1. Re: Hi installed Photoshop Cs6 on my Vista os and crashes gives following error DEP (Data Execution Prev
Jeff A WrightNov 2, 2012 2:43 PM (in response to mr3x)
Did you receive any error messages during the install process? Was it installed previously but had stopped functioning? You may also want to review your installation logs for errors. You can find details on how to accomplish this at Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5-cs5.html.
2. Re: Hi installed Photoshop Cs6 on my Vista os and crashes gives following error DEP (Data Execution Prev
mr3x Nov 2, 2012 3:10 PM (in response to Jeff A Wright)no I did not receave any errors during instalation. Yes I installed it before but occured same problem so I unstalled and made a new isntall.
I found these in the end of the log hope these helps.
Please search the above error/warning string(s) to find when the error occurred.
These errors resulted in installer Exit Code mentioned below.
[ 4460] Fri Nov 02 19:54:12 2012 INFO
Exit Code: 0 - No error.
Please see specific errors and warnings for troubleshooting. For example, WARNING: DF029, DW024 ...
END - Installer Session
3. Re: Hi installed Photoshop Cs6 on my Vista os and crashes gives following error DEP (Data Execution Prev
Jeff A WrightNov 2, 2012 3:15 PM (in response to mr3x)
Moving this discussion to the Photoshop General Discussion. It sounds as if Mr3x is having a launch issue which was unable to be resolved by removing and reinstalling their software.
4. Re: Hi installed Photoshop Cs6 on my Vista os and crashes gives following error DEP (Data Execution Prev
mr3x Nov 2, 2012 4:22 PM (in response to Jeff A Wright)Thanks I have been looking at your other threads that are on the Adobes site and see that there are alot users with the same problem and no resultion.
5. Re: Hi installed Photoshop Cs6 on my Vista os and crashes gives following error DEP (Data Execution Prev
Chris CoxNov 2, 2012 4:22 PM (in response to mr3x)
Did you install the 13.0.1 update?
Do you have any third party plugins? Have you tried disabling them?
And can you get the crash details (the name of the crashing module is important to figure out what went wrong).
6. Re: Hi installed Photoshop Cs6 on my Vista os and crashes gives following error DEP (Data Execution Prev
mr3x Nov 3, 2012 3:05 AM (in response to Chris Cox)yes I finished intalling the update but it still crashes.
I have no plugins its a new install.
The only crash info that comes up by the windos is "DEP (Data Execution Prevention)"
reminding that´s Vista OS.
