2 Replies Latest reply on Nov 15, 2012 6:08 AM by dav_sa
    Smartimage is not displayed
    dav_sa
      I  am creating a custom widget and i would like it to have a smartimage inside, I instantiated in this way:
      var form = new CQ.Ext.form.FormPanel({
                  title: 'Form Layout',
                  bodyStyle: 'padding:15px',
                  width: 650,
                  defaults: {
                      msgTarget: 'side'
                  items: [{
                      fieldLabel: 'First Name',
                      allowBlank: false,
                      labelSeparator: ':' // override labelSeparator layout config
                      height:250,
                      title:'Frame Image',
                      ddGroups:'media',
                      fileNameParameter:'./fileName',
                      fileReferenceParameter:'./fileReference',
                      xtype:'smartimage'
                  buttons: [
                      {text: 'Save'},
                      {text: 'Cancel'}
                  layoutConfig: {
                      labelSeparator: '~' // superseded by assignment below
                  // config options applicable to container when layout='form':
                  hideLabels: false,
                  labelAlign: 'left',   // or 'right' or 'top'
                  labelSeparator: '>>', // takes precedence over layoutConfig value
                  labelWidth: 65,       // defaults to 100
                  labelPad: 8           // defaults to 5, must specify labelWidth to be honored
      i just can see a blank space, what coul be the problem?
        • 1. Re: Smartimage is not displayed
          rush_pawan Level 4
          First of all 'smartimage' widget should not be under panel and require other properties to be set. But i would suggest to refer slideshow widget (xtype) to design your new widget '/libs/cq/ui/widgets/source/widgets/form/Slideshow.js'
          please let me know if you need any help.
          • 2. Re: Smartimage is not displayed
            dav_sa Level 1
            thank you for the answer, i have already seen the slideshow widget, the thing is that this widget extends of smartimage, so it make the things easier, i need to extend composite field.
            I read the documentation and says that you can put an smartimage into a FormLayout, thats why I put it under panel.
            thanks
