1 Reply Latest reply on Nov 3, 2012 7:40 PM by Xiaoyi Tong
    Help! No products are showing in my Extension Manager
    Iamadi
      Hi there,
      I'm having a problem in that no products are showing in the Extension Manager.  I've just signed up for the Creative Cloud and have so far only downloaded Photoshop. But it's refusing to show in the Extension Manager and I can't therefore install any extensions. The products column is just entirely empty.
      I did previously have the CS5.5 Master Collection installed but in case it was causing the problem I uninstalled it, uninstalled CS6 as well and resinstalled Photoshop afresh.
      I still have the same problem though
      I'm running Mac OS X 10.8.2 and following the advice from a different conversation tried "BridgeTalk.__diagnostics__;" and found that PhotoShop isn't mentioned at all in the resulting diagnostics.
      This is driving me crazy and I've got some bits I need to get done ASAP so please anyone help if you can!
      Thanks in advance,
      Adi
      Diagnostics text follows:
      Result: BridgeTalk Diagnostics
                Info:
                          Name = estoolkit-3.8
                          Status = PUMPING
                          Path
                          Version = 2.0
                          Build = ES 4.2.12
                          Next serial number = 18
                          Logging: = OFF
                          Now = 23:12:20
                                    Message Version = 2.05
                                    Authentication = ON
                                    Digest = ON
                Thread: estoolkit-3.8#thread
                          Avg. pump interval = 39ms
                          Last pump = 21ms ago
                          Ping: 7
                                    ECHO_REQUEST: ECHO_RESPONSE
                                              Timeout = undefined
                                              Handler = undefined
                                    STATUS: PUMPING
                                              Timeout = undefined
                                              Handler = undefined
                                    MAIN: MAIN
                                              Timeout = undefined
                                              Handler = installed
                                    LAUNCHED: LAUNCHED
                                              Timeout = undefined
                                              Handler = installed
                                    DIAGNOSTICS: DIAGNOSTICS
                                              Timeout = undefined
                                              Handler = installed
                                    INFO: INFO
                                              Timeout = undefined
                                              Handler = installed
                                    SETUPTIME: thread=1ms, left=1ms
                                              Timeout = undefined
                                              Handler = undefined
                Instances: 3
                          estoolkit-3.8#dbg:
                                              msg[23:12:20]: 00000013
                                                        @BT>Version = 2.05
                                                        Target = estoolkit-3.8#dbg
                                                        Sender = estoolkit-3.8#dbg
                                                        Sender-ID = localhost:mac6738
                                                        Timeout = 23:12:21
                                                        Type = Ignore
                                                        Response-Request = Timeout
                                                        Headers = (no headers)
                                                        Timestamp = 23:12:20
                                                        Serial-Number = 13
                                                        Received = undefined
                                                        Result = undefined
                                                        Error = undefined
                                                        Body = (empty)
                                    Incoming: 1
                                    Outgoing: 0
                                    Handler: 9
                                              ExtendScript = for all messages
                                              Error = for only msg #3
                                              Error = for only msg #5
                                              Error = for only msg #9
                                              Result = for only msg #13
                                              Error = for only msg #13
                                              Timeout = for only msg #13
                                              Result = for only msg #15
                                              Error = for only msg #15
                          estoolkit-3.8#estk:
                                              msg[23:12:20]: 00000015
                                                        @BT>Version = 2.05
                                                        Target = estoolkit-3.8#estk
                                                        Timeout = 23:22:20
                                                        Type = Debug
                                                        Response-Request = Result Error
                                                        Serial-Number = 15
                                                        Result = undefined
                                                        Error = undefined
                                                        Body: 107 bytes
        Text = <get-properties engine="main" object="$.global" exclude="undefined,builtin,prototype" all="true" max="20"/>
                                    Incoming: 1
                                    Outgoing: 0
                                    Handler: 1
                          estoolkit-3.8: (main)
                                    Incoming: 0
                                    Outgoing: 0
                                    Handler: 1
        • 1. Re: Help! No products are showing in my Extension Manager
          Xiaoyi Tong Adobe Employee
          Hi Lamadi,
          Extension Manager manages products in the same Creative Suite family only. It means, Extension Manager CS 5.5 only manages CS 5.5 products, such as Photoshop CS5.5. Extension Manager CS 6 only manages products like Photoshop CS 6. So CS 6 products will NOT be showed in Extension Manager CS5.5. Because Extension Manager CS 5.5 and Extension Manager CS6 can be installed on the same machine, please make sure you are running the correct one. Just double clicking the extension may not launch the Extension Manager you want. Please launch the Extension Manager you expect manually and then install your extensions. Thanks.
          Xiaoyi
