2 Replies Latest reply on Nov 7, 2012 7:43 AM by Grant H
    Exporting text.doc from an InDesign file
    hausnfranz1041
      Hello,
      I have about 400 pages, each with one textframe that is linked throughout all 400 pages. Each page also has a separate 'header' textframe that isn't linked. I need to export just the text from both of these textframes, but the headers need to somehow be "inserted" between each linked textframe on each page.
      I can easily copy/paste the entire linked textframe, it's getting the headers in there too that is the issue. Make sense?
        • 1. Re: Exporting text.doc from an InDesign file
          Jump_Over Level 5
          I think this is a good job for a script.
          I.e. like this:
          myDoc = app.activeDocument;
          myTextArr = new Array();
          var myTextStory = currHead = currText = "";
          for (k=0; k<myDoc.pages.length;k++) {
              for (f = 0; f<myDoc.pages[k].textFrames.length; f++)
                  switch (isLinked( myDoc.pages[k].textFrames[f] ) ) {
                      case true: {currText = myDoc.pages[k].textFrames[f].contents; break;}
                      case false: {currHead = myDoc.pages[k].textFrames[f].contents; break;}
                      default: {currHead = currText = ""; break;}
              if(currHead!=="") myTextArr.push(currHead);
              if(currText!=="") myTextArr.push(currText);
          myTextStory = myTextArr.join("\r");
          myFolder = "~/Desktop"               // You can edit this
          ExportFile = new File(myFolder + "/" + "InDesign_Export.txt");          // You can edit this
          ExportFile.open("w",undefined, undefined);
          ExportFile.write(myTextStory);
          ExportFile.close();
          function isLinked(myTF){
              if(!myTF.isValid) return -1;
              if(myTF.startTextFrame == myTF.endTextFrame) return false;
              else return true;
          It should be saved as .jsx file and placed in your Script Panel folder.
          To run - double click in InDesign script panel.
          hope...
          • 2. Re: Exporting text.doc from an InDesign file
            Grant H Level 4
            Why dont you export the document to PDF, then open the PDF,
            file>save as>microsoft word>word document.
            click settings in the Save As, dialogue box, and select retain flowing text, uncheck comments, uncheck Include Images, uncheck Run OCR. Click Ok
            G
