4 Replies Latest reply on Nov 12, 2012 5:24 AM by Siouxxx
    Changes only in text frames, not tables?
    Siouxxx
      I use a little script that loads saved searchqueries and execute them. The problem is: some corrections are only to do in textframes, not in tables. I don't know how to exclude tables so maybe someone here can help me? Here's the code:
      //start
      #target InDesign
      app.loadFindChangeQuery ('saved_query_text1', SearchModes.textSearch);
      app.activeDocument.changeText();
      app.loadFindChangeQuery ('saved_query_grep1', SearchModes.grepSearch);
      app.activeDocument.changeGrep();
      alert ("Finished");
      //end
        • 1. Re: Changes only in text frames, not tables?
          Jump_Over Level 5
          app.activeDocument.changeText();     // changeText() is proceeded in whole doc
          app.selection[0].changeText()     // changeText() area set to selection only;
          myTF.changeText()          // changeText() area set to text frame named "myTF";
          So your challange is to find a way to name your changeText() destination.
          It depends on your doc structure. If tables are in separated frames should be easy.
          But you have to say something about it.
          rgds
          • 2. Re: Changes only in text frames, not tables?
            Siouxxx Level 1
            Hi Jump_Over,
            Oh, I see. So every table in the document is in a separate frame.
            How can I select the textframes only? Must I use "switch" and then "parentTextFrames" or "parentStory"?
            And can I use "app.loadFindChangeQuery" for that?
            I think I have to build a loop instead of simply change all texts and define a var like "myTF", is that right?
            First many thanks for your helping
            Kindly regards
            Siouxxx
            • 3. Re: Changes only in text frames, not tables?
              Jump_Over Level 5
              So if we want to exclude textFrames with tables
              I suggest to proceed find/change procedure in 2 steps.
              1. myFound = myDoc.findText();
              You have an array with every findText() results.
              2. Hide changeText() into the loop statement:
              var k = myFound.length;
              while (k--)
                   if (myFound[k].parent.constructor.name !== "Cell")
                   myFound[k].changeText();
              This should change text only if its parent is not a table cell.
              hope...
              • 4. Re: Changes only in text frames, not tables?
                Siouxxx Level 1
                Thanks a lot, I will try asap.
                Kindly regards
                Siouxxx
