2 Replies Latest reply on Nov 8, 2012 6:59 PM by Janice Chia
    Issues on uploading file to design folder
    Janice Chia
      I'm having issue on uploading file (CSS/JS/Image) to website design folder under Tool module in CQ. It converted my uploaded file to sling:OrderedFolder where it should be physical js file. See attached image below.
      Please help.
        • 1. Re: Issues on uploading file to design folder
          rush_pawan Level 4
          I am not sure how you have uploaded the file but if you use 'new file' option to upload file then definately the system will store it as file (nt:file). I think you have used 'new folder' option (may be by mistake) which will create a folder 'sling:OrderedFolder' in system. Please try it again (also check error.log if it happens again) and if doesnt work then user CRXDE lite to create a new file with that name and just copy paste the data of your file (work around ). I hope this will help you to proceed.
          • 2. Re: Issues on uploading file to design folder
            Janice Chia Level 1
            Hi Rush,
            Yes, i'm using "New File" option. below is the screenshots. is this limitation for CQ5.5? i don't have this problem on CQ5.3. this upload will be useful for designer to update the website asset files.
