1 Reply Latest reply on Mar 5, 2008 10:22 AM by Shelady
    Create dynamic swf
    Hakan KIRIK Level 4
      is this possible:
      in Flex : create a movieclip and frames in it and then publish that movieclip as a new swf file?
      Everything with code, not using Flex or Flash interface.
        • 1. Re: Create dynamic swf
          Shelady
          The best way is to use Flash to make the frame by frame movie. Install Flex component for Flash and convert the movie to use in Flex.
          If you dont want to use Flex component for Flash, even then you can easily make .swf in Flash and load it in flex through .swf loader.
