.793] (..\MacrExtensionManager.cpp,3819) -CMacrExtensionManager::InstallExtension: isRollback false
              [DEBUG] Fri Nov 02 11:47:23 2012 [.793] (..\Control\OWLExtensionMgrUI.cpp,238) -Show progress
              [DEBUG] Fri Nov 02 11:47:23 2012 [.793] (..\Control\OWLExtensionMgrUI.cpp,244) -SetProgressCount:20
              [DEBUG] Fri Nov 02 11:47:23 2012 [.793] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:23 2012 [.793] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:23 2012 [.793] (..\Control\OWLFrontController.cpp,424) -70
              [DEBUG] Fri Nov 02 11:47:23 2012 [.793] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:47:23 2012 [.793] (..\Control\OWLFrontController.cpp,424) -5
              [DEBUG] Fri Nov 02 11:47:23 2012 [.793] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:23 2012 [.965] (..\Control\OWLExtensionMgrUI.cpp,244) -SetProgressCount:16
              [DEBUG] Fri Nov 02 11:47:23 2012 [.965] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:23 2012 [.965] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:23 2012 [.965] (..\Control\OWLFrontController.cpp,424) -70
              [DEBUG] Fri Nov 02 11:47:23 2012 [.965] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:47:23 2012 [.965] (..\Control\OWLFrontController.cpp,424) -6
              [DEBUG] Fri Nov 02 11:47:23 2012 [.965] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:23 2012 [.978] (..\Control\OWLExtensionMgrUI.cpp,446) -to generate mxi file for dir: C:\Users\*****\AppData\Local\Temp\SCZ9AEB.tmp\CSXS\manifest.xml and zxp name is From Oz to Kansas.zxp
              [DEBUG] Fri Nov 02 11:47:23 2012 [.978] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:23 2012 [.978] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:23 2012 [.978] (..\Control\OWLFrontController.cpp,424) -70
              [DEBUG] Fri Nov 02 11:47:23 2012 [.978] (..\Control\OWLFrontController.cpp,424) -101
              [DEBUG] Fri Nov 02 11:47:23 2012 [.978] (..\Control\OWLFrontController.cpp,424) -C:\Users\*****\AppData\Local\Temp\SCZ9AEB.tmp\CSXS\manifest.xml
              [DEBUG] Fri Nov 02 11:47:23 2012 [.978] (..\Control\OWLFrontController.cpp,424) -From Oz to Kansas.zxp
              [DEBUG] Fri Nov 02 11:47:23 2012 [.978] (..\Control\OWLFrontController.cpp,424) -C:\Users\*****\AppData\Local\Temp\From Oz to Kansas_mxi\From Oz to Kansas.mxi
              [DEBUG] Fri Nov 02 11:47:23 2012 [.978] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:24 2012 [.1] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:24 2012 [.1] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalRespondFromAIR
              [DEBUG] Fri Nov 02 11:47:24 2012 [.1] (..\Control\OWLFrontController.cpp,118) -70
              [DEBUG] Fri Nov 02 11:47:24 2012 [.1] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:47:24 2012 [.1] (..\Control\OWLFrontController.cpp,118) -com.configurator.extension.zxp
              [DEBUG] Fri Nov 02 11:47:24 2012 [.1] (..\Control\OWLFrontController.cpp,118) -C:\Users\*****\AppData\Local\Temp\From Oz to Kansas_mxi\com.configurator.extension.mxi
              [DEBUG] Fri Nov 02 11:47:24 2012 [.1] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:24 2012 [.1] (..\Control\OWLFrontController.cpp,165) -RequestId is70. It is a request used to unlock OK/Cancel
              [INFO] Fri Nov 02 11:47:24 2012 [.1] (..\MacrExtensionManager.cpp,13368) -mxi file name has been changed to ExtensionBundleId.
              [DEBUG] Fri Nov 02 11:47:24 2012 [.8] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:24 2012 [.8] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:24 2012 [.8] (..\Control\OWLFrontController.cpp,424) -70
              [DEBUG] Fri Nov 02 11:47:24 2012 [.8] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:47:24 2012 [.8] (..\Control\OWLFrontController.cpp,424) -12
              [DEBUG] Fri Nov 02 11:47:24 2012 [.8] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:24 2012 [.9] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:24 2012 [.9] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:24 2012 [.9] (..\Control\OWLFrontController.cpp,424) -70
              [DEBUG] Fri Nov 02 11:47:24 2012 [.9] (..\Control\OWLFrontController.cpp,424) -You are about to install the 'com.configurator.extension' extension. Please read the following carefully before you continue.
