7 Replies Latest reply on Nov 12, 2012 11:58 AM by kglad
    Issue with visibiliy of dynamic text and hyperlinks
    Karim Bizid Level 1
      Hi everyone,
      It's been a while since I've build a Flash site and a I'm finding a out a lot has changed.
      I'm building a simple site with some pictures, text and the 5 last posts from Twitter.
      This last one is not working out that well.
      First of all:
      The outputed data from Twitter is displayed into a dynamic text field which is working fine when I test the movie in Flash, but as soon as I upload it to my server the text is not visible.
      Flash already told me that I need to enclose my font in the movie (that's new for me) and I did that using the button in the properties windows.
      But it still won't work.
      I recreated the Twitter reader in a empty document to isolate it from my website during the troubleshooting.
      Here's the AS I'm using:
      var loadXML:XML = new XML();
          loadXML.ignoreWhite = true;
          loadXML.onLoad = processXML;
          loadXML.load("twitter.php"); //used when swf in placed on server
          loadXML.load("");
          function processXML(loaded:Boolean)
              if(loaded)
                  var node = this.firstChild;
                  tweet_1.text = node.childNodes[0].childNodes[2].firstChild;
                  tweet_2.text = node.childNodes[1].childNodes[2].firstChild;
                  tweet_3.text = node.childNodes[2].childNodes[2].firstChild;
                  tweet_4.text = node.childNodes[3].childNodes[2].firstChild;
                  var follower_count = node.childNodes[9].childNodes[11].childNodes[9].firstChild;// Creates variable
                  trace(follower_count); //loads variable into output
                  follower_count_txt.text = follower_count;// show follower count in text box
              else
                  error_txt.text = "Error loading XML file";
                          for (i=0; i<follower_count; i++)
                              _root.attachMovie("tweep_mc", "tweep"+i+"_mc", i);
                              _root["tweep"+i+"_mc"]._x = 150 + random(500);
                              _root["tweep"+i+"_mc"]._y = 150 + random(500);
                              trace(i);
                          trace(i);
          follow_btn.onRelease = function()
              getURL("");
      facebook_btn.onRelease = function()
              getURL("");
      stop();
      Right here you can see the output of it on the server.
      The second issue:
      The items posted to Twitter will simply always contain pictures which Twitter posts as hyperlinks.
      Is there a way to make those hyperlinks function in my dynamic text field?
      Hope you guys can help me out!
      Thanks in advance!!
      Karim
