2 Replies Latest reply on Nov 15, 2012 12:37 AM by Aiesyaah
    Drag and drop for Tablet
    Aiesyaah
      Hi!
      I am working on an existing drag and drop animation which uses the mouse to move. The animation is being done in Adobe Edge. The animation works fine in the browser (using the mouse for the drag and drop). I want to make the animation to work on tablets, therefore, I will need to use the events: touchstart, touchmove and touchend.
      I managed to make to symbols drag around on the stage. However, all the symbols gets dragged together as a bunch. Also, the reset button does not seem to work in the tablet. How do I edit the codes for the reset button for the tablet?
      There would not be any conflict between the animation working in the browser and tablet, right? Does anyone have any basic drag and drop using tablet that involves several symbols and a reset button? Something I can refer to for my work?
      Thank you.
        • 1. Re: Drag and drop for Tablet
          Aiesyaah Level 1
          This is my codes for the drag and drop using the mouse (on the web browser).
          Model = function(datas){
                           this.defaultDatas ={
                               draggables :
                               droppables :
                                     dropout:'start',
                                     drop:'drop',
                                     dropover:'dropover'
                                     dropout:'start',
                                     drop:'drop',
                                     dropover:'dropover'
                                     dropout:'start',
                                     drop:'drop',
                                     dropover:'dropover'
                                     dropout:'start',
                                     drop:'drop',
                                     dropover:'dropover'
                                     dropout:'start',
                                     drop:'drop',
                                     dropover:'dropover'
                                     dropout:'start',
                                     drop:'drop',
                                     dropover:'dropover'
                                     dropout:'start',
                                     drop:'drop',
                                     dropover:'dropover'
                                     dropout:'start',
                                     drop:'drop',
                                     dropover:'dropover'
                                     dropout:'start',
                                     drop:'drop',
                                     dropover:'dropover'
                               dropOptions : {}
                   };//end of default values
                               var _datas = $.extend(this.defaultDatas,datas);
                               sym.$("data-div").data("model",{"itemDragged":"none","theme1":"000","theme2":"000","theme 3":"000","dropConfirm":"none"});
                               this.get=function(property){
                                    // forbid ojects to be passed as references by serializing de-serializing the prop.
                                    return JSON.parse(JSON.stringify(_datas[property]));
                               };// end get
                               this.set=function(property,value){
                                    _datas[property] = value ;
                               };//end set
          };//end of model
          Controller = function(model){
                       this.model = model;
                         this.setItemDragged = function (inval){
                              var values = sym.$("data-div").data("model");
                              values.itemDragged = inval;
                              sym.$("data-div").data("model",values);
                       this.setTheme = function (num,inval){
                              var theme = "none";
                               if(num==="1"){
                                        theme = values.theme1;
                               }else if(num==="2"){
                                        theme = values.theme2;
                               }else if(num==="3"){
                                        theme = values.theme3;
                               var num1 = parseInt(theme.substring(1,2));
                               var num2 = parseInt(theme.substring(2,3));
                               var num0 = 0;
                               if(inval>num2){
                                        num0 = num1;
                                        num1 = num2;
                                        num2 = inval;
                               }else if(inval>num1){
                                        num0 = num1;
                                        num1 = inval;
                               }else{
                                        num0 = inval;
                               theme = num0.toString()+num1.toString()+num2.toString();
                               if(num==="1"){
                                        values.theme1=theme;
                                        values.theme2=theme;
                                        values.theme3=theme;
                       this.dropConfirm = function (inval){
                              values["dropConfirm"] = inval;
                           // sym.$(inval).css({"left":220,"top":154});
                          return values[property];
                       }//end of get
                       var _this = this;
                       $(this).bind("setItemDragged",this.setItemDragged);
                       $(this).bind("setTheme",this.setTheme);
          };//end ctrller
          main = function(sym,w){
                       sym.play();
                       sym.$("stage").css("margin","auto");
                       sym.stop();
                       w.model = new Model({});
                       w.controller = new Controller(model);
                       $.getScript("http://ajax.googleapis.com/ajax/libs/jqueryui/1.8.9/jquery-ui.min.js",onJqueryUILoad);
          };//end
          onJqueryUILoad = function(e){
                       // EN : when the script is loaded
                       viewInit(sym);
          viewInit = function(sym){
                       var a = 3;
                       var counter = 0;
                       //draggable event
                       $.each(model.get("draggables"),function(){
                           var _this = this ;
                           //when drag is started, this event is called
                         if(_this.name=="_1"){
                                                  sym.$(_this.name).draggable(
                                                             helper: "clone",
                                                            revert: "invalid",
                                                            start: function(event, ui) {
        $(this).css("z-index", a++);
        sym.$(_this.name).hide();
                                                            },//end start
                                                            stop: function(event, ui) {
        if(controller.get("dropConfirm")!=_this.name){
        sym.$(_this.name).show();
                                                            cursor: "crosshair",
                                                            cursorAt: { left:60,bottom:85},
                                                            opacity: 0.8
                              }else if(_this.name=="_2"){
                                                             helper: "clone",
