1. Re: RH9 slow to load and close
Peter Grainge Nov 14, 2012 12:01 PM (in response to argus08)You say "Recently upgraded from RH8 to RH10 because I needed RH9 for a particular client project" but you don't say anything about installing 9.
Assuming you have installed 9, when? Before or after 10?
Given something went wrong with the registry I think I would be inclined to uninstall all versions of Rh and then reinstall them in the correct order, earliest first. It might be worth uninstalling using RevoUninstaller to uninstall as that cleans more registry entries. Only use it if you are confident using such programs, if not involve your IT people.
Did Google pin the blame on Pure Text causing the registry problem or simply suggest it was a registry error? I know several people using Pure Text without any problems.
2. Re: RH9 slow to load and close
argus08 Nov 14, 2012 12:22 PM (in response to Peter Grainge)Hi Peter
I don’t remember now if I installed 9 before 10 (purchased together). I’ll try your suggestion.
I didn’t google PureText as a cause of the problem because I had been using it without problem for a few weeks. I only googled re the loss of the program menu, although that could have happened earlier and I just never noticed it (I use desktop icons for the apps/docs I use most). So the Google results mentioning registry problems were referring to the program menu. I only decided to delete PureText because I no longer needed it and I was curious if that was the culprit, being the newest kid on my PC block.
My IT people, that’s funny – that would be me. L I muddle through as best as I can, relying on dear ol’ Google and Adobe forums!
Laurie
3. Re: RH9 slow to load and close
Peter Grainge Nov 14, 2012 12:32 PM (in response to argus08)RevoUninstaller is reasonably intuitive. It first uninstalls using the programs uninstaller and then it does some extra work. At that stage make sure you only delete whatever it has highlighted bold.
The problem when giving answers is knowing just how PC savvie someone is.
4. Re: RH9 slow to load and close
argus08 Nov 27, 2012 11:42 AM (in response to Peter Grainge)I finally took the time to uninstall everything with RevoUninstaller, then reinstalled TCS1, RH8, RH9. I'm leaving RH10 until I get RH9 working properly. RH9 is still not loading in good time. I uninstalled it again, downloaded the setup files again, and this time chose to include Robohelp for Word in the installation (although there's no earthly reason it should make a difference).
Still having the same problem: I get the splash screen immediately, then the app frame appears, but remains white. The splash screen stalls at Loading Components but remains open. Actually, it's now worse - before it opened after 10 minutes - now it's been 33 minutes and I gave up and force-closed it.
RH8 and RH10 (before I uninstalled it) both opened and closed without a problem.
I'd love to just use RH10, but a client is using RH9 for minor updates so I have to keep their project in RH9.
5. Re: RH9 slow to load and close
argus08 Nov 27, 2012 11:55 AM (in response to argus08)I've found another post that didn't quite apply but pointed me to the Adobe Support, I'm going to try them now, will post back.
6. Re: RH9 slow to load and close
argus08 Nov 28, 2012 6:22 AM (in response to argus08)Grrr...not a happy camper. Adobe Support could only recommend that I uninstall all Adobe products and then install RH9 and see if that works. I flipped. I already wasted an entire day uninstalling and reinstalling everything. He said that sometimes a .dll may be in conflict with another version and it's completely random which computers it affects. I couldn't believe this has not been an issue before with the volume of customers running multiple versions. So I installed it on my laptop where it runs fine.
This is not ideal, because I cannot access our server from the laptop and will have to copy the project back and forth for backup purposes, and the client software I'm documenting is on another computer so any screenshots will have to be managed via Dropbox. But after the current round of updates, I don't expect to have to work on this project for at least another year, and I can use RH10 for everyone else. So I don't love it, but at least I can work.
7. Re: RH9 slow to load and close
Peter Grainge Nov 28, 2012 6:37 AM (in response to argus08)Doesn't the random nature and the fact the problem does not occur on your laptop suggest the problem is being connected to the network? Have you tried running a work PC with the network cable pulled out?
The other possibility is the different virus checker / virus checker settings. Some years back a new virus checker was installed here and it ground me to a halt at times. The guys set it to be less aggressive and we all lived happily ever after.
8. Re: RH9 slow to load and close
argus08 Nov 28, 2012 8:45 AM (in response to Peter Grainge)I unplugged my network cable and tried launching, no change. I disabled my anti-virus, no change.
Like I said, I'm not happy, but I'm not dead in the water, I do have RH10 for most projects, and the RH9 one is in review stage so it will be finished for at least a year soon enough. And maybe I'll be able to convince them to upgrade to RH10!
9. Re: RH9 slow to load and close
Jeff_Coatsworth Nov 28, 2012 8:56 AM (in response to argus08)You’ve got to have something specific to your environment as nobody else was getting this happening that I’ve ever heard.
10. Re: RH9 slow to load and close
argus08 Nov 28, 2012 8:58 AM (in response to Jeff_Coatsworth)Yeah, so it would seem. Just strange that I have no trouble running any other version.
