I have Creative Cloud. Downloaded fine on my PC. However, I have a new Macbook Pro running the latest Mountain Lion OS, and I am unable to accept the acrobat agreement upon opening the application. I see the Accept button but I cannot click on it. When I click on it, it doesn't do anything. Since I cannot accept the user/software use agreement, I cannot do PDFs on the web, etc. Maybe it's a learning curve (came from a PC) or maybe a real issue? I have no problems with any of the other Adobe applications. Please help.
Known issue.
Fix described here: http://helpx.adobe.com/acrobat/kb/known-issues-acrobat-xi-reader.html (see Blank EULA screen)
"Blank EULA screen. Problem: Mac OS only. On launch, a blank EULA screen appears, which cannot be accepted, and Acrobat does not run. This problem can appear if you have any products installed from CCM or from Creative Suite, and you tried installing Acrobat XI from a different source.
Workaround: Launch any other product which is part of the CCM or Creative suite. Then, d
...Copy link to clipboard
Same problem here. It was so annoying as clicking on a PDF in a browser wouldn't work. I have Snow Leapord on a MacBook Pro.
I uninstalled Acrobat Pro XI by draggin it to the trash. Probably shouldn't have done that since now AAM thinks it's still installed and I can't reinstall it.
Help!
Known issue.
Workaround: Launch any other product which is part of the CCM or Creative suite. Then, deactivate it by choosing Help > Deactivate. Quit the application. Then, launch Acrobat and accept the EULA. Then, for the CCM subscription product, launch it and select License This Software to enable the CCM product again. If a CS application, launch it and reactivate it. [3338419]"
Thanks! I'm not sure if that solved it or not. Now all of my applications are in trial mode! And the one I de-activated won't let me navigate beyond "enter a serial number" which I do not have because its the creative cloud membership. Any advice?
Thanks John! That did in fact work! I APPRECIATE IT SO MUCH!!
I did the following to fix the "trial" issue (for anyone who reads this later):
(quit all applications)
1. Launch the application which says you are in trial mode.
2. On the Creative Cloud application trial screen, click on "License this Software".
3. Sign in with your Adobe ID associated with your Creative Cloud membership.
