3 Replies Latest reply on Nov 13, 2012 9:21 AM by Rick Gerard
    resolution
    David Mardones
      We are working on a project with 47 projectors and would like to make a continuous panoramic image. The problem is that the resolution of the screen is 48.128x768 and After Effects has a Limete of 30.000pixel. You can make a compocicion of 48.128x768  pixels?
        • 1. Re: resolution
          Todd_Kopriva Level 8
          No, you can't make a single composition with a width or height greater than 30,000 pixels.
          • 2. Re: resolution
            Dave LaRonde Level 6
            Your description leads me to think that this is a message that runs around an indoor arena on a very long and narrow digital scoreboard.  The reason for my suspiciaon is that there is NO projector that can work at 48 vertical pixels.  Furthermore, there may be no arena display systems that are even able to play back a display of 48,128 horizontal pixels.  They usually need displays that aren't as wide, but are crafted to look as if they are a single continuous strip.
            You should check with your client for the delivery specifications needed by the arena's playback equipment.
            • 3. Re: resolution
              I would layout your comp at 1/2 or 1/4 size exactly, then split it up into 47 different comps I would then run the resize composition script on the 47 new comps to make them full size. This way you can fall well within the max horizontal resolution of AE and still render out full resolution clips.
              I hope you followed that logic. What ever way you try this project it's going to take a bunch of system resources to pull it off.
