1 Reply Latest reply on Jan 4, 2016 8:22 AM by AJDValien
    Failed to export the JPEG file: Maximum size exceeded
    niekname
      When exporting a page to JPEG you might get the following error message:
      "Failed to export the JPEG file: Maximum size exceeded. Try decreasing the resolution."
      After some research I believe this maximum size for the resulting JPEG is set to 32767 pixels. This is the maximum value of a signed short.
      Anyone can verify if this is correct?
      Another similar error message you might get is:
      "Failed to export the JPEG file: Not enough memory. Try decreasing the resolution."
      I would like to know how this limit is calculated.
      Test case:
      InDesign document of 2000 mm x 2000 mm
          Export JPEG, format method 'BASELINE', dpi 416
                -> result preview of 32756 pixels     (2000 mm = 78,740157 inch * 416 dpi = 32756 pixels)
                => preview is exported
           Export JPEG, format method 'BASELINE', dpi 417
                -> "Failed to export the JPEG file: Maximum size exceeded. Try decreasing the resolution."
                => max size exceeded
           Export JPEG, format method 'PROGRESSIVE', dpi 416
                -> "Failed to export the JPEG file: Not enough memory. Try decreasing the resolution."
                => Within the max size boundaries, but not within the max memory boundaries. How is this calculated?
           Export JPEG, format method 'PROGRESSIVE', dpi 225
           Export JPEG, format method 'PROGRESSIVE', dpi 224
