0 Replies Latest reply on Nov 14, 2012 11:50 AM by JVM-
    Unknown Problem with long String
    JVM-
      We purchased code from a third paty, but it wouldn't compile on our systems. After much debugging the source was found. The below code causes an "Unknown Problem" on our systems (with no further details).
      Is it possible for someone else to compile the below Test.as and see what the results are?
      On our systems the below code throws an "Unknown Problem" error
      Removing two of the repeated lines (shortening it by two lines) compiles without error.
      JVM
      package
          public class Test
              public function generateCode():String
                  // Generate styles
                  var toReturn:String = "";
                  var test:String = "";
                  // Add properties
                  toReturn = "test=\"" + test + "\"\n" +
                      "test=\"" + test + "\"\n" + // 10
                      "test=\"" + test + "\"\n" + // 20
                      "test=\"" + test + "\"\n" + // 30
                      "test=\"" + test + "\"\n" + // 40
                      "test=\"" + test + "\"\n" + // 50
                      "test=\"" + test + "\"\n" + // 51
                      "test=\"" + test + "\"\n" + // 52
                      "test=\"" + test + "\"\n" + // 53
                      "test=\"" + test + "\"\n" + // 54
                      "test=\"" + test + "\"\n" + // 55
                      "test=\"" + test + "\"\n" + // 56
                      "test=\"" + test + "\"\n" + // 57
                      "test=\"" + test + "\"\n" + // 58
                      "test=\"" + test + "\"\n" + // 59
                      "test=\"" + test + "\"\n";    // 60
                  return toReturn;
