5 Replies Latest reply on Nov 7, 2012 12:08 PM by TimJaramillo
    pass symbol instance name to variable
    David M. Level 1
      Hi all,
      I'm trying to figure out how to pass the instance name (ID) of a clicked object to a variable so I can navigate to a label on the timeline with the same name.
      So far I've tried different variations of:
      sym.getSymbol() //logs as "undefined"
      sym.getSymbolTypeName // logs the symbol name in the library, not the instance
      Any ideas?
      -Dave
        • 1. Re: pass symbol instance name to variable
          TimJaramillo Level 4
          Hi David, see below. Here you manually pass in the btnId. Not sure if you're specifically trying to dynamically get the button's instance name?
          // code on Stage.compositionReady event
          sym.onClick = function(btnId){
               sym.play(btnID);
          // code on your button's click event
          sym.getComposition().getStage().onClick("myBtn");
          • 2. Re: pass symbol instance name to variable
            David M. Level 1
            Hi Tim,
            Thanks for the quick response. However, I am trying to dynamically get the button's name. Ideally instead of adding a line of code to each button, I was hoping to add the code to the symbol in the library, that would then pass the instance name of each copy I made.
            Right now I have five buttons on the stage with indivdual instance names (nav_btn1 thru nav_btn5). Instead of handcoding an onclick even handler for each button I'd like to dynamically retrieve the instance name of the button clicked and pass it into a variable. In Flash I could do this with  e.target.name ... is there an equivelent in EA and jQuery?
            David
            • 3. Re: pass symbol instance name to variable
              Hi David,
              You can use "e.target.id" on your button click event to get the button's div id.
              alert(e.target.id);
              The only weird thing is that it seems to prepend "Stage_" to the value, so if your button div is called "myButton", the above will alert "Stage_myButton".
              • 4. Re: pass symbol instance name to variable
                David M. Level 1
                Sweet!
                That worked - Thanks! I ended up combining both your suggestions. on the button symbol i have
                sym.getComposition().getStage().onClick(e.target.id);
                and then after compositionReady I added a function to split out the second name and logged it to test;
                sym.onClick = function(targetId){
                          var names = targetId.split("_");
                          console.log(names[1]);
                Works perfectly! - Although it would be nice if the EA team could fix that functionality in future releases so e.target.id gives you just the id for the selected symbol. I would think if you can write something like getSymbol("mySymbol") it should be just as easy to get that name without all the extra (Stage...etc)
                Thanks again!
                -David
                • 5. Re: pass symbol instance name to variable
                  No problem!
                  Agreed, the "Stage_" prepending deal is weird. Maybe I'm missing something in the documenation for a more direct way to grab the clicked button id. I don't see anything in the API doc though: http://www.adobe.com/devnet-docs/edgeanimate/api/current/index.html