              [DEBUG] Fri Nov 02 11:47:24 2012 [.10] (..\Control\OWLFrontController.cpp,424) -
              [DEBUG] Fri Nov 02 11:47:24 2012 [.10] (..\Control\OWLFrontController.cpp,424) -"Configurator-Panel" is a customized panel for Photoshop CS6 developed by Configurator 3. Once this extension is installed, "Configurator-Panel" can be launched from Window > Extension > From Oz to Kansas. Select, Window > Extension > to close the From Oz to Kansas panel.
              [DEBUG] Fri Nov 02 11:47:24 2012 [.10] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:25 2012 [.740] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:25 2012 [.740] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalRespondFromAIR
              [DEBUG] Fri Nov 02 11:47:25 2012 [.740] (..\Control\OWLFrontController.cpp,118) -70
              [DEBUG] Fri Nov 02 11:47:25 2012 [.740] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:47:25 2012 [.740] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:25 2012 [.740] (..\Control\OWLFrontController.cpp,165) -RequestId is70. It is a request used to unlock OK/Cancel
              [DEBUG] Fri Nov 02 11:47:25 2012 [.741] (..\Control\HeadLightsMgr.cpp,1104) -LogEvent: cat is ExtensionManagement, subCat is InstallType, eventName is PerMachineExtensionInstalledPerMachine
              [DEBUG] Fri Nov 02 11:47:25 2012 [.741] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:25 2012 [.741] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:25 2012 [.741] (..\Control\OWLFrontController.cpp,424) -70
              [DEBUG] Fri Nov 02 11:47:25 2012 [.741] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:47:25 2012 [.741] (..\Control\OWLFrontController.cpp,424) -18
              [DEBUG] Fri Nov 02 11:47:25 2012 [.742] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:25 2012 [.754] (..\Control\OWLExtensionMgrUI.cpp,623) -to request air to validation:  1; com.configurator.extension; com.configurator.extension; com.configurator.extension; com.configurator.extension; C:\Users\*****\AppData\Local\Temp\SCZ9AEB.tmp; 1.0.0;
              [DEBUG] Fri Nov 02 11:47:25 2012 [.754] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:25 2012 [.755] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:25 2012 [.755] (..\Control\OWLFrontController.cpp,424) -70
              [DEBUG] Fri Nov 02 11:47:25 2012 [.755] (..\Control\OWLFrontController.cpp,424) -102
              [DEBUG] Fri Nov 02 11:47:25 2012 [.755] (..\Control\OWLFrontController.cpp,424) -com.configurator.extension
              [DEBUG] Fri Nov 02 11:47:25 2012 [.755] (..\Control\OWLFrontController.cpp,424) -C:\Users\*****\AppData\Local\Temp\SCZ9AEB.tmp
              [DEBUG] Fri Nov 02 11:47:25 2012 [.755] (..\Control\OWLFrontController.cpp,424) -1.0.0
              [DEBUG] Fri Nov 02 11:47:25 2012 [.755] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:26 2012 [.321] (..\Control\HeadLightsMgr.cpp,1104) -LogEvent: cat is ExtensionManagement, subCat is Install, eventName is PopUpSignatureDialogByInstallExtension
              [DEBUG] Fri Nov 02 11:47:26 2012 [.323] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:26 2012 [.323] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:26 2012 [.323] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:26 2012 [.323] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:28 2012 [.124] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:28 2012 [.124] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalRespondFromAIR
              [DEBUG] Fri Nov 02 11:47:28 2012 [.124] (..\Control\OWLFrontController.cpp,118) -70
              [DEBUG] Fri Nov 02 11:47:28 2012 [.124] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:47:28 2012 [.124] (..\Control\OWLFrontController.cpp,118) -com.configurator.extension
              [DEBUG] Fri Nov 02 11:47:28 2012 [.124] (..\Control\OWLFrontController.cpp,118) -1
              [DEBUG] Fri Nov 02 11:47:28 2012 [.124] (..\Control\OWLFrontController.cpp,118) -2
              [DEBUG] Fri Nov 02 11:47:28 2012 [.124] (..\Control\OWLFrontController.cpp,118) -Sean Dyroff #B Vincent Versace
              [DEBUG] Fri Nov 02 11:47:28 2012 [.124] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:28 2012 [.124] (..\Control\OWLFrontController.cpp,165) -RequestId is70. It is a request used to unlock OK/Cancel
              [DEBUG] Fri Nov 02 11:47:28 2012 [.125] (..\Control\OWLExtensionMgrUI.cpp,662) -com.configurator.extension
              [DEBUG] Fri Nov 02 11:47:28 2012 [.125] (..\Control\OWLExtensionMgrUI.cpp,662) -1
              [DEBUG] Fri Nov 02 11:47:28 2012 [.125] (..\Control\OWLExtensionMgrUI.cpp,662) -2
              [DEBUG] Fri Nov 02 11:47:28 2012 [.125] (..\Control\OWLExtensionMgrUI.cpp,662) -Sean Dyroff & Vincent Versace
              [DEBUG] Fri Nov 02 11:47:28 2012 [.125] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:28 2012 [.125] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:28 2012 [.125] (..\Control\OWLFrontController.cpp,424) -70
              [DEBUG] Fri Nov 02 11:47:28 2012 [.125] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:47:28 2012 [.125] (..\Control\OWLFrontController.cpp,424) -25
              [DEBUG] Fri Nov 02 11:47:28 2012 [.125] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:28 2012 [.171] (..\Control\OWLExtensionMgrUI.cpp,301) -Hide progress
              [DEBUG] Fri Nov 02 11:47:28 2012 [.171] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:28 2012 [.171] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:28 2012 [.171] (..\Control\OWLFrontController.cpp,424) -70
              [DEBUG] Fri Nov 02 11:47:28 2012 [.171] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:47:28 2012 [.172] (..\Control\OWLFrontController.cpp,424) -100
              [DEBUG] Fri Nov 02 11:47:28 2012 [.172] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:28 2012 [.349] (..\Control\OWLExtensionMgrUI.cpp,301) -Hide progress
              [DEBUG] Fri Nov 02 11:47:28 2012 [.349] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:28 2012 [.349] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:28 2012 [.349] (..\Control\OWLFrontController.cpp,424) -70
              [DEBUG] Fri Nov 02 11:47:28 2012 [.349] (..\Control\OWLFrontController.cpp,424) -9
              [DEBUG] Fri Nov 02 11:47:28 2012 [.349] (..\Control\OWLFrontController.cpp,424) -100
              [DEBUG] Fri Nov 02 11:47:28 2012 [.349] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:28 2012 [.350] (..\MacrExtensionManager.cpp,7318) -CMacrExtensionManager::InstallExtension(): non-rollback session, reset g_exitCode
              [DEBUG] Fri Nov 02 11:47:28 2012 [.354] (..\DBWrapper.cpp,4328) -HandleSetForInstallExtension:+++ extId 7
              [DEBUG] Fri Nov 02 11:47:28 2012 [.355] (..\DBWrapper.cpp,4357) -HandleSetForInstallExtension: extId 7, extName com.configurator.extension, prodId 1
              [DEBUG] Fri Nov 02 11:47:28 2012 [.364] (..\Control\OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
              [DEBUG] Fri Nov 02 11:47:28 2012 [.364] (..\Control\OWLFrontController.cpp,407) -Method Name: airCallBack
              [DEBUG] Fri Nov 02 11:47:28 2012 [.364] (..\Control\OWLFrontController.cpp,424) -70
              [DEBUG] Fri Nov 02 11:47:28 2012 [.364] (..\Control\OWLFrontController.cpp,424) -0
              [DEBUG] Fri Nov 02 11:47:28 2012 [.364] (..\Control\OWLFrontController.cpp,424) -Photoshop CS6 64
              [DEBUG] Fri Nov 02 11:47:28 2012 [.365] (..\Control\OWLFrontController.cpp,424) -com.configurator.extension.mxi
              [DEBUG] Fri Nov 02 11:47:28 2012 [.365] (..\Control\OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
              [DEBUG] Fri Nov 02 11:47:28 2012 [.385] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:28 2012 [.386] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
              [DEBUG] Fri Nov 02 11:47:28 2012 [.386] (..\Control\OWLFrontController.cpp,118) -75
              [DEBUG] Fri Nov 02 11:47:28 2012 [.386] (..\Control\OWLFrontController.cpp,118) -install
              [DEBUG] Fri Nov 02 11:47:28 2012 [.386] (..\Control\OWLFrontController.cpp,118) -0
              [DEBUG] Fri Nov 02 11:47:28 2012 [.386] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:29 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:29 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:29 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:29 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:32 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:32 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:32 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:32 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:35 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:35 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:35 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:35 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:38 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:38 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:38 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:38 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:41 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:41 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:41 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:41 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:44 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:44 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:44 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:44 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:47 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:47 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:47 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:47 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:50 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:50 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:50 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:50 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:53 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:53 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:53 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:53 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:56 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:56 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:56 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:56 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:47:59 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:47:59 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:59 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:47:59 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:02 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:02 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:02 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:02 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:05 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:05 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:05 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:05 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:08 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:08 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:08 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:08 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:11 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:11 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:11 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:11 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:14 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:14 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:14 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:14 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:17 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:17 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:17 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:17 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:20 