14 Replies Latest reply on Jul 7, 2016 6:41 AM by davidhmorgan
    [Req.] script for updating links in Indesign using spotlight
    Eric Lipton Ice
      hi,
      i've got a challange, can somebody please help me?
      I'm a graphic designer from holland and I work with lots of Indesign documents
      whose links are missing because they are moved, so they are somewhere on our server.
      I have several scripts to relink missing links but they are slow,
      because they search every directory and every subdirectory. This takes a while.
      The search engine from apple, spotlight, is much much faster.
      So I think i have this brilliant idea, i thought of the following:
      I select one missing link in the linkpanel in Indesign.
      Then I start the script.
      The path of the missing link is copied and trimmed to just the name of the file
      The filename is then copied to the clipboard.
      The script then opens the dialog window to relink the missing link.
      There the name of the picture is pasted in the spotlight search engine.
      There the script stops.
      Click on the correct file (if there are more choises) and the relink is made.
      I think this way of relinking can be much faster.
      And you can also work with pre-defined clever windows (to limit the results), for example:
      - one witch only shows jpg
      - one witch only shows tiff
      - one witch only shows pdf
      I know a tiny little bit of scripting, but this one I cant figure out yet.
      Can somebody give me a help please?
      Kind regards, Eric
      ps. I still work in CS4
        • 1. Re: [Req.] script for updating links in Indesign using spotlight
          Muppet Mark Level 5
          If you want spotlight searching in script… You should do man mdfind in the terminal app… This will show you the scriptable options for the command… You would need to call the shell from AppleScript. Your subject would probably be better answered at…
          http://macscripter.net/viewforum.php?id=2
          Where more forum users are familiar with both AppleScript and shell… Not sure you will achive the kind of user interaction you envisage and be fast… Drop the clipboard idea it's not needed… Just a bit of text…
          • 2. Re: [Req.] script for updating links in Indesign using spotlight
            Eric Lipton Ice Level 1
            Muppet Mark,
            Thank you very much for your reply but i don't think that you quite understand my request.
            I don't want to use spotlight in a script. I want to make use from spotlight whitch is already build in in the standard dialog window from InDesign, the window whitch appears when you click: 'relink the image'.
            All the script has to do is copy te name of the missing link and then paste the name of the image in that dialog in the right upper corner, the spotlight search.
            That's all.
            • 3. Re: [Req.] script for updating links in Indesign using spotlight
              -hans- Level 4
              try this,
              could just test it with ID CS3 and Mac OS 10.4.11
              --startpoint here is a selected graphicframe (which of course should inlude the missing link)
              set myFolder to choose folder with prompt "Where to search for the missing link?" --select a mounted volume, folder ...
              set tid to AppleScript's text item delimiters
              set AppleScript's text item delimiters to ":"
              tell application "Adobe InDesign CS3"
                                 set myGraphicFilePath to (file path of (item link of (item 1 of all graphics of (item 1 of selection))) as text)
              end tell
              set myGraphicName to text item -1 of myGraphicFilePath
              set myGraphicFilePath to quoted form of POSIX path of myGraphicFilePath
              set AppleScript's text item delimiters to return
              set PathToAllFiles to every text item of (do shell script "mdfind -onlyin '" & quoted form of POSIX path of myFolder & "'" & space & " -name '" & myGraphicName & "'")
              set PathToAllFiles to my cleanList(myGraphicName, PathToAllFiles)
              repeat with i from 1 to count of PathToAllFiles
                                 set theItem to (item i of PathToAllFiles)
                                 if button returned of (display dialog theItem with title "Relink this file?" buttons {"OK", "Cancel", "Go on"}) is "OK" then
        relink (item link of (item 1 of all graphics of (item 1 of selection))) to POSIX file theItem
                                                          end tell
                                 end if
              end repeat
              set AppleScript's text item delimiters to tid
              on cleanList(fileName, listOfFilePaths)
                                 set myCleanList to {}
                                 set AppleScript's text item delimiters to "/"
                                 repeat with p from 1 to count of listOfFilePaths
                                                          set aName to (text item -1 of (item p of listOfFilePaths))
                                                          if aName is equal to fileName then set end of myCleanList to (item p of listOfFilePaths)
                                 end repeat
                                 return myCleanList
              end cleanList
              Hans-Gerd Classen
              • 4. Re: [Req.] script for updating links in Indesign using spotlight
                Eric Ice Lipton
                Thank you guys for your response,
                the last script was interesting, but it made my indesign to quit, 2 times in a row. Don't know why.
