18 Replies Latest reply on Feb 23, 2013 3:53 PM by julienbelg
    Rendering light in Photoshop CS6
    julienbelg
      by download I received CS6 (download version, not by disk).
      after installation I tryed in a photo to put an object into a spotlight.
      in the menu filter, rendering you can activate clouds etc, also lighteffects, but in my version the tab lighteffects is coloured in grey (not active)
      how can I get this thing started?
      Johan Cnudde
        • 1. Re: in cs6 filter, rendering, lighteffects
          charles badland Level 4
          Hi Johan,
          You need to either enable Graphics Processor: Edit(PC)  Photoshop(Mac)>Preferences>Performance> and check Use Graphics Processor, or update your video card to one compatible with CS6.
          Do you know the brand and model of your current graphics card?
          • 2. Re: in cs6 filter, rendering, lighteffects
            julienbelg Level 1
            I'am sorry, I'am not so technologic.
            what I found: Nividia Geforce 9400 GT is that the name of my video card?
            • 3. Re: in cs6 filter, rendering, lighteffects
              Yes. I assume you are on a PC?
              Launch Photoshop and go to the Edit Menu, then Preferences, then Performance and see that Use Graphics Processor is checked.
              Also, check to make sure your image is in RGB mode. In Photoshop, with your image open, go Image>Mode and see that RGB is checked.
              • 4. Re: in cs6 filter, rendering, lighteffects
                sudarshan.t Level 6
                Johan,
                Did you try Charles' suggestion?
                If that still doesn't solve your issue, open Photoshop, go to Help > System Info, copy and paste that data here for us please.
                • 5. Re: in cs6 filter, rendering, lighteffects
                  julienbelg Level 1
                  I have reinstalled CS6 this is a picture of the screen
                  here under print of system info
                  Adobe Photoshop Versie: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x32
                  Besturingssysteem: Windows 7 32 bits
                  Versie: 6.1 Service Pack 1
                  Systeemarchitectuur: Intel CPU-familie:15, Model:4, Stepping:3 met MMX, SSE-integer, SSE FP, SSE2, SSE3, HyperThreading
                  Aantal fysieke processors: 1
                  Aantal logische processors: 2
                  Snelheid processor: 3277 MHz
                  Ingebouwd geheugen: 2046 MB
                  Beschikbaar geheugen: 308 MB
                  Hoeveelheid beschikbaar geheugen voor Photoshop: 1627 MB
                  Geheugen in gebruik door Photoshop: 60 %
                  Blokgrootte van afbeelding: 128 kB
                  Niveaus voor afbeeldingscache: 4
                  De GPU Sniffer is vastgelopen op 6/11/2012 om 14:31:52
                  Scherm: 1
                  Grenzen:= boven: 0, links: 0, onder: 1080, rechts: 1920
                  Geen videokaart gevonden
                  Serienummer: 91198703422063947307
                  Toepassingsmap: C:\Program Files\Adobe\Adobe Photoshop CS6\
                  Tijdelijk bestandspad: C:\Users\Johan\AppData\Local\Temp\
                  Werkgeheugen van Photoshop heeft asynchrone I/O ingeschakeld
                  Werkvolume(s):
                  C:\, 74,4 GB, 17,2 GB vrij
                  Map met vereiste plug-ins: C:\Program Files\Adobe\Adobe Photoshop CS6\Required\
                  Primaire map voor plug-ins: C:\Program Files\Adobe\Adobe Photoshop CS6\Plug-ins\
                  Map voor extra plug-ins: niet ingesteld
                  Geïnstalleerde componenten:
                     A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                     ACE.dll   ACE 2012/01/18-15:07:40   66.492997   66.492997
                     adbeape.dll   Adobe APE 2012/01/25-10:04:55   66.1025012   66.1025012
                     AdobeLinguistic.dll   Adobe Linguisitc Library   6.0.0
                     AdobeOwl.dll   Adobe Owl 2012/02/09-16:00:02   4.0.93   66.496052
                     AdobePDFL.dll   PDFL 2011/12/12-16:12:37   66.419471   66.419471
                     AdobePIP.dll   Adobe Product Improvement Program   6.0.0.1654
                     AdobeXMP.dll   Adobe XMP Core 2012/02/06-14:56:27   66.145661   66.145661
                     AdobeXMPFiles.dll   Adobe XMP Files 2012/02/06-14:56:27   66.145661   66.145661
                     AdobeXMPScript.dll   Adobe XMP Script 2012/02/06-14:56:27   66.145661   66.145661
                     adobe_caps.dll   Adobe CAPS   6,0,29,0
                     AGM.dll   AGM 2012/01/18-15:07:40   66.492997   66.492997
                     ahclient.dll    AdobeHelp Dynamic Link Library   1,7,0,56
                     aif_core.dll   AIF   3.0   62.490293
                     aif_ocl.dll   AIF   3.0   62.490293
                     aif_ogl.dll   AIF   3.0   62.490293
                     amtlib.dll   AMTLib   6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00)   1.000000
                     ARE.dll   ARE 2012/01/18-15:07:40   66.492997   66.492997
                     AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
