2 Replies Latest reply on Nov 5, 2012 2:50 PM by taz291819
    Exported .mp4 and FlipFactory audio sync problems
    taz291819 Level 1
      I work for a television station, and we use FlipFactory to convert everything before going to our playout server.
      When using the H.264 preset in CS5.5, everything works fine.
      When using the same preset in CS6, after going through FlipFactory, the audio sync starts to drift.  By the end of a 30 minute program, the audio is way out of sync.  If I play the file (after CS6 export, before FlipFactory) in WMP, VLC, MPC, the audio stays in sync.
      Using the H.264 BluRay preset, everything is fine (in both CS5.5 and CS6), but obviously, the file size is larger due to the container.
      I understand that most will say this is a FlipFactory issue since the file plays back fine before FF does it's thing, but something must have changed from CS5.5 to CS6 regarding the H.264 encoder, as CS5.5's files go through FF just fine.
      Any help would be appreciated.
        • 1. Re: Exported .mp4 and FlipFactory audio sync problems
          Since you mention WMP, I will presume you are on Windows
          So, use http://mediainfo.sourceforge.net/en to analyze the DETAILS of the CS5.5 and CS6 output files to see what is different
          • 2. Re: Exported .mp4 and FlipFactory audio sync problems
            taz291819 Level 1
            Did somewhat of what you asked.  I exported the same show in CS6, one using the H.264 preset, one using the H.264 BluRay preset.  The H.264 preset one drifts out of sync after FlipFactory, the other stays in sync.
            Here are the media info specs for each file (I did use different bitrates on the two, but that shouldn't cause an issue):
            H.264:
            General
            Complete name                            : D:\Commercials\TORICHMOND\PH6522.mp4
            Format                                   : MPEG-4
            Format profile                           : Base Media / Version 2
            Codec ID                                 : mp42
            File size                                : 3.61 GiB
            Duration                                 : 28mn 30s
            Overall bit rate mode                    : Variable
            Overall bit rate                         : 18.1 Mbps
            Encoded date                             : UTC 2012-11-05 19:56:39
            Tagged date                              : UTC 2012-11-05 19:58:35
            ©TIM                                     : 00:00:00:00
            ©TSC                                     : 30000
            ©TSZ                                     : 1001
            Video
            Format                                   : AVC
            Format/Info                              : Advanced Video Codec
            Format profile                           : Main@L4.1
            Format settings, CABAC                   : Yes
            Format settings, ReFrames                : 3 frames
            Codec ID                                 : avc1
            Codec ID/Info                            : Advanced Video Coding
            Duration                                 : 28mn 30s
            Source duration                          : 28mn 30s
            Bit rate mode                            : Constant
            Bit rate                                 : 18.0 Mbps
            Width                                    : 1 920 pixels
            Height                                   : 1 080 pixels
            Display aspect ratio                     : 16:9
            Frame rate mode                          : Variable
            Frame rate                               : 29.970 fps
            Minimum frame rate                       : 29.970 fps
            Maximum frame rate                       : 30.000 fps
            Standard                                 : NTSC
            Color space                              : YUV
            Chroma subsampling                       : 4:2:0
            Bit depth                                : 8 bits
            Scan type                                : Interlaced
            Scan order                               : Top Field First
            Bits/(Pixel*Frame)                       : 0.290
            Stream size                              : 3.57 GiB (99%)
            Source stream size                       : 3.57 GiB (99%)
            Language                                 : English
            Tagged date                              : UTC 2012-11-05 19:56:39
            mdhd_Duration                            : 1710709
            Audio
            Format                                   : AAC
            Format/Info                              : Advanced Audio Codec
            Format profile                           : LC
            Codec ID                                 : 40
            Duration                                 : 28mn 30s
            Bit rate mode                            : Variable
            Bit rate                                 : 192 Kbps
            Maximum bit rate                         : 295 Kbps
            Channel(s)                               : 2 channels
            Channel positions                        : Front: L R
            Sampling rate                            : 48.0 KHz
            Compression mode                         : Lossy
            Stream size                              : 38.6 MiB (1%)
            Source stream size                       : 38.6 MiB (1%)
            Language                                 : English
            mdhd_Duration                            : 1710763
            H.264 BluRay:
            General
            Complete name                            : D:\Commercials\TORICHMOND\PH6522A.m2t
            Format                                   : MPEG-TS
            File size                                : 4.93 GiB
            Duration                                 : 28mn 31s
            Overall bit rate                         : 24.7 Mbps
            Video
            Menu ID                                  : 1 (0x1)
            Format                                   : AVC
            Format profile                           : High@L4.1
            Format settings, ReFrames                : 4 frames
            Codec ID                                 : 27
            Duration                                 : 28mn 30s
            Bit rate                                 : 23.4 Mbps
            Maximum bit rate                         : 24.0 Mbps
            Standard                                 : NTSC
            Color space                              : YUV
            Bit depth                                : 8 bits
            Bits/(Pixel*Frame)                       : 0.376
            Stream size                              : 4.66 GiB (95%)
            Color primaries                          : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
            Transfer characteristics                 : BT.709-5, BT.1361
            Matrix coefficients                      : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
            Audio
            Menu ID                                  : 1 (0x1)
            Format                                   : AC-3
            Format/Info                              : Audio Coding 3
            Mode extension                           : CM (complete main)
            Codec ID                                 : 129
            Duration                                 : 28mn 30s
            Bit rate                                 : 128 Kbps
            Bit depth                                : 16 bits
            Stream size                              : 26.1 MiB (1%)