                (yes I changed CS3 to CS4)
                After some thinking, I came up with the following solution:
                Set in the prefs, the keyshortcuts from InDesing these keystrokes:
                - ga naar koppeling "shift §" -  (english: go to link?)
                - opnieuw koppelen "commando §" - (english: re-link?)
                - volledig pad kopiëren "§" - (english: copy path of link?)
                After this, this is the script I run:
                activate application "Adobe InDesign CS4"
                tell application "System Events"
                    keystroke "§" using shift down
                    keystroke "§"
                end tell
                delay 0.5
                set LinkPath to do shell script "pbpaste"
                set AppleScript's text item delimiters to {"/"}
                set delimitedList to last text item of LinkPath
                set the clipboard to delimitedList
                    keystroke "§" using command down
                    keystroke "f" using command down
                    keystroke "v" using command down
                    keystroke "2" using command down
                end tell
                This works for me! :-)
                • 5. Re: [Req.] script for updating links in Indesign using spotlight
                  -hans- Level 4
                  Fine that you've got a solution and sorry for quitting yout ID. Should have tested it more then once, it's been a quite old script and I just copy and pasted it ...
                  just rewrote my old script a bit to run  on ID CS 5.5 OSX 10.7.4
                  Should run over missing links of active Document, uses mdfind to find files with simular names as missing link name in the given directory, optionally reveals the file in finder  and shows / selects currMissingLink in ID-file. if "ok" relinks the missing link (without quitting ID ;-) I hope).
                  global myFolder
                  tell application "Adobe InDesign CS5.5"
                      set currDoc to active document
                      set theMissingLinks to every link of currDoc whose status is link missing
                      if theMissingLinks is not {} then set myFolder to choose folder with prompt "Where to search for the missing links?" --select a mounted volume, folder ...
                      repeat with missingLink from 1 to count of theMissingLinks
                          set currMissingLink to item missingLink of theMissingLinks
                          set currFileName to name of currMissingLink
                          set theResultList to my mdFind(currFileName)
                          if theResultList is not {} then
                              repeat with i from 1 to count of theResultList
                                  set theItem to (item i of theResultList)
                                  set currDialog to display dialog theItem with title "Relink this file?" buttons {"OK", "Cancel", "Show in Finder first"}
                                  if button returned of currDialog is "OK" then
                                      try
                                          relink currMissingLink to POSIX file theItem
                                      on error e
                                          display dialog e
                                      end try
                                  else if button returned of currDialog is "Show in Finder first" then
                  show  currMissingLink --select the missing link in ID
                                      my revealInFinder(theItem) --show the found file in finder
                                      activate
                                      set currDialog to display dialog theItem with title "Please switch to Finder to see the file. Relink the file shown in Finderwindow?" buttons {"OK", "Cancel", "Continue searching"}
                                          try
                                          on error e
                                              display dialog e
                                          end try
                                      end if
                                  end if
                              end repeat
                          end if
                      end repeat
                  end tell
                  on mdFind(currFileName)
                      set PathToAllFiles to every text item of (do shell script "mdfind -onlyin '" & quoted form of POSIX path of myFolder & "'" & space & " -name '" & currFileName & "'")
                      set PathToAllFiles to my cleanList(currFileName, PathToAllFiles)
                  end mdFind
                      end repeat
                      return myCleanList
                  end cleanList
                  on revealInFinder(somePosixPath)
                      tell application "Finder"
                          set myAlias to (POSIX file somePosixPath) as alias
                          activate
                          reveal myAlias
                      end tell
                  end revealInFinder
                  Hope it'll run
                  Hans-Gerd Claßen
                  • 6. Re: [Req.] script for updating links in Indesign using spotlight
                    Eric Ice Lipton Level 1
                    Thanx  for your reply and the trouble you went thru of rewriting the script.
