1. Re: CS6 Encore - No 16:9 with 1050 square pixel footage
SAFEHARBOR11 Nov 8, 2012 7:35 AM (in response to GeoffVane)Do you mean 1080i 50? Never ran into this issue with 1080i 29.97, maybe it is a PAL bug but then we would see the same complaint from others, which we're not seeing on the forums.
Could be something in the workflow, but really I'm not as big fan of dynamic link - like to have more control over parameters. Have you tried creating the "MPEG-2 for DVD" files directly from Premiere using Adobe Media Encoder. You can set the correct parameters and import the results into Encore, which should then leave those files alone and NOT do any transcoding of the video.
Also, where are you seeing the aspect being flipped - in Encore, or the burned disc? Please let us know the steps taken in your workflow so we can get this resolved.
Jeff Pulera
Safe Harbor Computers
2. Re: CS6 Encore - No 16:9 with 1050 square pixel footage
GeoffVane Nov 8, 2012 8:06 AM (in response to SAFEHARBOR11)PAL DV Square Pixel. 1050 x 576
I can't use dynamic link: it always crashes in all applications.
I won't use dynamic link for Encore: all sorts of auto functions often screw up the field quality.
When I encode, the aspect is stretched way too wide.
Both on screen and burned result.
Before encoding, everything looks fine.
All possible interpretation settings, provided to solve this, don't work.
I have to render anamorphic or I can't create a DVD.
I used Premiere to convert stuff. Sometimes I'll get "Don't transcode" but sometimes it just won't say that, no matter what you try.
3. Re: CS6 Encore - No 16:9 with 1050 square pixel footage
SAFEHARBOR11 Nov 8, 2012 8:19 AM (in response to GeoffVane)Hi Geoff,
Well now it is making more sense. Where are you getting 1050x576 source material? If shooting in SD wide, it ought to be 720x576 (anamorphic) out of the camera.
PAL DVD is always 720x576 (anamorphic for widescreen), so I can see where things are going to get distorted starting with a square pixel source. What is the Sequence setting in Premiere? I would think that if you put the 1050x576 video into a DV PAL Widescreen Sequence, then it would fill the screen and any subsequent exports would then keep the correct aspect.
So if the project is 1050x576, I think that would be the core of the issue, but you have not really shared the workflow yet so I don't know exactly the steps you are using
Jeff Pulera
4. Re: CS6 Encore - No 16:9 with 1050 square pixel footage
GeoffVane Nov 8, 2012 8:54 AM (in response to SAFEHARBOR11)1050 x 576 is the square pixel standard.
Encore should be able to handle that.
Why make interpret footage options if it ain't possible to work with square pixel?
5. Re: CS6 Encore - No 16:9 with 1050 square pixel footage
SAFEHARBOR11 Nov 8, 2012 12:12 PM (in response to GeoffVane)Hi Geoff,
I'm trying to be helpful, but could really use more info. As discussed, if you shot this on tape as widescreen SD, as far as I know it must have originated as anamorphic footage, which would make it 720x576. So I ask once more, where in the process did the footage become 1050x576? Need the workflow, or you're on your own...
Jeff
6. Re: CS6 Encore - No 16:9 with 1050 square pixel footage
Stan Jones Nov 8, 2012 6:59 PM (in response to GeoffVane)When I encode, the aspect is stretched way too wide.
It looks okay to me when I brought a sample in from AE. Are you sure you are applyig the custom transcode settings in encore?
I did not burn a disk, but you seem to say that it should look wrong in the preview.
7. Re: CS6 Encore - No 16:9 with 1050 square pixel footage
JSS1138 Nov 8, 2012 8:18 PM (in response to GeoffVane)1050 x 576 is the square pixel standard.
The problem is that the DVD specification itself can't handle that. Even Hollywood can't create such a DVD. You need 720 x 576 with a 1.4 PAR.
Because sometimes Encore doesn't get the memo that your 720 x 576 footage should have the widescreen PAR instead of the normal PAR. Interpret Footage forces that. But the input still needs to be 720 x 576.
8. Re: CS6 Encore - No 16:9 with 1050 square pixel footage
GeoffVane Nov 9, 2012 2:23 AM (in response to JSS1138)I know a DVD is always 720. For 16:9 and 4:3.
I don't understand your explanation about forced PARs: if my streams are always 720 then there is no need for PAR forcing options.
9. Re: CS6 Encore - No 16:9 with 1050 square pixel footage
Stan Jones Nov 9, 2012 5:23 AM (in response to JSS1138)But the input still needs to be 720 x 576.
The input doesn't need to be dvd spec; just the transcode that encore builds with. My issue here (and I haven't built to test it) is that my 1050x576 sample from AE was a) seen by encore as square pixel (it didn't need an interpret option) and b) a custom preset resulted in encore created the correct 720x576 video for output.
10. Re: CS6 Encore - No 16:9 with 1050 square pixel footage
GeoffVane Nov 9, 2012 5:40 AM (in response to Stan Jones)I tried all interpret settings and none were rendered correct after encoding.
11. Re: CS6 Encore - No 16:9 with 1050 square pixel footage
Stan Jones Nov 9, 2012 8:59 AM (in response to GeoffVane)I tried all interpret settings and none were rendered correct after encoding.
That is only one part of the equation. And, Encore interprets my 1050x576 (correctly) as square pixels. If it does not see yours as square, it makes me wonder whether yours are in fact correct.
Also, you can, for example, create a custom preset in Encore, but never apply the preset to the transcode setting for that clip. So the original could be correct, and it would still transcode wrong.
I would use mediainfo to look at your original and the transcode result from Encore (and the build version for that matter).
12. Re: CS6 Encore - No 16:9 with 1050 square pixel footage
GeoffVane Nov 9, 2012 9:10 AM (in response to Stan Jones)If it was just a hobby, you could question that.
Since I've been creating nothing but graphics since '97, you may assume I know how to render 1050 x 576 square pixel.
It's not that hard to select the right preset in AE.
Everything looks fine and corrected before encoding.
The encoding screws things up.
Hacking the automatic preset and changing it into something else, doesn't really help.
Plus if it would work, the automatic calculation for optimum disc filling will be gone.
I'll just rerender everything each time to anamorphic 720 as a workaround.
It's just unbelievable that Adobe programs function this poorly: version after version.
Only Photoshop and Lightroom are well made.
The rest is super shaky.
13. Re: CS6 Encore - No 16:9 with 1050 square pixel footage
Stan Jones Nov 9, 2012 9:22 AM (in response to GeoffVane)I'm not so much questioning your expertise as not understanding why my 1050x576 Square sample from AE is seen by Encore as square (and therefore interpret footage is not relevant), and yours is apparently not.
Using a custom preset does help, because it transcodes a DVD spec outcome. But no, you cannot apply such a preset and also use the Encore automatic setting.
