2 Replies Latest reply on Mar 22, 2010 2:01 PM by blm_webman_069
    Problems using LDAPS
    ensanian
      I currently have CPS setup for user authentication against an LDAP server I have. currently it uses the standard port 389 and works fine (address format of "ldap://myserver.ldap.edu") Using the technotes document on configuring CPS to use LDAPS, I have imported my ldap servers certificate into the truststore. I then change the address of my ldap server to simply "ldaps://myserver.ldap.edu" - however upon testing and trying a search for a user, i get the following error: Error connecting to the LDAP server. If I go back and remove the 's' from the server address, forcing unsecure port 389, it works fine. Ideas? Anyone else have this issue? Any help is appreciated.