                     AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
                     Bib.dll   BIB 2012/01/18-15:07:40   66.492997   66.492997
                     BIBUtils.dll   BIBUtils 2012/01/18-15:07:40   66.492997   66.492997
                     boost_date_time.dll   DVA Product   6.0.0
                     boost_signals.dll   DVA Product   6.0.0
                     boost_system.dll   DVA Product   6.0.0
                     boost_threads.dll   DVA Product   6.0.0
                     cg.dll   NVIDIA Cg Runtime   3.0.00007
                     cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                     CIT.dll   Adobe CIT   2.0.5.19287   2.0.5.19287
                     CoolType.dll   CoolType 2012/01/18-15:07:40   66.492997   66.492997
                     data_flow.dll   AIF   3.0   62.490293
                     dvaaudiodevice.dll   DVA Product   6.0.0
                     dvacore.dll   DVA Product   6.0.0
                     dvamarshal.dll   DVA Product   6.0.0
                     dvamediatypes.dll   DVA Product   6.0.0
                     dvaplayer.dll   DVA Product   6.0.0
                     dvatransport.dll   DVA Product   6.0.0
                     dvaunittesting.dll   DVA Product   6.0.0
                     dynamiclink.dll   DVA Product   6.0.0
                     ExtendScript.dll   ExtendScript 2011/12/14-15:08:46   66.490082   66.490082
                     FileInfo.dll   Adobe XMP FileInfo 2012/01/17-15:11:19   66.145433   66.145433
                     filter_graph.dll   AIF   3.0   62.490293
                     hydra_filters.dll   AIF   3.0   62.490293
                     icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
                     icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
                     image_compiler.dll   AIF   3.0   62.490293
                     image_flow.dll   AIF   3.0   62.490293
                     image_runtime.dll   AIF   3.0   62.490293
                     JP2KLib.dll   JP2KLib 2011/12/12-16:12:37   66.236923   66.236923
                     libeay32.dll   The OpenSSL Toolkit   0.9.8g
                     libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                     libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   10.0
                     LogSession.dll   LogSession   2.1.2.1640
                     mediacoreif.dll   DVA Product   6.0.0
                     MPS.dll   MPS 2012/02/03-10:33:13   66.495174   66.495174
                     msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                     msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                     msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
                     msvcp71.dll   Microsoft® Visual Studio .NET   7.10.3077.0
                     msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                     msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                     msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
                     msvcr71.dll   Microsoft® Visual Studio .NET   7.10.3052.4
                     msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                     msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                     pdfsettings.dll   Adobe PDFSettings   1.04
                     Photoshop.dll   Adobe Photoshop CS6   CS6
                     Plugin.dll   Adobe Photoshop CS6   CS6
                     PlugPlug.dll   Adobe(R) CSXS PlugPlug Standard Dll (32 bit)   3.0.0.383
                     PSArt.dll   Adobe Photoshop CS6   CS6
                     PSViews.dll   Adobe Photoshop CS6   CS6
                     SCCore.dll   ScCore 2011/12/14-15:08:46   66.490082   66.490082
                     ScriptUIFlex.dll   ScriptUIFlex 2011/12/14-15:08:46   66.490082   66.490082
                     shfolder.dll   Microsoft(R) Windows (R) 2000 Operating System   5.50.4027.300
                     ssleay32.dll   The OpenSSL Toolkit   0.9.8g
                     tbb.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
                     tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
                     TfFontMgr.dll   FontMgr   9.3.0.113
                     TfKernel.dll   Kernel   9.3.0.113
                     TFKGEOM.dll   Kernel Geom   9.3.0.113
                     TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                     updaternotifications.dll   Adobe Updater Notifications Library   6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   6.0.0.24
                     WRServices.dll   WRServices Friday January 27 2012 13:22:12   Build 0.17112   0.17112
                     wu3d.dll   U3D Writer   9.3.0.113
                  Vereiste plug-ins:
                     Adaptief groothoek 13.0
                     ADM 3.11x01
                     Andere wolken 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Arcering 13.0
                     Basreliëf 13.0
                     BMP 13.0
                     Bol 13.0
                     Camera Raw 7.0
                     Chroom 13.0
