3 Replies Latest reply on Nov 5, 2012 4:57 AM by CindiSell
    Conversion of PE 10 Catalogue to PE 11
    CindiSell
      I installed PE 11.  It asked if I wanted to convert previous PE 10 Catalogue to PE 11.  I have about 49,000 pix, many edited, ALL tagged.  I said yes.  It started, converted a very few media files, and stopped.  Can't figure out how to convert ALL PE 10 files.
        • 1. Re: Conversion of PE 10 Catalogue to PE 11
          18qwer Level 3
          I found this in the help file:
          Use (convert) a catalog of a previous version
          When you open Elements Organizer for the first time after installation, you are prompted to
          convert catalogs from previous versions. When you click Yes, catalogs from the previous
          version are converted and renamed.
          If you have not converted catalogs earlier, use the following procedure to convert catalogs
          Note: Adobe recommends that you take a backup of your previous catalog using File > Backup Catalog.
          1. In the latest version of Elements Organizer, select File > Manage Catalogs.
          2. Click Convert.
          3. Select the catalog from the list that is displayed.
          4. Click Done.
          Try this and see if it works.
          • 2. Re: Conversion of PE 10 Catalogue to PE 11
            ~V Adobe Employee
            Cindisell,
            Do you see an error message or does it stop at particular stage during conversion. Can you post a screenshot if feasible?
            Regards,
            vaishali
            • 3. Re: Conversion of PE 10 Catalogue to PE 11
              CindiSell Level 1
              I found the training video and went back and did the PE 10  optomize  and
              repair.  Then I found the name of the 10 catalogue. Finally  PE 11 asked for
              previously converted files (It hadn't found the PE 10  catalogue before) and
              when I found that catalogue and told it to convert--it did  so.
              Funny thing.  It stopped at 36% and took a long time going through  several
              million files   like
              Mycatalogue4\caxmpFILES\xvp12300100.xmp
              Then it raced to 100%, and, voila,  my 50,000 pix came up.
              Now I am concerned because Carbonite doesn't seem to be backing up all
              those files???
              A month or so ago when I wrote tag and other info onto file names through
              PE10, it took Carbonite a month to back up all the changes.  Now I don't
              see much backup work for Carbonite after I did the conversion to PE11.
              I have been buying the new programs since PE2, so I have done a lot of
              changes.  I always keep at least the current program and the last on the
              computer in case of problems.  It has helped several times when something  went
              bad in the current PE pgm.
              Thanks for the help.
              In a message dated 11/5/2012 3:01:31 A.M. Eastern Standard Time,
              forums_noreply@adobe.com writes:
              created by ~V (http://forums.adobe.com/people/~V)  in Photoshop  Elements
              - View the full  discussion
              (http://forums.adobe.com/message/4823388#4823388)
