2 Replies Latest reply on Nov 13, 2012 7:31 PM by alexdejesus
    Is It Possible To Reposition Multiple Sequence Markers?
    alexdejesus Level 1
      I'm woking a project where I had to split a long sequence into two so that it would fit into a DVD. But there are dozens of sequence markers that need to be moved along with the ripple edited half of the sequence. Dynamically linked in Encore. I have read a post on this issue dating back to 2007.  Was hoping this feature was available in CS6
      I just realized, however, that the linked Encore chapter markers do ripple edit. If you don't ripple delete the gap in Premiere left by splitting the long sequence, you can still trim the empty part of the Encore timeline and slide to the zero point and the chapter markers follow. So, the problem is partly solved, except chapter markers timecodes will not match the corresponding markers in Premiere.
      I know that some people add Encore markers last after editing is completed. Still, I would like to be able to select multiple markers in Premiere or have them ripple as I make edits.