                     Cineon 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Collada 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     CompuServe GIF 13.0
                     Conté crayon 13.0
                     Craquelure 13.0
                     De-Interlace 13.0
                     Donkere lijnen 13.0
                     Droog penseel 13.0
                     Eazel Acquire 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     FastCore Routines 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Filigraan 13.0
                     Filmkorrel 13.0
                     Filter Figuurpakket 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Filter Foto's uitsnijden en rechttrekken 13.0
                     Filtergalerie 13.0
                     Fotokopie 13.0
                     Foto's uitsnijden en rechttrekken 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Fresco 13.0
                     Geaccentueerde randen 13.0
                     Gebrandschilderd glas 13.0
                     Geef diepte 13.0
                     Gemiddelde 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Gescheurde randen 13.0
                     Gips 13.0
                     Glas 13.0
                     Gloed onscherp 13.0
                     Golf 13.0
                     Grafische pen 13.0
                     Halftoonraster 13.0
                     HDRMergeUI 13.0
                     Hoeklijn 13.0
                     Houtskool 13.0
                     IFF-formaat 13.0
                     Inktomtrek 13.0
                     JPEG 2000 13.0
                     Kleur halftoon 13.0
                     Kleurpotlood 13.0
                     Klodder 13.0
                     Kneep 13.0
                     Knipsel 13.0
                     Korrel 13.0
                     Krijt en houtskool 13.0
                     Kristal 13.0
                     Kronkel 13.0
                     Lappendeken 13.0
                     Lenscorrectie 13.0
                     Matlab Operation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Metingskern 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Mezzotint 13.0
                     MMXCore-routines 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Mozaïektegels 13.0
                     Neon gloed 13.0
                     NTSC-kleuren 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Oceaanrimpel 13.0
                     Olieverf 13.0
                     Ondersteuning van meerdere processors 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     OpenEXR 13.0
                     Oplichtende rand 13.0
                     Opslaan voor web 13.0
                     Paden naar Illustrator 13.0
                     Paletmes 13.0
                     PCX 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Perspectiefpunt 13.0
                     Photoshop 3D-engine 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Pixar 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Plastic 13.0
                     PNG 13.0
                     Pointilleren 13.0
                     Poolcoördinaten 13.0
                     Portable Bit Map 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Posterranden 13.0
                     Postpapier 13.0
                     Radiaal vaag 13.0
                     Radiance 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Rimpel 13.0
                     Ruw pastel 13.0
                     Schuin 13.0
                     Scriptondersteuning 13.0
                     Slim vervagen 13.0
                     Solariseren 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Spetters 13.0
                     Spons 13.0
                     Sproeilijn 13.0
                     Stempel 13.0
                     Structuurmaker 13.0
                     Sumi-e 13.0
                     Targa 13.0
                     Tegels 13.0
                     Uitvloeien 13.0
                     Vage lens 13.0
                     Variaties 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Verplaatsen 13.0
                     Vezels 13.0
                     Vlek 13.0
                     Voorbewerking 13.0
                     Watermerk insluiten 4.0
                     Watermerk lezen 4.0
                     Waterpapier 13.0
                     Waterverf 13.0
                     WIA-ondersteuning 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Wind 13.0
                     Wireless Bitmap 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     Wolken 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                     ZigZag 13.0
                     Zon 13.0
                  Optionele plug-ins en plug-ins van derden: GEEN
                  Plug-ins die niet konden worden geladen: GEEN
                  Flash:
                     Mini Bridge
                     Kuler
                  Geïnstalleerde TWAIN-apparaten: GEEN
                  thank you for your help
                  • 6. Re: in cs6 filter, rendering, lighteffects
                    sudarshan.t Level 6
                    Your system doesn't seem to show up a video graphics card that Photoshop can use. This is why the filters that are dependant on that are greyed out.
