1 Reply Latest reply on Nov 5, 2012 4:04 AM by fotoviva
    Reusing hyperlinks in CS3
    fotoviva
      Hi, as the title says, I have a document in ID CS3 which needs hyperlinks made to various images/text. I can make them work fine but I cannot work out how to reuse some of the made hyperlinks for other elements.
      For instance, I make a hyperlink for an item on one page but then have another item that I want linking to the same url. If I select the item I can click on the already made hyperlink in the Hyperlinks tab but it doesn't assign it to the item. Double clicking doesn't work either.
      I'm sure there must be an easy way to do this but I can't figure it out. The one way I can do it is by going into the sub menu and selecting New Hyperlink which allows me to select from a previous hyperlink - but it gives it a new name so I will end up with loads of hyperlink names in my hyperlink tab - if you get my drift!