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:20 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:20 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:20 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:23 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:23 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:23 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:23 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:26 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:26 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:26 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:26 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:29 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:29 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:29 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:29 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:32 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:32 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:32 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:32 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:35 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:35 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:35 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:35 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:38 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:38 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:38 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:38 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:41 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:41 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:41 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:41 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:44 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:44 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:44 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:44 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:47 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:47 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:47 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:47 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:50 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:50 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:50 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:50 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:53 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:53 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:53 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:53 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:56 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:56 2012 [.324] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:56 2012 [.324] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:56 2012 [.324] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:48:59 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:48:59 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:59 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:48:59 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:02 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:02 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:02 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:02 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:05 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:05 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:05 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:05 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:08 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:08 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:08 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:08 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:11 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:11 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:11 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:11 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:14 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:14 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:14 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:14 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:17 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:17 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:17 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:17 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:20 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:20 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:20 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:20 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:23 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:23 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:23 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:23 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:26 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:26 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:26 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:26 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:29 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:29 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:29 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:29 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:32 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:32 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:32 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:32 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:35 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:35 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:35 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:35 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:38 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:38 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:38 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:38 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:41 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:41 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:41 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:41 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:44 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:44 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:44 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:44 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:47 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:47 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:47 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:47 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:50 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:50 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:50 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:50 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:53 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:53 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:53 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:53 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:56 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:56 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:56 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:56 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:49:59 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:49:59 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:59 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:49:59 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:02 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:02 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:02 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:02 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:05 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:05 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:05 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:05 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:08 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:08 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:08 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:08 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:11 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:11 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:11 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:11 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:14 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:14 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:14 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:14 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:17 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:17 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:17 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:17 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:20 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:20 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:20 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:20 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:23 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:23 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:23 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:23 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:26 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:26 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:26 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:26 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:29 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:29 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:29 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:29 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:32 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:32 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:32 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:32 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:35 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:35 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:35 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:35 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:38 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:38 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:38 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:38 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:41 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:41 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:41 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:41 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:44 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:44 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:44 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:44 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:47 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:47 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:47 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:47 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:50 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:50 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:50 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:50 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:53 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:53 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:53 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:53 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:56 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:56 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:56 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:56 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:50:59 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:50:59 