4 Replies Latest reply on Nov 4, 2012 3:49 PM by usoldier18
    How to resolve Comparison between a value with static type string and a possible unrelated type numb
    usoldier18
      I am new to this and any help would be greatly appreciated, Im trying to display custom numbers for values of a Hslider.
      Here is my code so far:
                                       xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
        <fx:Declarations>
        <!-- Place non-visual elements (e.g., services, value objects) here -->
        </fx:Declarations>
        <fx:Script>
                          <![CDATA[
                                    import mx.events.SliderEvent;
                                    protected function ValueSlider_changeHandler(event:SliderEvent):void
                                    ValueLabel.text = String(ValueSlider.value);
                                              if(ValueSlider.value == "0")
                                              ValueLabel.text = "150";
                                              if(ValueSlider.value == "1")
                                              ValueLabel.text = "333";
                                              if(ValueSlider.value == "2")
                                              ValueLabel.text = "543";
                                              if(ValueSlider.value == "3")
                                              ValueLabel.text = "9342";
        </fx:Script>
                <s:Panel x="199" y="141" width="250" height="200">
                          <s:HSlider id="ValueSlider" x="74" y="68" maximum="5" minimum="0" stepSize="1"/>
                          <s:Label id="ValueLabel" x="109" y="38" text="Label"/>
        </s:Panel>
      </s:Application>
        • 1. Re: How to resolve Comparison between a value with static type string and a possible unrelated type numb
          pauland Level 4
          Why are you quoting the numbers?
          Shouldn't you have
          if(ValueSlider.value == 0)
          In general, it's bad practice not to use braces with conditionals and use indentation - it's easy to make a mistake without them:
          if(ValueSlider.value == 0){
          You can optimise this better, like this:
          const CONVERSION:Array = ["150","333","543","9342"];
          ValueLabel.text = CONVERSION[ValueSlider.value];
          It's also bad practice to name instances using a capital as the first letter - Class names start with capitals, instances with lower case, all caps for constants.
          Hope that helps.
          • 2. Re: How to resolve Comparison between a value with static type string and a possible unrelated type numb
            usoldier18 Level 1
            Thank you for your help, I was using quotes around the number from a suggestion on another forum. Now how to I display the result on valueLabel? "valueLabel.text"? {valueLable.text}, "const"?,
              <fx:Declarations>
              </fx:Declarations>
              <fx:Script>
                                <![CDATA[
                                                    valueLabel.text = CONVERSION[valueSlider.value];
              </fx:Script>
                                <s:HSlider id="valueSlider" x="78" y="69" maximum="3" minimum="0" stepSize="1" value="1"/>
              <s:Label id="valueLabel" x="109" y="38" text= "(valueLabel.text)"/>  <-----what do I place here?
              </s:Panel>
            </s:Application>
            • 3. Re: How to resolve Comparison between a value with static type string and a possible unrelated type numb
              pauland Level 4
              Take a look at the project below. I have modified your example. You can either monitor the slider changes via binding or explicitly handle events:
                  <fx:Declarations>
                  </fx:Declarations>
                  <fx:Script>
                      <![CDATA[
                          protected function valueSlider2ChangeHandler(event:Event):void
                              valueLabel2.text = CONVERSION[event.currentTarget.value];
                  </fx:Script>
                      <s:HSlider id="valueSlider" x="78" y="69" maximum="3" minimum="0" stepSize="1" value="1" />
                      <s:HSlider id="valueSlider2" x="378" y="69" maximum="3" minimum="0" stepSize="1" value="1" change="valueSlider2ChangeHandler(event)"/>
                      <s:Label id="valueLabel" x="109" y="38" text= "{CONVERSION[valueSlider.value]}"/>
                      <s:Label id="valueLabel2" x="409" y="38" text="'XXX'"/>
                  </s:Panel>
              </s:Application>
              • 4. Re: How to resolve Comparison between a value with static type string and a possible unrelated type numb
                usoldier18 Level 1
                Thank you very much, very helpfull and I will definilty come here for more help when I get stuck again.
