0 Replies Latest reply on Nov 5, 2012 5:24 AM by Sonunew2flex
    Header renderer click handler not working
    Sonunew2flex Level 1
      Hi All
      Below is code of my header renderer which copied code from default headerrenderer and created new one, I added textinput with down arrow and close button,
      But when i click on close button, I am making filter box invisible, If i put a break point inside griditemrenderer1_mouseOutHandler() function then filter box becomes invisible, but while running in debug mode without break point filter box shows visible only,
      Please let me know where i am doing wrong.
      <s:GridItemRenderer minWidth="21" minHeight="21"
                          xmlns:fx="http://ns.adobe.com/mxml/2009"
                          xmlns:mx="library://ns.adobe.com/flex/mx"
                          mouseOver="griditemrenderer1_mouseOverHandler(event)"
                          creationComplete="griditemrenderer1_creationCompleteHandler(event)">
          <fx:Declarations>
              <s:Label id="labelDisplay"
                       verticalCenter="1"
                       textAlign="start"
                       fontWeight="bold"
                       verticalAlign="middle"
                       maxDisplayedLines="1"
                       showTruncationTip="true" />
          </fx:Declarations>
          <fx:Script>
              <![CDATA[
                  import com.db.view.components.FilterPopup;
                  import mx.managers.PopUpManager;
                  import mx.controls.Menu;
                  import mx.events.FlexEvent;
                  import spark.components.gridClasses.IGridVisualElement;
                  import mx.core.IVisualElement;
                  import spark.components.DataGrid;
                  import spark.components.GridColumnHeaderGroup;
                  import spark.components.gridClasses.GridColumn;
                  import spark.primitives.supportClasses.GraphicElement;
                  // chrome color constants and variables
                  private static const DEFAULT_COLOR_VALUE:uint = 0xCC;
                  private static const DEFAULT_COLOR:uint = 0xCCCCCC;
                  private static const DEFAULT_SYMBOL_COLOR:uint = 0x000000;
                  private static var colorTransform:ColorTransform = new ColorTransform();
                   *  @private
                  private function dispatchChangeEvent(type:String):void
                      if (hasEventListener(type))
                          dispatchEvent(new Event(type));
                  //  maxDisplayedLines
                  private var _maxDisplayedLines:int = 1;
                  [Bindable("maxDisplayedLinesChanged")]
                  [Inspectable(minValue="-1")]
                   *  The value of this property is used to initialize the
                   *  <code>maxDisplayedLines</code> property of this renderer's
                   *  <code>labelDisplay</code> element.
                   *  @copy spark.components.supportClasses.TextBase#maxDisplayedLines
                   *  @default 1
                   *  @langversion 3.0
                   *  @playerversion Flash 10
                   *  @playerversion AIR 1.5
                   *  @productversion Flex 4.5
                  public function get maxDisplayedLines():int
                      return _maxDisplayedLines;
                   *  @private
                  public function set maxDisplayedLines(value:int):void
                      if (value == _maxDisplayedLines)
                          return;
                      _maxDisplayedLines = value;
                      if (labelDisplay)
                          labelDisplay.maxDisplayedLines = value;
                      invalidateSize();
                      invalidateDisplayList();
                      dispatchChangeEvent("maxDisplayedLinesChanged");
                   *  @private
                   *  Create and add the sortIndicator to the sortIndicatorGroup and the
                   *  labelDisplay into the labelDisplayGroup.
                  override public function prepare(hasBeenRecycled:Boolean):void
                      super.prepare(hasBeenRecycled);
                      if (labelDisplay && labelDisplayGroup && (labelDisplay.parent != labelDisplayGroup))
                          labelDisplayGroup.removeAllElements();
                          labelDisplayGroup.addElement(labelDisplay);
                  private var chromeColorChanged:Boolean = false;
                  private var colorized:Boolean = false;
                  [Bindable]
                  private var _filterVisibility:Boolean = false;
                   *  @private
                   *  Apply chromeColor style.
                  override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
                      // Apply chrome color
                      if (chromeColorChanged)
                          var chromeColor:uint = getStyle("chromeColor");
                          if (chromeColor != DEFAULT_COLOR || colorized)
                              colorTransform.redOffset = ((chromeColor & (0xFF << 16)) >> 16) - DEFAULT_COLOR_VALUE;
                              colorTransform.greenOffset = ((chromeColor & (0xFF << 8)) >> 8) - DEFAULT_COLOR_VALUE;
                              colorTransform.blueOffset = (chromeColor & 0xFF) - DEFAULT_COLOR_VALUE;
                              colorTransform.alphaMultiplier = alpha;
                              transform.colorTransform = colorTransform;
                              var exclusions:Array = [labelDisplay];
                              // Apply inverse colorizing to exclusions
                              if (exclusions && exclusions.length > 0)
                                  colorTransform.redOffset = -colorTransform.redOffset;
                                  colorTransform.greenOffset = -colorTransform.greenOffset;
                                  colorTransform.blueOffset = -colorTransform.blueOffset;
                                  for (var i:int = 0; i < exclusions.length; i++)
                                      var exclusionObject:Object = exclusions[i];
                                      if (exclusionObject &&
                                          (exclusionObject is DisplayObject ||
                                              exclusionObject is GraphicElement))
                                          colorTransform.alphaMultiplier = exclusionObject.alpha;
                                          exclusionObject.transform.colorTransform = colorTransform;
                              colorized = true;
                          chromeColorChanged = false;
                      super.updateDisplayList(unscaledWidth, unscaledHeight);
                   *  @private
                  override public function styleChanged(styleProp:String):void
                      var allStyles:Boolean = !styleProp || styleProp == "styleName";
                      super.styleChanged(styleProp);
                      if (allStyles || styleProp == "chromeColor")
                          chromeColorChanged = true;
                  protected function griditemrenderer1_mouseOverHandler(event:MouseEvent):void
                      _filterVisibility = true;
                  protected function griditemrenderer1_mouseOutHandler():void
                      _filterVisibility = false;
                  protected function griditemrenderer1_creationCompleteHandler(event:FlexEvent):void
                      trace(label);
                  protected function textinput1_clickHandler(event:MouseEvent):void
                      var filterpopUp:FilterPopup = new FilterPopup();
                      filterpopUp.filterColumn = label;
                      PopUpManager.addPopUp(filterpopUp,this,false);
                      filterpopUp.addEventListener("test",testHandler);
                      filterpopUp.x = event.stageX - 50;
                      filterpopUp.y = event.stageY + 10;
                  protected function testHandler(event:Event):void
                      owner.dispatchEvent(new Event("test"));
          </fx:Script>
          <s:VGroup left="7" right="7" top="5" bottom="5" gap="2" verticalAlign="bottom">
              <s:HGroup id="tiFilter" width="100%" gap="3" verticalAlign="middle" visible="{_filterVisibility}">
                  <s:TextInput width="{labelDisplay.width + 20}" height="16" skinClass="com.db.view.skins.FilterTextInputSkin"
                                text="{label}" click="textinput1_clickHandler(event)"/>
                  <s:HGroup id="closeBtn" width="15" height="15" click="griditemrenderer1_mouseOutHandler()"
                            buttonMode="true" useHandCursor="true" mouseChildren="false" keyDown="griditemrenderer1_mouseOutHandler()">
                      <s:Image source="@Embed('/assets/images/icon_close.gif')"/>
                  </s:HGroup>
              </s:HGroup>
              <s:Group id="labelDisplayGroup" width="100%"/>
              <s:Group id="sortIndicatorGroup" includeInLayout="false" />
          </s:VGroup>
      </s:GridItemRenderer>
