1. Re: New PC, White Backgrounds opening Yellow?
gator soup Nov 12, 2012 4:55 PM (in response to woodwizer)white appears yellow in Photoshop is a sure sign your OS default monitor profile is off
Windows default monitor profile is set in Control Panels> Color Management> Devices tab> check Use my settings for this device> set your custom monitor profile "(default)" as pictured in screenshot:
but i hope you don't mean you selected your monitor profile in Edit> Color Settings> Working Spaces> RGB: monitor profile -- that should be sRGB (as a start like this, with these Color Management Policies in place):
that will help ensure you are using the correct Source Profile on your documents and warn you of missing profiles and profile mismatches
IN OTHER WORDS
you need to 'calibrate' a good monitor profile
get it set as the Default in Windows
and configure Photoshop Color Settings to use the correct profiles (or warn you of problems that could be causing some of the problems you describe)...
