5 Replies Latest reply on Nov 8, 2012 12:54 PM by StixandBones
    Changing aspect ratio
    StixandBones
      Is it possible to change the aspect ration of a comp and have all particulars, emitters, effects etc snap to new ratio? Example go from portrait to landscape?
      Thank you.
        • 1. Re: Changing aspect ratio
          Not off the bat. You can use the Comp Resizer script that comes with AE to do some of that, but many effects that use absolute values/ coordinates will have to be adjusted as will things like masks, placement of shape layers, text layers and so on. Of course some of that again could be automated/ facilitated with additional scripts or applying expressions that convert value ranges, but there will always be manual labour involved.
          Mylenium
          • 2. Re: Changing aspect ratio
            Dave LaRonde Level 6
            Portrait to landscape?  Precisely do you seek to do:
            1) rotate the work you've already done,
            2) somehow redistribute the layers, position points, etc. of your work into a different aspect ratio or
            3) something else
            Your query is confusing, and clarification will help people be more specific.
            • 3. Re: Changing aspect ratio
              StixandBones Level 1
              Well, I have a particular built light band zipping through the frame. The composition was 1280x720. I want to change it to 720x1280 and keep all my other settings as is. In other words, grab and migrate all the layers etc and move them around to fit the new comp format. I may be overthinking this. I could render out what I have with an alpha and do a new compostion I suppose but then I'd be stuck with that comp as it is. I was hoping there was a magic button/one step process.
              Thank you all for your responses.
              Here is a quick visual example. See how the particle effect is retaining the old comp format? Is there an easy way to change that to fit the new without rebuilding the particular?
              • 4. Re: Changing aspect ratio
                You can nest the 16x9 comp in the 9x16 comp and rotate it 90 degrees, then add whatever you want.
                • 5. Re: Changing aspect ratio
                  Thanks. I'll give it a shot.
