5 Replies Latest reply on Nov 13, 2012 9:51 AM by Marc Autret
    How can I set width or height of an object?
    PanDulka
      Hi Guys,
      is there a simple method to set a width/height of an object in absolute values without messing with .geometricBounds?
      Something like this:
      app.activeDocument.selection [0].width = "150 mm";
      or
      app.activeDocument.selection [0].width("150 mm", ConstrainProportion.Yes, AnchorPoint.bottomLeftAnchor);
      The object is in my case usually a vector graphic copied out of Illustrator.
      PanDulka
        • 1. Re: How can I set width or height of an object?
          @PanDulka – I would recommend reading the following blog post:
          Marc Autret
          Work Around the Width/Height Gap
          http://www.indiscripts.com/post/2009/10/work-around-the-width-height-gap
          Uwe
          • 2. Re: How can I set width or height of an object?
            Marc Autret Level 4
            However my article only considers the question "How to GET the size?", not "How to SET the size".
            Now to answer the original question, I think PageItem.resize() is the way to go.
            function setWidthHeight(/*PageItem*/o, /*str*/w, /*str*/h, /*bool=false*/useVisibleBounds)
                if( !o.resize ) return;
                var CS_INNER = CoordinateSpaces.INNER_COORDINATES,
                    BB = BoundingBoxLimits[(useVisibleBounds?'OUTER_STROKE':'GEOMETRIC_PATH') + '_BOUNDS'];
                var wPt = UnitValue(w).as('pt'),
                    hPt = UnitValue(h).as('pt');
                if( 0 >= wPt || 0 >= hPt ) return;
                o.resize(
                    [CS_INNER,BB],
                    AnchorPoint.CENTER_ANCHOR,
                    ResizeMethods.REPLACING_CURRENT_DIMENSIONS_WITH,
                    [wPt,hPt,CS_INNER]
            // Sample code
            setWidthHeight(app.selection[0], "5cm", "50pt");
            Marc
            • 3. Re: How can I set width or height of an object?
              @Marc – thank you for sharing this function. Very interesting…
              Especially the "BoundingBoxLimits" declaration where you make the distinction between visibleBounds and geometricBounds in one line.
              Never thought of using enumerators like this. Great.
              Uwe
              • 4. Re: How can I set width or height of an object?
                PanDulka Level 1
                Hi Marck,
                thank you for your quick reply. The function looks great but I forgot to mention that I still use InDesign CS3 that does not support PageItem.resize() method. Resize seems to be supported from in CS4 and above.
                Don't you have by any chance version for CS3?
                PanDulka
                • 5. Re: How can I set width or height of an object?
                  Marc Autret Level 4
                  In that case we need to use the PageItem.transform() method in a very special way.
                  Try this:
                  function setWidthHeightCS3(/*PageItem*/o, /*str*/w, /*str*/h, /*bool=false*/useVisibleBounds)
                      if( !o.transform) return;
                      var wsBkp = app.transformPreferences.whenScaling,
                          a = o.resolve([[1,1], BB], CS_INNER)[0].
                              concat(o.resolve([[0,0], BB], CS_INNER)[0]),
                          sx = wPt / (a[2]-a[0]),
                          sy = hPt / (a[3]-a[1]);
                      app.transformPreferences.whenScaling = WhenScalingOptions.APPLY_TO_CONTENT;
                      o.transform(
                          CS_INNER,
                          [sx,0,0,sy,0,0],
                          MatrixContent.SCALE_VALUES
                      app.transformPreferences.whenScaling = wsBkp;
                  // Sample code
                  setWidthHeightCS3(app.selection[0], "5cm", "100pt");
                  Marc