                    Just tested it twice and it works like a charm!
                    Thought I ought to let you know...
                    Thanx again
                    • 8. Re: [Req.] script for updating links in Indesign using spotlight
                      Muppet Mark Level 5
                      "Thought I ought to let you know..." You can do that by making the subject answered… and giving the deserved points… were all after a free mug…
                      • 9. Re: [Req.] script for updating links in Indesign using spotlight
                        no problem, i have to do that tomorrow, from my work.
                        For some reason, when I log in at home with the same login information, it uses my first attempt account.
                        Look at the name, from my work its 'Lipton Ice' and from at home its 'Ice Lipton'.
                        I'll try tommorow, see if i can find it, i'm kinda new here..., ok?
                        Grtz, Eric
                        • 10. Re: [Req.] script for updating links in Indesign using spotlight
                          Sirbaxx Level 1
                          Whenever I try to run this script I get the following error:
                          error "Unknown option -
                          Usage: mdfind [-live] [-count] [-onlyin directory] [-name fileName | -s smartFolderName | query]
                          list the files matching the query
                          query can be an expression or a sequence of words
                                    -live             Query should stay active
                                    -count            Query only reports matching items count
                                    -onlyin <dir>     Search only within given directory
                                    -name <name>      Search on file name only
                                    -s <name>         Show contents of smart folder <name>
                                    -0                Use NUL (``\\0'') as a path separator, for use with xargs -0.
                          example:  mdfind image
                          example:  mdfind -onlyin ~ image
                          example:  mdfind -name stdlib.h
                          example:  mdfind \"kMDItemAuthor == '*MyFavoriteAuthor*'\"
                          example:  mdfind -live MyFavoriteAuthor
                          " number 1
                          I've pasted your full code into the Applescript editor and I'm trying it to run in InDesign CS5.5
                          I've tried modifying the script here and there, but can't seem to get it to work. (I have not made myself familiar yet with running shellscripts within Applescript.)
                          Any chance you could help me with this?
                          • 11. Re: [Req.] script for updating links in Indesign using spotlight
                            -hans- Level 4
                            it's been built for lion, ID 5.5. Mdfind-command seems to be ok. perhaps it's a copy paste problem. try the link https://dl.dropboxusercontent.com/u/11350320/mdFind_Relink.scpt.zip
                            • 12. Re: [Req.] script for updating links in Indesign using spotlight
                              Sirbaxx Level 1
                              Hi Hans,
                              thanks for the quick reply.
                              I'm still getting the same error. I am working on Mountain Lion (10.8.4), so maybe that's why I get the error?
                              --edit
                              It seems that I only get the error when I point the script the certain folders.
                              The folders that give the error are indexed by spotlight, but still give the error.
                              I'll try to rebuild my spotlight index and see if that will work.
                              • 13. Re: [Req.] script for updating links in Indesign using spotlight
                                ollesundin
                                This would be fantastic if it would work. Any news?
                                • 14. Re: [Req.] script for updating links in Indesign using spotlight
                                  davidhmorgan Level 1
                                  Working in a graphic design studio I had the same problem. We often supply collected files to other designers who return the Indesign documents updated for us to use but the images are still linked to the collected folder. This is what prompted me to write this AppleScript so that I could relink them back to our master images libraries.
                                  Indesign Image Relinker – Dr Scripto
                                  The script asks you to point it to the top level of a directory and it searches every subdirectory within it for the images. You can ask it to relink selected images, missing images or all images to the chosen directory. The script uses a shell script to create an index of the directory structure which is super quick and it then searches every subfolder for the links and relinks them to the document.