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:59 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:50:59 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:02 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:02 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:02 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:02 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:05 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:05 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:05 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:05 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:08 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:08 2012 [.324] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:08 2012 [.324] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:08 2012 [.324] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:11 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:11 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:11 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:11 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:14 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:14 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:14 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:14 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:17 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:17 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:17 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:17 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:20 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:20 2012 [.324] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:20 2012 [.324] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:20 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:23 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:23 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:23 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:23 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:26 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:26 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:26 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:26 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:29 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:29 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:29 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:29 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:32 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:32 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:32 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:32 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:35 2012 [.329] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:35 2012 [.330] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:35 2012 [.330] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:35 2012 [.330] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:38 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:38 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:38 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:38 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:41 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:41 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:41 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:41 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:44 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:44 2012 [.324] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:44 2012 [.324] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:44 2012 [.324] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:47 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:47 2012 [.324] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:47 2012 [.324] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:47 2012 [.324] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:50 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:50 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:50 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:50 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:53 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:53 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:53 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:53 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:56 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:56 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:56 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:56 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:51:59 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:51:59 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:59 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:51:59 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:02 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:02 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:02 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:02 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:05 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:05 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:05 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:05 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:08 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:08 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:08 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:08 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:11 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:11 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:11 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:11 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:14 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:14 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:14 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:14 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:17 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:17 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:17 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:17 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:20 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:20 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:20 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:20 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:23 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:23 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:23 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:23 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:26 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:26 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:26 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:26 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:29 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:29 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:29 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:29 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:32 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:32 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:32 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:32 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:35 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:35 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:35 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:35 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:38 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:38 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:38 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:38 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:41 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:41 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:41 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:41 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:44 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:44 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:44 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:44 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:47 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:47 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:47 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:47 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:50 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:50 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:50 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:50 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:53 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:53 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:53 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:53 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:56 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:56 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:56 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:56 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:52:59 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:52:59 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:59 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:52:59 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:02 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:02 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:02 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:02 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:05 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:05 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:05 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:05 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:08 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:08 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:08 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:08 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:11 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:11 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:11 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:11 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:14 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:14 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:14 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:14 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:17 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:17 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:17 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:17 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:20 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:20 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:20 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:20 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:23 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:23 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:23 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:23 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:26 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:26 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:26 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:26 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:29 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:29 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:29 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:29 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:32 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:32 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:32 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:32 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:35 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:35 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:35 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:35 