                    Also, your version of Photoshop is not up to date. The current version is 13.0.1. Click Help > Update and update to the latest version.
                    A few other observations. You seem to be having only 2GB of RAM which is absolutely insufficient for Photoshop CS6. Photoshop CS6 needs a bearest minimum of 4Gigs of RAM - 8GB  recommended. More the merrier for Photoshop!
                    Your Harddisk space is also extremely low for a lot of high-end processing that Photoshop CS6 is capable of.
                    I think it is time you consider a decent hardware upgrade.
                    • 7. Re: in cs6 filter, rendering, lighteffects
                      julienbelg Level 1
                      can you give me the type and brand of the video graphics cards which adobe requires for C6, or other suggestions about the hardware upgrade?
                      thank you
                      • 8. Re: in cs6 filter, rendering, lighteffects
                        sudarshan.t Level 6
                        Any dedicated video card should work. A minimum of 1Gig, preferably 2Gigs of GPU RAM is recommended for CS6.
                        Look up nVidia for available options.
                        Hardware upgrade - pick up a good amount of RAM. It's dirt cheap nowadays. 8 Gigs minimum or 16Gigs - Again ensure that your processor and motherboard support this amount of RAM. From the looks, I think your computer itself is quite old. Also, get a good capacity hard drive.
                        • 9. Re: in cs6 filter, rendering, lighteffects
                          GumboMumbo
                          Julien, your graphics card is an approved type, but it has failed an Adobe test ("De GPU Sniffer is vastgelopen"). The reason is not clear, but I suggest that, with power off, you first carefully remove and then reinstall the GPU card. If that does not solve the problem, it could be that you don't have enough disk space (in Win Explorer, right-click your drive letter, click Properties, click Disk Cleanup to get more disk space). It could be that you don't have enough free memory. In that case, disable unnecessary programs that are using memory, especially any that you installed recently. A good way to disable programs, either temporarily or permanently, is to click Start, enter "cmd" and then enter "msconfig". The Startup tab will show the running tasks; uncheck any that you do not want to run, then reboot. Also, update Photoshop to the current version, and do the same for your graphics card. If none of those actions fix the problem, it is likely that your graphics card is defective. If possible, borrow a graphics card from a friend; if it works, yours is bad.
                          • 10. Re: in cs6 filter, rendering, lighteffects
                            Jeff Arola Adobe Community Professional
                            Hi julienbeig,
                            Did you go to the Nvidia site and download and install the latest drivers for your card?
                            (the updates that windows update offers are sometimes very out of date)
                            http://www.nvidia.com/Download/index.aspx?lang=en-us
                            Under option 2 you can download a utility that will check to see what card you have and suggest the latest driver to download.
                            • 11. Re: in cs6 filter, rendering, lighteffects
                              julienbelg Level 1
                              good day Sudarshan,
                              i have updated my hardware, but still the rendering lighteffects is greyed out. is it possible that the remark "Photoshop Standard" is the cause?
                              if so, how can i upgrade eventualy?
                              thanks for answer
                              • 12. Re: in cs6 filter, rendering, lighteffects
                                sudarshan.t Level 6
                                Julien, no Photoshop Standard can render Lighting effects. Only for 3d purposes, Photoshop Extended is required. So, you need not upgrade to Extended.
                                Now that you've said you've upgraded hardware, could you go to Help > System Info, copy & paste that data here to show us what has changed?
