6 Replies Latest reply on Nov 7, 2012 7:18 AM by PeteComcar
    Why do Coldfusion structure key cases change depending on declaration style?
    PeteComcar Level 1
      In this simple component (test.cfc):
      component {
           VARIABLES.obj = {};
           VARIABLES.obj.foo = "bar";
           VARIABLES.obj['foo2'] = "bart";
          remote function func1() {
              return VARIABLES.obj;
      The response from the URL “/test.cfc?method=func1&returnformat=json” looks like this:
      • foo2: "bart",
      • FOO: "bar"
      Note that if you declare the property of a structure with dot notation, it is returned in uppercase. Using array like declarations returns it as you specified.
      This is still apparent when dumping a structure in a page, but is more of a problem when accessing the results via JSON in a Javascript appliation, as this is case sensitive.
      Pete