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:38 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:38 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:38 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:38 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:41 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:41 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:41 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:41 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:44 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:44 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:44 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:44 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:47 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:47 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:47 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:47 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:50 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:50 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:50 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:50 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:53 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:53 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:53 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:53 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:56 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:56 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:56 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:56 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:53:59 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:53:59 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:59 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:53:59 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:02 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:02 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:02 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:02 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:05 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:05 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:05 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:05 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:08 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:08 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:08 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:08 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:11 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:11 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:11 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:11 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:14 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:14 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:14 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:14 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:17 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:17 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:17 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:17 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:20 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:20 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:20 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:20 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:23 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:23 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:23 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:23 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:26 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:26 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:26 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:26 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:29 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:29 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:29 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:29 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:32 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:32 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:32 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:32 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:35 2012 [.330] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:35 2012 [.330] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:35 2012 [.330] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:35 2012 [.330] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:38 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:38 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:38 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:38 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:41 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:41 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:41 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:41 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:44 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:44 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:44 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:44 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:47 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:47 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:47 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:47 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:50 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:50 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:50 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:50 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:53 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:53 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:53 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:53 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:56 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:56 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:56 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:56 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:54:59 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:54:59 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:59 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:54:59 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:02 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:02 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:02 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:02 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:05 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:05 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:05 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:05 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:08 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:08 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:08 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:08 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:11 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:11 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:11 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:11 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:14 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:14 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:14 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:14 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:17 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:17 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:17 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:17 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:20 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:20 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:20 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:20 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:23 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:23 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:23 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:23 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:26 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:26 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:26 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:26 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:29 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:29 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:29 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:29 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:32 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:32 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:32 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:32 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:35 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:35 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:35 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:35 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:38 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:38 2012 [.324] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:38 2012 [.324] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:38 2012 [.324] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:41 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:41 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:41 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:41 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:44 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:44 2012 [.324] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:44 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:44 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:47 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:47 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:47 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:47 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:50 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:50 2012 [.324] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:50 2012 [.324] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:50 2012 [.324] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:53 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:53 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:53 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:53 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:56 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:56 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:56 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:56 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:55:59 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:55:59 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:59 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:55:59 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:02 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:02 2012 [.324] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:02 2012 [.324] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:02 2012 [.324] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:05 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:05 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:05 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:05 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:08 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:08 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:08 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:08 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:11 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:11 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:11 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:11 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:14 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:14 