                                -ST
                                • 13. Re: Rendering light in Photoshop CS6
                                  julienbelg Level 1
                                  Here are the required changements:
                                  Adobe Photoshop Versie: 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00) x32
                                  Besturingssysteem: Windows NT
                                  Versie: 6.2
                                  Systeemarchitectuur: Intel CPU-familie:6, Model:10, Stepping:9 met MMX, SSE-integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
                                  Aantal fysieke processors: 4
                                  Aantal logische processors: 8
                                  Snelheid processor: 3503 MHz
                                  Ingebouwd geheugen: 32721 MB
                                  Beschikbaar geheugen: 30668 MB
                                  Hoeveelheid beschikbaar geheugen voor Photoshop: 3255 MB
                                  De GPU Sniffer is vastgelopen op 9/02/2013 om 16:00:21
                                  Scherm: 1
                                  Toepassingsmap: C:\Program Files (x86)\Adobe\Adobe Photoshop CS6\
                                  Tijdelijk bestandspad: C:\Users\Admin\AppData\Local\Temp\
                                  Werkvolume(s):
                                  C:\, 111,4 GB, 41,9 GB vrij
                                  Map met vereiste plug-ins: C:\Program Files (x86)\Adobe\Adobe Photoshop CS6\Required\
                                  Primaire map voor plug-ins: C:\Program Files (x86)\Adobe\Adobe Photoshop CS6\Plug-ins\
                                     ACE.dll   ACE 2012/06/05-15:16:32   66.507768   66.507768
                                     AdobeOwl.dll   Adobe Owl 2012/06/26-12:17:19   4.0.95   66.510504
                                     AGM.dll   AGM 2012/06/05-15:16:32   66.507768   66.507768
                                     ARE.dll   ARE 2012/06/05-15:16:32   66.507768   66.507768
                                     Bib.dll   BIB 2012/06/05-15:16:32   66.507768   66.507768
                                     BIBUtils.dll   BIBUtils 2012/06/05-15:16:32   66.507768   66.507768
                                     CoolType.dll   CoolType 2012/06/05-15:16:32   66.507768   66.507768
                                     msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6910
                                     msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6910
                                     msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6910
                                  Vereiste plug-ins:
                                     ADM 3.11x01
                                     Andere wolken 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Arcering 13.0
                                     Basreliëf 13.0
                                     BMP 13.0
                                     Bol 13.0
                                     Camera Raw 7.3
                                     Chroom 13.0
                                     Cineon 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Collada 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     CompuServe GIF 13.0
                                     Conté crayon 13.0
                                     Craquelure 13.0
                                     De-Interlace 13.0
                                     Donkere lijnen 13.0
                                     Droog penseel 13.0
                                     Eazel Acquire 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     FastCore Routines 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Filigraan 13.0
                                     Filmkorrel 13.0
                                     Filter Figuurpakket 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Filtergalerie 13.0
                                     Fotokopie 13.0
                                     Foto's uitsnijden en rechttrekken 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Fresco 13.0
                                     Geef diepte 13.0
                                     Gemiddelde 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Gips 13.0
                                     Glas 13.0
                                     Gloed onscherp 13.0
                                     Golf 13.0
                                     Grafische pen 13.0
                                     Halftoonraster 13.0
                                     HDRMergeUI 13.0
                                     Hoeklijn 13.0
                                     Houtskool 13.0
                                     IFF-formaat 13.0
                                     Inktomtrek 13.0
                                     JPEG 2000 13.0
                                     Kleur halftoon 13.0
                                     Kleurpotlood 13.0
                                     Klodder 13.0
                                     Kneep 13.0
                                     Knipsel 13.0
                                     Korrel 13.0
                                     Kristal 13.0
                                     Kronkel 13.0
                                     Lappendeken 13.0
                                     Lenscorrectie 13.0
                                     Matlab Operation 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Metingskern 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Mezzotint 13.0
                                     MMXCore-routines 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Mozaïektegels 13.0
                                     Neon gloed 13.0
                                     NTSC-kleuren 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Oceaanrimpel 13.0
                                     Olieverf 13.0
                                     Ondersteuning van meerdere processors 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     OpenEXR 13.0
