1. Re: CS6 Font Selection Annoyance
shooternz Nov 11, 2012 12:25 PM (in response to John Ellenberger)What is the Font name that it is defaulting to?
2. Re: CS6 Font Selection Annoyance
John Ellenberger Nov 11, 2012 12:42 PM (in response to shooternz)ABSALOM / Regular / 100pt.
3. Re: CS6 Font Selection Annoyance
Steven L. Gotz Nov 11, 2012 12:49 PM (in response to John Ellenberger)I have a few styles I created, so I just click on the style and then click on the text tool, click into the title and start typing.
After you get the font the way you want it, select some of the text and create a new style. Then drag the icon for the new stle up to the top row of the style library. Save the library.
4. Re: CS6 Font Selection Annoyance
JSS1138 Nov 11, 2012 3:49 PM (in response to John Ellenberger)I have no problem changing the font first. (Windows 7 & 8)
List out the exact steps you take here.
5. Re: CS6 Font Selection Annoyance
Bill Hunt Nov 11, 2012 8:22 PM (in response to John Ellenberger)When you have created the first Title, with the Text, as you desire, just create a new Style.
For all later Titles, just apply that Style, to make all settings, what you have designed, just as Steven has done.
6. Re: CS6 Font Selection Annoyance
John Ellenberger Nov 12, 2012 3:26 AM (in response to JSS1138)I listed the "exact steps" in the original post.
7. Re: CS6 Font Selection Annoyance
Jon-M-Spear Nov 12, 2012 4:02 AM (in response to John Ellenberger)'Fraid that I don't have a solution, but I find it infurtating that Premiere has never offered a default font option. Mine always defaults to Abigail, even though I have never used it.
Photoshop and After Effects seem to save the last font used to the prefs file.
I feel a feature request coming on.
8. Re: CS6 Font Selection Annoyance
JSS1138 Nov 12, 2012 8:22 AM (in response to John Ellenberger)I listed the "exact steps" in the original post.
With insufficient detail. I mean every step, in sequence.
1. Open titler.
2. ...
3. ...
9. Re: CS6 Font Selection Annoyance
ScubaBadger Oct 18, 2013 4:20 AM (in response to John Ellenberger)I find this highly annoying too.
Yes - I can manually change the font selected - which on mine is "Abigail" (and to make it worse my version of Abigail is corrupt), but I shouldn't have to waste this time on every tile I make.
I would much prefer to be able to set my programme preferences to open new titles with my preferred font auto selected - not something that appears to be at random.
10. Re: CS6 Font Selection Annoyance
Cenpic Jan 30, 2014 1:21 PM (in response to John Ellenberger)This is how I removed Absalom from my font list:
To remove a font from the hard disk, follow these steps:
- Click Start, and then click Run.
- Type the following command, and then click OK:
%windir%\fonts
- Click the font that you want to remove. To select more than one font at a time, press and hold the CTRL key while you select each font.
- On the File menu, click Delete.
- When you receive the "Are you sure you want to delete these fonts?" prompt, click Yes.
Note You can prevent a font from loading without removing it from the hard disk. To do this, move the font from the Windows\Fonts folder to another folder.
