2 Replies Latest reply on Nov 8, 2012 10:20 AM by Paul Riggott
    Get the folder path and exclude the filename.
    adamfreestyle
      Hi guys,
      I am writing a ps script (in javascript) which involves the user navigating to and then selecting a file. The path of the file is then saved to a text file 'path.txt' and is called upon later in the script - for various reasons.
      For example:
      At the moment, when the file is navigated to and then selected, it will write to the text file:
      /h/Art/Textures/MainTexture.tga
      Up until now that is what i needed it to do, but now i need a slight modification.
      What i need is for it to just write:
      /h/Art/Textures
      - Excluding the filename.
      The code that i am currently using for this, is as follows:
      UpdatePaths.onClick=function() {
           saveFile = File.openDialog("Select the file you are working on:", "All Formats: *.*");
           var txtPath = new File("C:\\path.txt");
           txtPath.open('w');
           txtPath.writeln(saveFile);
           txtPath.close(1);
           fileDialog.close(1);
      Hopefully this is just an easy tweak?
      Any help would be much appreciated.
      Many thanks,
      Adam
