2 Replies Latest reply on Nov 6, 2012 11:24 AM by nabnub
    Changing Another Field with Combo Box (Drop Down) Selection
    nabnub
      Hi everyone
      I've been trying to follow the instructions here: http://acrobatusers.com/tutorials/print/change_another_field
      so I tried to adapt the explained method to my form but nothing is happening really:
      here is my form : http://cjoint.com/?BKgsODn3tsD
      basically if in the field "Module code" I select Y1H3, I display in the fileds "Texte nRow.. " only:
      3           <= Texte nRow1
      13         <= Texte nRow2
      20         <= Texte nRow3
      if Y2H5 is selected I will have the following sequence displayed:
      1       <= Texte nRow1
      7       <= Texte nRow2
      12     <= Texte nRow3
      21     <= Texte nRow4
      22     <= Texte nRow5
      and so one for Y3H6 selected ... up to H6H11
      this is what I've try to do:
      so for the field  "Module code":  in proprities > Validate >  Run custom validation script I wrote:
      if( event.willCommit )
         if(event.value == " ")
           this.resetForm(["Texte nRow1","Texte nRow2","Texte nRow3","Texte nRow4","Texte nRow5","Texte nRow6","Texte nRow7","Texte nRow8","Texte nRow9","Texte nRow10","Texte nRow11"]);
         else
           SetFieldValues(event.value);
      then I created a document Javascript called SetFieldValues with the following code:
      //-----------------Do not edit the XML tags--------------------
      //<Document-Level>
      //<ACRO_source>SetFieldValues</ACRO_source>
      //<ACRO_script>
      /*********** belongs to: Document-Level:SetFieldValues ***********/
      // Place all prepopulation data into a single data structure
      var DeptData = { Y1H3:{ Line1: "3",
               Line2: "13",
               Line3: "20",
               Line4: "",
               Line5: "",
               Line6: "",
               Line7: "",
               Line8: "",
               Line9: "",
               Line10: "",
                                    Line11: "" },
                       Y2H5:{ Line1: "1",
               Line2: "7",
               Line3: "12",
               Line4: "21",
               Line5: "22",
               Line6: "",
               Line7: "",
               Line8: "",
               Line9: "",
               Line10: "",
                                    Line11: "" },
                       Y3H6 :{ Line1: "5",
               Line2: "11",
               Line3: "16",
               Line4: "23",
               Line5: "34",
               Line6: "39",
               Line7: "",
               Line8: "",
               Line9: "",
               Line10: "",
                                    Line11: "" },
                       Y4H8:{ Line1: "2",
               Line2: "6",
               Line3: "9",
               Line4: "15",
               Line5: "30",
               Line6: "33",
               Line7: "38",
               Line8: "42",
               Line9: "",
               Line10: "",
                                    Line11: "" },
           Y5H9:{ Line1: "4",
               Line2: "10",
               Line3: "26",
               Line4: "29",
               Line5: "31",
               Line6: "35",
               Line7: "37",
               Line8: "40",
               Line9: "41",
               Line10: "",
                                    Line11: "" },
           Y5H9:{ Line1: "8",
               Line2: "14",
               Line3: "17",
               Line4: "18",
               Line5: "19",
               Line6: "24",
               Line7: "27",
               Line8: "28",
               Line9: "32",
               Line10: "",
                                    Line11: "" }};
      function SetFieldValues(cDeptName)
        this.getField("Texte nRow1").value = DeptData[cDeptName].Line1;
        this.getField("Texte nRow2").value = DeptData[cDeptName].Line2;
        this.getField("Texte nRow3").value = DeptData[cDeptName].Line3;
        this.getField("Texte nRow4").value = DeptData[cDeptName].Line4;
        this.getField("Texte nRow5").value = DeptData[cDeptName].Line5;
        this.getField("Texte nRow6").value = DeptData[cDeptName].Line6;
        this.getField("Texte nRow7").value = DeptData[cDeptName].Line7;
        this.getField("Texte nRow8").value = DeptData[cDeptName].Line8;
        this.getField("Texte nRow9").value = DeptData[cDeptName].Line9;
        this.getField("Texte nRow10").value = DeptData[cDeptName].Line10;
        this.getField("Texte nRow11").value = DeptData[cDeptName].Line11;
      //</ACRO_script>
      //</Document-Level>
      //<AcroForm>
      //<ACRO_source>DepartmentNames:Keystroke</ACRO_source>
      //<ACRO_script>
      /*********** belongs to: AcroForm:DepartmentNames:Keystroke ***********/
      and actually nothing happened,
      can anyone have a look at it please?
      thanks a lot,
        • 1. Re: Changing Another Field with Combo Box (Drop Down) Selection
          For the following code:
             else
          The "willCommit" property of the event only applies to the keystroke event.
          Use:
             else
          That will get your code to execute.
          Now check the JavaScript console and workout your next set of errors.
          • 2. Re: Changing Another Field with Combo Box (Drop Down) Selection
            nabnub Level 1
            Thanks GKaiseril,
            actually I followed this example that they posted and which works perfectly:
            http://acrobatusers.com/assets/collections/tutorials/legacy/tech_corners/javascript_corner /tips/2006/change_another_field/ComboTest_Complete.pdf
            I realise a small mistake it wasn't under: proprities > Validate > Run custom validation script
            but proprities > Format > Custom Keystroke Script
            so I put what you suggested and then in the console error I've got:
            Acrobat EScript Built-in Functions Version 10.0
            Acrobat SOAP 10.0
            TypeError: DeptData[cDeptName] is undefined
            56:Field:Keystroke
            56:Field:Keystroke
            56:1
            but they say:
            "Enter the following code into the script editor. Note that the SetFieldValues() function definition is already in the script. By default Acrobat creates a function with the same name as the script. In the code below this function definition has been modified with the addition of an input argument named “cDeptName".  "
            I don't really see where is the problem in my code and why cDeptName is considered as undefined???
            thanks for you help