                                     Paletmes 13.0
                                     PCX 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Photoshop 3D-engine 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Pixar 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Plastic 13.0
                                     PNG 13.0
                                     Pointilleren 13.0
                                     Portable Bit Map 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Posterranden 13.0
                                     Postpapier 13.0
                                     Radiaal vaag 13.0
                                     Radiance 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Rimpel 13.0
                                     Ruw pastel 13.0
                                     Schuin 13.0
                                     Scriptondersteuning 13.0.1
                                     Slim vervagen 13.0
                                     Solariseren 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Spetters 13.0
                                     Spons 13.0
                                     Sproeilijn 13.0
                                     Stempel 13.0
                                     Structuurmaker 13.0
                                     Sumi-e 13.0
                                     Targa 13.0
                                     Tegels 13.0
                                     Uitvloeien 13.0
                                     Vage lens 13.0
                                     Variaties 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Verplaatsen 13.0
                                     Vezels 13.0
                                     Vlek 13.0
                                     Voorbewerking 13.0
                                     Watermerk lezen 4.0
                                     Waterpapier 13.0
                                     Waterverf 13.0
                                     WIA-ondersteuning 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Wind 13.0
                                     Wireless Bitmap 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     Wolken 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                     ZigZag 13.0
                                     Zon 13.0
                                  Flash:
                                     Mini Bridge
                                     Kuler
                                  Van: Sudarshan Thiagarajan forums_noreply@adobe.com
                                  Verzonden: zaterdag 9 februari 2013 13:01
                                  Aan: julienbelg
                                  Onderwerp: Rendering light in Photoshop CS6
                                  created by Sudarshan Thiagarajan <http://forums.adobe.com/people/sudarshan.t>  in Photoshop for Beginners - View the full discussion <http://forums.adobe.com/message/5060053#5060053
                                  • 14. Re: in cs6 filter, rendering, lighteffects
                                    Noel Carboni Level 8
                                    The error message referring to ''no GPU options in Photoshop Standard'' is a mistake.  Ignore the &quot;Photoshop Standard&quot; part.
                                    The basic problem is that Adobe's &quot;GPU Sniffer&quot; - a program that checks to see if your system is properly set up to provide graphics processor support - has crashed, per this entry that we see in your info:
                                    To correct this problem, you need to get to the bottom of why that's happening.
                                    The normal advice is to seek out an updated / more stable version of your display driver.  In the case where you've upgraded your hardware, you may have to run special software that will seek out and remove remnants of the display driver you had in your system before.  I have never used it myself, but one such program I've heard recommended is called Driver Sweeper.  Then you'll want to install the latest version offered by the manufacturer of the video card.
                                    -Noel
                                    • 15. Re: Rendering light in Photoshop CS6
                                      julienbelg Level 1
                                      It’s a new PC I bought, with windows 8 on it.
                                      My graphic card is a  <Sapphire Radeon HD 7970 Graphic Card - 1000 MHz Core - 6 GB GDDR5 SDRAM – VAPOR X>
                                      Which driver should I use? (Hydravision or Catalyst)
                                        http://www.sapphiretech.com/presentation/downloads/?pid=1497&psn=0006&lid=1&os=12
                                      • 16. Re: Rendering light in Photoshop CS6
                                        Level 7
                                        You should be downloading your drivers directly from AMD, not Microsoft, and not a card vendor.
                                        • 17. Re: Rendering light in Photoshop CS6
                                          Catalyst 13.2 beta 5 is your best bet right now for use with Photoshop.  The current release, 13.1, is no good with Photoshop.
                                          Go to http://www.amd.com, hover your cursor over the Find a Driver hotspot at the upper-right, and make the choices that match your OS and architecture (32 or 64 bit).  Then look for the "Latest Beta Driver" link on that page.
                                          This advice stands until 13.2 is actually released of course.
                                          -Noel
                                          • 18. Re: Rendering light in Photoshop CS6
                                            julienbelg Level 1
                                            Thank you for your answer,
                                            This was the sollution to my problem
                                            Best regards
                                            Johan
