5 Replies Latest reply on Nov 2, 2012 11:17 AM by Felix CL
    Match Frame screen not opening
    GeoffVane Level 1
      Learning to Edit properly.
      I've always used dragging to make every cut.
      This because I only create very short movies and AE is my main program.
      However, After 15 years it's time to learn NLE functions.
      EDIT: I made a mistake, the function I need isn't called Match Frame but Trim.
      I'll keep the old message below, until I solved all questions regarding the keyboard shortcuts.
      I want to:
      A. Select a clip on a track.
      B. Make it longer at the end using the keyboard.
      C. Prevent all other tracks from changing/moving in any way.
      I couldn't find that function using the keyboard.
      But after pressing F, I got the Match frame function.
      This worked fine and did exactly what I needed.
      1. It  now can't be activated again. Is the function bugged or am I doing it wrong?
      2. Can it be done using the keyboard?
        • 1. Re: Match Frame screen not opening
          Felix CL Level 3
          watch this great video by Todd on the subject and if you still have open questions about trimming, feel free to ask!
          dynamic-trimming-and-editing-with-the-keyboard
          besides, match frame is used to find the frame of a video or audio in the edit on your timeline on it's source clip.
          • 2. Re: Match Frame screen not opening
            GeoffVane Level 1
            Thanks for that great video. I learned a lot, very fast.
            Press T, drag some in the trim-interface and fix with keys or go to keys straight away:
            Very fast and quite easy!
            Never gonna tweak frames with dragging no more.
            • 3. Re: Match Frame screen not opening
              Felix CL Level 3
              that a boy!
              here's another proselytized (is that the right english word?) keyboard editor!
              only a few hundred thousand to go.
              - am glad, i pointed you in the right direction. wish you happy and fast editing.
              and keep smiling
              • 4. Re: Match Frame screen not opening
                GeoffVane Level 1
                Is there a key to select the clip under the indicator?
                Plan:
                - Put shot on timeline
                - Select shot (without having to let go of the indicator)
                - Find nice in point
                - Press ctrl K to make a cut at the in point
                - Press shift delete to ripple away the stuff before the in point and keep the timeline gap free at all times.
                • 5. Re: Match Frame screen not opening
                  Felix CL Level 3
                  not that i know of. no. just click on it.
                  faster alternative:
                  -doubleclick clip to load to source monitor
                  -play and hit "i" at desired in-point and "o" ate desired out-point
                  -overwrite (".") or insert(",") edit clip into sequence (into activated tracks) [at current indicator)
                  ...quicker
                  also there is no need for the clip to be selected to make the cut with Ctr.+K, the track has to be active.
                  you can also assign shortcuts to:
                  • Ripple Trim Next Edit to Playhead
                  • Ripple Trim Previous Edit to Playhead
                  - i have them at Shift+K
                     and AltGr(Ctrl+Alt)+K
                  i often use those when editing on the fly on the timeline...
                  if interested, read this:
                  http://helpx.adobe.com/premiere-pro/using/trimming-clips1.html
                  for a deeper info on how to trim, ripple edit, slip&slide, use trim mode etc.
                  also note, that until 5.5 (i think) it was called "current-time indicator" (CTI), they now call it "playhead", but i think not everywhere in the shortcuts and help-files, but they both mean the same thing...
