2 Replies Latest reply on Nov 13, 2012 12:25 PM by CristianDR
    Play SWF in Catalyst
    CristianDR Level 1
      I need to know how to make an SWF file i made to reproduce none stop in catalyst.
      The idea is to make an initial portal to my web where there is an animation runing and an enter button where to click to get inside the website.
      How can i do this? I have imported the swf file to catalyst but when i try to make it play i don't get any results, the animation does not even show.
        • 1. Re: Play SWF in Catalyst
          Chris W. Griffith Adobe Community Professional
          First you need to look at the On Application Start event trigger, then choose Play Action Sequence. Now select your animation on the stage, then select the Timeline panel. Click the Add Action button. You can then select the Play menu choice to play your animation.
          However, I would HIGHLY recomment that you do not use Flash Catalyst in this manner. The product has been discontinued by Adobe, so you issues with your projects at some later date. Also, the project will not work on any iOS device or any newer Android device. I would recommend that you look at using web standards for your project. If the animation is complex, look at Toolkit for Create.js extenstion for Flash to convert your Flash animation to a HTML5 based version. Or you could look at Edge Animate to rebuild your animation.
          Chris Griffith
          • 2. Re: Play SWF in Catalyst
            CristianDR Level 1
            Chris the idea was later use Dreamwaver to construct the site.
            So now i get they are discontinuating the catalyst, bumer!!!
            What would u suggest me to use to build the website then? Dreamwaver, Flash, any other soft?