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:14 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:14 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:17 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:17 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:17 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:17 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:20 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:20 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:20 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:20 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:23 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:23 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:23 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:23 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:26 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:26 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:26 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:26 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:29 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:29 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:29 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:29 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:32 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:32 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:32 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:32 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:35 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:35 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:35 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:35 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:38 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:38 2012 [.324] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:38 2012 [.324] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:38 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:41 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:41 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:41 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:41 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:44 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:44 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:44 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:44 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:47 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:47 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:47 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:47 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:50 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:50 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:50 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:50 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:53 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:53 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:53 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:53 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:56 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:56 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:56 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:56 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:56:59 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:56:59 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:59 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:56:59 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:02 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:02 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:02 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:02 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:05 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:05 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:05 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:05 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:08 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:08 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:08 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:08 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:11 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:11 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:11 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:11 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:14 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:14 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:14 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:14 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:17 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:17 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:17 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:17 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:20 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:20 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:20 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:20 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:23 2012 [.324] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:23 2012 [.324] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:23 2012 [.324] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:23 2012 [.324] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:26 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:26 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:26 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:26 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:29 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:29 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:29 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:29 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:32 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:32 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:32 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:32 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:35 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:35 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:35 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:35 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:38 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:38 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:38 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:38 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:41 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:41 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:41 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:41 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:44 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:44 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:44 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:44 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:47 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:47 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:47 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:47 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:50 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:50 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:50 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:50 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:53 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:53 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:53 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:53 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:56 2012 [.326] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:56 2012 [.326] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:56 2012 [.326] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:56 2012 [.326] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:57:59 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:57:59 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:59 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:57:59 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              [DEBUG] Fri Nov 02 11:58:02 2012 [.325] (..\Control\OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
              [DEBUG] Fri Nov 02 11:58:02 2012 [.325] (..\Control\OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:58:02 2012 [.325] (..\Control\OWLFrontController.cpp,118) -pumpBridgeTalkMessage
              [DEBUG] Fri Nov 02 11:58:02 2012 [.325] (..\Control\OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
              • 4. Re: Extensions Aren't Installed in PS CS6
                davidl11 Level 1
                Hi Carl,
                Unfortunately in the Description for all 3 of the extensions, the authors say to go to Window > Extension > 'name of panel' to access the panels.  And when I do that, I do not find the extensions listed.
                Best,
                David
                • 5. Re: Extensions Aren't Installed in PS CS6
                  Xiaoyi Tong Adobe Employee
                  Hi Davidl11,
                  Please check the folder of C:\Program Files (x86)\Common Files\Adobe\CS6ServiceManager\extensions. Subfolders( "com.configurator.extension", "FromOztoKansasPowerTools" and "EasyDodgeFullCS6" ) should be created for your extensions( In your case, I think it should be okay because you didn't get any error msg in extension installation ).
                  All these extensions set the max version of the Photoshop to "13.0", which means they will NOT be loaded by Photoshop whose version is greater than "13.0", and the version of your Photoshop is "13.0.1"( You might have updated your photoshop after installation ). That is why you could not see them in Photoshop panel. If you install these extensions on another device, which Photoshop "13.0" was installed, they would be showed in the panel.
                  Generally speaking, the developers of extension should be careful when they are going to set the max-version of the products.
                  Xiaoyi
                  • 6. Re: Extensions Aren't Installed in PS CS6
                    davidl11 Level 1
                    Hi Xiaoyi,
                    Xiaoyi Tong wrote:
                    Hi Davidl11,
                    Xiaoyi
                    I have been traveling on business, and am just now getting back to this problem.  Based on what you said and given that I don't have another device on which to install CS6, I think my options are to re-install CS5 or perhaps write to the developers and see if they can or will revise the extensions to allow usage in versions of CS6 beyond version 13.0.  Are there any other options?
                    Thanks for your help.
                    Best,
                    David
                    • 7. Re: Extensions Aren't Installed in PS CS6
                      Hi David,
                      Re-installing "CS5" cannot help you because your extensions are for "Photoshop CS6" only. The reason you got trouble is you have installed a patch of "Photoshop CS6". So the version of Photoshop was changed from "13.0" to "13.0.1", and then your extensions could not be loaded.
                      You have 2 options:
                      1. uninstall your Photoshop, and install it again( version "13.0" ), and DON'T install any patch for Photoshop.
                      2. Send an email to the developers of your extensions and ask them to update the extensions.
                      Xiaoyi
                      • 8. Re: Extensions Aren't Installed in PS CS6
                        davidl11 Level 1
                        Xiaoyi Tong wrote:
                        You have 2 options:
                        Xiaoyi
                        I have written to both developers.  One had already updated his extension, which I have now downloaded.
                        Thanks for your help and, especially, in explaining the problem.
                        Best,
                        David
