4 Replies Latest reply on Nov 11, 2012 1:52 PM by Paul Hough
    Import single element from xml and place into active doc via text box
    Paul Hough
      I am working on an existing .indd file (press sheet) and need to add a text field with content that is stored in a xml file using Javascript in CS5.5. I can make a text box and add content to it but importing a XML and grabbing the value is just beyond my curent skill set. If someone could just push me in the right direction that would be great.
      Below is a sample of what the .xml file looks like I am trying to get the bolded string.
      ///// Start of XML ////////
      <field-list>
          <field Id="spMF_1_5">
              <tag>JbName</tag>
              <type>string</type>
              <required>false</required>
              <value>Test_3498349</value>
          </field>
      </field-list>
      //////// End of XML //////
        • 1. Re: Import single element from xml and place into active doc via text box
          Jump_Over Level 5
          In general, to import myFile, which is .xml to InDesign use:
          app.activeDocument.importXML(myFile);
          Regarding to your example,  desired value will be given by:
          app.activeDocument.xmlElements[0].xmlElements[0].xmlElements.itemByName("value").contents;
          hope it helps...
          • 2. Re: Import single element from xml and place into active doc via text box
            Paul Hough Level 1
            Thanks Jump_Over!!
            Here is the Problemt that I have I can import the XML element ino a textbox using;
            var FilterXML
            app.activeDocument.importXML(File.openDialog("Please choose XML File", FilterXML));
            app.activeDocument.pages[0].textFrames[0].parentStory.contents = app.activeDocument.xmlElements[0].xmlElements[0].xmlElements.itemByName("value").contents ;
            But when I replace the
            "File.openDialog("Please choose XML File", FilterXML)"
            with a file a file path (/HDD/Users/Me/dDescktop/test.xml) the same script fails. I am using a mac if that makes any differance at all.any help would be appreciated greatly!!
            Also I have tried using "app.activeDocument.pages[0].textFrames[0].parentStory.contents = FilterXML" to get the file path but this failed aswell
            Paul Hough
            • 3. Re: Import single element from xml and place into active doc via text box
              Paul Hough wrote:
              ..  when I replace the
              With what error? (Did you for example  forgot to add quotes around the path?)
              Just a random guess: Since CS4 or so, file operations got a bit more picky about what they expect -- a literal "File" object, and nothing as simple as 'a string that is a file path'. You could try this:
              app.activeDocument.importXML(File("/HDD/Users/Me/dDescktop/test.xml"));
              (I copied the path from your post. Is "dDescktop" really the name of an existing folder?)
              • 4. Re: Import single element from xml and place into active doc via text box
                Paul Hough Level 1
                Jongware,
                Thank you so much for your help!! the "app.activeDocument.importXML(File("/HDD/Users/Me/dDescktop/test.xml")) ;" does exactlly what I had intended.
                The file path in my post was just an example, but you are corect "dDesktop" would not have worked very well .... lol
