5 Replies Latest reply on Nov 7, 2012 2:19 AM by Jump_Over
    how to set if, else???
    AlienLai
      for example:
      if i want to text convert to table.
      If have ";" x 4
      header1;header2;header3;header4
      col1;col2;col3;col4
      (script 1)
      Header 1Header 2Header 3Header 4
      col1col2col3col4
      else
      if have ";" x5
      (script 2)
      var myTable = app.selection[0].convertToTable(";","\r");
      header1;header2;header3;header4;header5
      col1;col2;col3;col4;col5
      Header 1Header 2Header 3Header 4Header 5
      col1col2col3col4col5
      and if have ";"x6 =(script 3), ";" x 7 = (script 4), ";" x8  (scr.......
      i want only use a script to do, how can i do that??
      thankyou>< love your
        • 1. Re: how to set if, else???
          You don't have to count the number of ;'s. The function convertToTable will never create more columns than needed.
          • 2. Re: how to set if, else???
            AlienLai Level 1
            thankyou your help.
            but i want to set colnum wifth.
            different colnum number different width...
            example: if ";" x3
            col1 width = "90 mm" col2 = "30mm" col3 = "30mm"
            of ";" x 4
            col1 width = "75mm" cold 2 width = "25mm" col 3 width = "25mm" col 4 width = "25mm"
            because i have many script 1 for 3 column, script 2 for 4 column.
            how can i integrate to one script.
            • 3. Re: how to set if, else???
              Jump_Over Level 5
              Could you find a rule when calculating columns width?
              Could it be: 1st column is 3 times wider then the rest?
              If your table width is a textFrame width - all the rest is mathematics
              and can be done in one loop.
              • 4. Re: how to set if, else???
                AlienLai Level 1
                i see, but i'm asking wrong my english to bad....
                actually i'm not want to set colnum width.....
                i need count the character ";".....sorry...
                if         1;2;3;4       <----have three ";"
                run script 1
                if 1;2;3;4;5             <------have four ";"
                run script 2
                if       1;2;3;4;5;6   <--------have five ";"
                run script 3
                • 5. Re: how to set if, else???
                  Jump_Over Level 5
                  So you could use a switch:
                  var whichScript = myTable.columns.length;
                  or
                  var whichScript = app.selection[0].texts[0].contents.split(";").length;
                  and after this:
                  switch(whichScript)
                  case 1: {do something1; break;}
                  case 2: {do something2; break;}
                  case 3: {do something3; break;}
