1. Re: JPEGS Edit In P Pro But Errors In AME
Steven L. Gotz Nov 11, 2012 11:03 AM (in response to chuck farris)Tried dividing the second half into 2 quarters, neither encoded.
I think you were on the right track. Take a harder look. Split it into smaller sections. It might be just a single JPEG or a few of them that are causing a problem. Try harder to isolate them.
If you are using your render files during export, stop doing that. If you aren't - start. But delete all the cache files first and start over with a fresh render.
2. Re: JPEGS Edit In P Pro But Errors In AME
chuck farris Nov 11, 2012 11:12 AM (in response to Steven L. Gotz)Thanks for the quick reply, Steven. Will keep dividing by half til I reach the sub-atomic particle level ;^)
How do I do this? Thanks again.
3. Re: JPEGS Edit In P Pro But Errors In AME
Steven L. Gotz Nov 11, 2012 12:25 PM (in response to chuck farris)Start by going to Edit - Preferences - Media and clicking on the "Clean" button in the Media Cache Databse section. Note where the files are on your hard drive, close Premiere Pro and delete all the files in those directories.
That should clean up part of it. Then go into Project - Project Settings and on the Scratch Disks tap it should lead you to where your Video Previewsd and Audio Previews are. Delete any left over preview files.
4. Re: JPEGS Edit In P Pro But Errors In AME
JSS1138 Nov 11, 2012 3:56 PM (in response to chuck farris)Have you tried rendering the sequence yet? Does it also fail?
5. Re: JPEGS Edit In P Pro But Errors In AME
chuck farris Nov 11, 2012 5:41 PM (in response to JSS1138)Sequence was rendered in timeline, and was playing normally.
Was. Now seem to have new problems (since cleaning cache? Is that possible?). Difficlty playing in timeline and sending to AME.
Replaced many clips that seemed to be causing problems, though it was hard to confirm they were the cause.
Still ahngs up in AME after taking forever to get there...Thoughts???
6. Re: JPEGS Edit In P Pro But Errors In AME
JSS1138 Nov 11, 2012 6:21 PM (in response to chuck farris)Is the sequence still rendered? Green line above?
7. Re: JPEGS Edit In P Pro But Errors In AME
chuck farris Nov 11, 2012 7:38 PM (in response to JSS1138)Yes, green.
Editing new (2nd) sequence, so far so good, but still haven't successfully encoded the first...
8. Re: JPEGS Edit In P Pro But Errors In AME
Bill Hunt Nov 11, 2012 8:16 PM (in response to chuck farris)You have probably already looked overy this Adobe KB Article, but if not, then there might be some tips in it: http://helpx.adobe.com/premiere-pro/kb/error-compiling-movie-rendering-or.html
9. Re: JPEGS Edit In P Pro But Errors In AME
chuck farris Nov 11, 2012 8:53 PM (in response to Bill Hunt)I hadn't seen that Bill- thanks.
I think things are working now, but don't know what's different- I may have had Use Previews off, and now it's on?
Small low bitrate version finally came through, got a full version now- so far so good...
10. Re: JPEGS Edit In P Pro But Errors In AME
Bill Hunt Nov 12, 2012 7:54 AM (in response to chuck farris)so far so good...
Hope that it stays that way.
Thanks for reporting success, and good luck,
