5 Replies Latest reply on Nov 20, 2012 5:58 AM by Ken Krugh
    Plug-in actually used?
    Ken Krugh Level 1
      We have an InDesign file from someone else that I THINK might have been CS2 or earlier because when it opens in CS3 it requires a Save-As. We're also getting the Missing Plug-ins message "PowerMath.InDesignPlugin" for this particular file.
      We have an archival service to which our clients upload their files so we will be doing this frequently. We've saved this file as an inx, then pulled the inx back into InDesign, which removed the plug-in message after re-saving as an InD, but I'm concerned that if the plug-in was used somewhere that the content of the file may be wrong
      Is there a way to tell whether the plug-in was actually used in the file?
      Thank a bunch,
      Ken
        • 1. Re: Plug-in actually used?
          Apparently nobody knows for sure, or your question scrolled by too fast. My understanding is that with most plugins you either only need them to create the content or they throw an error when the file is opened that the plugin is missing when you need them to continue working. You probably should check with the PowerMath plugin vendor, though. Looks like http://www.phsoftware.com/pages/powermath_indesign.html
          • 2. Re: Plug-in actually used?
            Ken Krugh Level 1
            Thanks Peter. As you say, nobody seems to know for sure.
            PowerMath was very prompt in getting back to me, though didn't readily know the answer themselves. They mentioned something about exporting to text and searching for [& then &] but after pestering them too many times (I guess) I hadn't heard back from them about further details on that method. I'll post back if I do hear from them regarding that.
            We're PC based and have our "token" Macintosh onto which I loaded PowerMath. I then opened the file there and saved it as an INX into which, I was told by PowerMath, the PowerMath objects would be saved. Opening the INX back on the PC I no longer received the warning for the plug-in.
            I can only assume this means there were no PowerMath objects in the file.
            PowerMath did tell me that at one time if a PowerMath object was added to a file and later deleted the reference to the plug-in stayed in the InD file. I'm thinking this was the case here.
            So, unfortunately, I didn't really get an answer to my original main question about plug-ins. Maybe in an future rev. of InD we'll have something.
            Best,
            Ken
            • 3. Re: Plug-in actually used?
              It may also mean that you only need the plugin to CREATE the objects originally, but once in place they can be read by unencumbered versions. I think a lot of plugins work that way.
              • 4. Re: Plug-in actually used?
                Ken Krugh Level 1
                Yes, the gent at PowerMath wasn't sure whether I would see the equation or an empty box on a computer without PowerMath loaded.
                • 5. Re: Plug-in actually used?
                  Ken Krugh Level 1
                  Addendem: Didn't even need to save as an INX, simply saved from the Mac, with PowerMath loaded, to another InD file and opened on the PC without getting the message.
                  So, the lastest PowerMath plug-in seems to have removed the "false" reference to the plug-in.