                                                            revert: "invalid",
                                                            },//end start
                                                            cursorAt: { left:100,bottom:120 },
                                                            opacity: 0.8
                              }else if(_this.name=="_3"){
                                                             helper: "clone",
                                                            revert: "invalid",
                                                            },//end start
                                                            cursorAt: { left:120,bottom:110 },
                                                            opacity: 0.8
                              }else if(_this.name=="_4"){
                                                             helper: "clone",
                                                            revert: "invalid",
                                                            },//end start
                                                            cursorAt: { left:80,bottom:80 },
                                                            opacity: 0.8
                              }else if(_this.name=="_5"){
                                                             helper: "clone",
                                                            revert: "invalid",
                                                            },//end start
                                                            cursorAt: { left:90,bottom:75 },
                                                            opacity: 0.8
                              }else if(_this.name=="_6"){
                                                             helper: "clone",
                                                            revert: "invalid",
                                                            },//end start
                                                            cursorAt: { left:100,bottom:100 },
                                                            opacity: 0.8
                              }else if(_this.name=="_7"){
                                                             helper: "clone",
                                                            revert: "invalid",
                                                            },//end start
                                                            cursorAt: { left:65,bottom:120 },
                                                            opacity: 0.8
                              }else if(_this.name=="_8"){
                                                             helper: "clone",
                                                            revert: "invalid",
                                                            },//end start
                                                            cursorAt: { left:80,bottom:130 },
                                                            opacity: 0.8
                              }else if(_this.name=="_9"){
                                                             helper: "clone",
                                                            revert: "invalid",
                                                            },//end start
                                                            cursorAt: { left:70,bottom:80 },
                                                            opacity: 0.8
                           sym.$(_this.name).bind( "drag", function(event, ui) {
                                        controller.setItemDragged(_this.name);
                              });// end bind
                       });//end each draggable
                       $.each(model.get("droppables"),function(){
                           var _this = this;
                           sym.$(_this.name).droppable({ greedy:true,tolerance:"pointer"});
                           sym.$(_this.name).bind("drop",function(event,ui){
                                        var itemDragged = controller.get("itemDragged");
                                        //play animation
                                        sym.getComposition().getStage().getSymbol(_this.name).play(itemDragged);
                                        //sym.$(itemDragged).draggable("option", "disabled", true );
                                        //disable the droppable
                                        sym.$(_this.name).droppable("option", "disabled", true );
                                        //get the position num
                                        var item = parseInt(itemDragged.substring(1,2));//item num
                                        var position = parseInt(_this.name.substring(8,9));//position num
                                        //console.log(_this.name.substring(8,9));
                                        if(position<=3) {//update theme1
                                                  sym.$("category-label1").hide();
                                                  controller.setTheme("1",item);
                                        }else if(position<=6){//update theme1
                                                  sym.$("category-label2").hide();
                                                  controller.setTheme("2",item);
                                        }else if(position<=9){//update theme1
                                                  sym.$("category-label3").hide();
                                                  controller.setTheme("3",item);
                                        var theme1 = controller.get("theme1");
                                        var theme2 = controller.get("theme2");
                                        var theme3 = controller.get("theme3");
                                        if(theme1.indexOf("0")==-1&&theme2.indexOf("0")==-1&&theme3.indexOf("0")== -1){
                                                  dif1 = parseInt(theme1.substring(1,2))-parseInt(theme1.substring(0,1));
                                                  dif2 = parseInt(theme1.substring(2,3))-parseInt(theme1.substring(1,2));
                                                  dif3 = parseInt(theme2.substring(1,2))-parseInt(theme2.substring(0,1));
                                                  dif4 = parseInt(theme2.substring(2,3))-parseInt(theme2.substring(1,2));
                                                  dif5 = parseInt(theme3.substring(1,2))-parseInt(theme3.substring(0,1));
                                                  dif6 = parseInt(theme3.substring(2,3))-parseInt(theme3.substring(1,2));
                                                  if(dif1==dif2&&dif2==dif3&&dif3==dif4&&dif4==dif5&&dif5==dif6&&dif6== 3){
                                                            sym.getComposition().getStage().getSymbol("feedback").play("sugg est");
                                                  }else if(dif1==dif2&&dif2==dif3&&dif3==dif4&&dif4==dif5&&dif5==dif6&&dif6==1){
                                                            sym.getComposition().getStage().getSymbol("feedback").play("corr ect");
                                                  }else {
                                                            sym.getComposition().getStage().getSymbol("feedback").play("wron g");
                                        }else{//hasn't completed yet
                                        controller.dropConfirm(controller.get("itemDragged"));
                           });//end bind
                       });//end each
          };//end viewInit
          main(sym,window);
          // insert code here
