1 Reply Latest reply on Nov 9, 2012 1:28 PM by Steve Werner
    Interactive PDF, open file in new window.
    careington_cbs
      Hello everyone,
      I was unable to find this on the net or I could be using the wrong typed search. Created a successful interactive document. I attached a portfolio to this interactive document. I have 3 images. Two are hyperlinked to specific urls which work just fine. I have a sample button which opens the pdf. The only problem I have is that the pdf open in the current pdf window of the past file, so one has to reopen the original file again to access it. I could create a button on the portfolio webpage to go back to the original document, but that would be 20 buttons.
      Is there a way for someone to click on the sample button, but open up a new window like you would for a webpage?
      Right now the setup in the Buttons and Forms window:
      Sample button
      Type: button
      Event: On Release or Tap
      Open File - Checked
      Select File: current path
      PDF Options
      Description: Portfolio Samples
      Printable - Checked.
      That is pretty much it.
