2 Replies Latest reply on Nov 14, 2012 7:02 AM by jagan18
    Calculating age based on DOB
    jagan18
      Need to calculate a user age base on DOB field using AcroForms Javascript?
        • 1. Re: Calculating age based on DOB
          From today some other date?
          And what do you want returned? Years only, years and months, years months and days, days, or other time value?
          Assuming you are using Acrobat and not LiveCycle Designer:
          // get dob string value of the DOB field
          var sDob = this.getField("DOB").value;
          // convert to date object
          var oDob = util.scand("dd-mmm-yyyy", sDob);
          // convert to milliseconds since Epoch date
          var nDob = oDob.getTime();
          // todays date in milliseconds since Epoch date
          var nToday =  (new Date()).getTime();
          // compute difference including end date
          var nDiff = nToday - (nDob + (1000 * 60 * 60 * 24)) ;
          // compute output in whole years
          event.value = Math.floor(nDiff / (1000 * 60 * 60 * 24 * 365.2425))
          • 2. Re: Calculating age based on DOB
            jagan18 Level 1
            Thanks, I was looking for it in years only.  I have a form in adobe acrobat with a DOB text box "mm/dd/yyyy" format.  Then I have a second text field that is the "age"  field, in which I need the user age to populate.  I was thinking on using the "on blur" action to fire the code and calculation javascript.  I know I can use the calculation custom script but was unsure how it fired the code.  Thanks for your respone and help.
