1. Re: Can't stop recording in Captivate 6/Mac
Anjaneai Srivastava Nov 15, 2012 9:22 AM (in response to Rakshi_707)Did you use Cmd + Enter or Cmd + Return?
Also, try changing the Shortcut to something else, like Cmd+A or Shift+Q and see if this works in a New reocrding?
Anjaneai
2. Re: Can't stop recording in Captivate 6/Mac
Rakshi_707 Nov 15, 2012 11:14 AM (in response to Anjaneai Srivastava)Hi Anjaneai,
Thanks for your interest. I tried Cmd + Enter, Cmd + Return, and every other random combination and function key I could think of, to no effect.
I was unable to change the shortcut keys in Preferences. The fields are uneditable.
Thanks!
3. Re: Can't stop recording in Captivate 6/Mac
Anjaneai Srivastava Nov 15, 2012 11:30 AM (in response to Rakshi_707)btw, you can end your recording by clicking on Captivate icon in your dock.
I am able to change the shortcut key in Preferences panel.
4. Re: Can't stop recording in Captivate 6/Mac
RodWard Nov 15, 2012 11:36 AM (in response to Rakshi_707)Rakshi,
Sounds like you may need to delete/rename your Preference folder so that Captivate restores it on next bootup. Your Preferences folder may be corrupt.
5. Re: Can't stop recording in Captivate 6/Mac
Rakshi_707 Nov 15, 2012 12:25 PM (in response to RodWard)Clicking the Captivate icon does not work. I don't know why I can't change the shortcut key, I was able to do so in my previous version of Captivate.
How do I delete/rename my Preferences folder? I could not find it in my Captivate folder. I found a utility called "Clean Preferences" and I used it, but it did not help.
Maybe I should uninstall and reinstall Captivate?
6. Re: Can't stop recording in Captivate 6/Mac
Anjaneai Srivastava Nov 15, 2012 12:29 PM (in response to Rakshi_707)Try this--
Open Finder-- Go to Folder-- "~/Library/Preferences/Adobe Captivate 6", rename this folder and make sure you have closed the Captivate first, relaunch and the try chnaging shortcut again.
7. Re: Can't stop recording in Captivate 6/Mac
Rakshi_707 Nov 15, 2012 12:47 PM (in response to Anjaneai Srivastava)Still can't find the Preferences folder. The method you suggested opened a window with 9 random files and folders in Captivate (backup_data, Themes, Workspace etc.), but none are Preferences.
8. Re: Can't stop recording in Captivate 6/Mac
RodWard Nov 15, 2012 9:05 PM (in response to Rakshi_707)The 'Adobe Captivate 6' folder that Anjaneai directed you to IS the preferences folder for your Captivate 6 installation. Just rename that whole folder or delete it, and Captivate 6 will recreate it fresh next time it launches.
9. Re: Can't stop recording in Captivate 6/Mac
Rakshi_707 Nov 18, 2012 1:07 PM (in response to RodWard)Thank you both! I threw out the Preferences folder, and now I can stop recording using Cmd-enter.
I still can't edit the keyboard shortcuts in Preferences, but at the moment that doesn't matter.
10. Re: Can't stop recording in Captivate 6/Mac
Zeemacz070 Jan 16, 2013 5:34 AM (in response to RodWard)I have the same problem using the same system(Captivate 6, Mac OS 10.6.8). Deleting the Preferences folder has not fixed the problem. Any other suggestions? A re-install?
11. Re: Can't stop recording in Captivate 6/Mac
m.pierce Jan 23, 2013 5:15 PM (in response to Zeemacz070)(Captivate 6, Mac OS X 10.7.5) I have tried deleting the Preferences folder, uninstalling and re-installing, and nothing worked. Finally, I figured it out.
When beginning to record, I had seen a small message pop up about preferences, but I thought it was talking about a setting in Captivate. Finally figured out it was talking about a setting on my Mac.
Go to System Preferences, then into Universal Access, and click Enable Access for Assistive Devices.
Now I am able to stop recording. Cmd+enter still doesn't work, but I am able to click on the Captivate icon in my dock to end a recording.
12. Re: Can't stop recording in Captivate 6/Mac
Zeemacz070 Jan 25, 2013 12:09 PM (in response to m.pierce)Strange, amazing, but it fixed my problem. Many thanks.
Quoting "m.pierce" <forums_noreply@adobe.com>:
m.pierce http://forums.adobe.com/people/m.pierce created the discussion
"Re: Can't stop recording in Captivate 6/Mac"
To view the discussion, visit:
13. Re: Can't stop recording in Captivate 6/Mac
Websmiths Feb 4, 2014 3:31 PM (in response to Rakshi_707)I'm running Captivate 7 in Mavericks (after the patch finally came through).
I also can't end recordings. I've tried changing the shortcuts, deleting preferences and other suggestions here (dock icon etc. etc.). Nothing works. I have to crash the program which leaves me with nothing.
Also, when trying to record it tells me to set a System Preference which I can't find in the Preferences Panel under Accessibility.
I assume that the Mavericks patch is only enough to get the program running and that this is another issue that hasn't been addressed.
Once again, disappointed that Captivate can't seem to to basic things that I require.
Any help most appreciated.
Cheers,
Julian -
14. Re: Can't stop recording in Captivate 6/Mac
RodWard Feb 4, 2014 5:10 PM (in response to Websmiths)Just a suggestion, but...a lot of people are still unaware that after you install any update patch to Captivate you should always trash your Preferences folder and allow Captivate to create a new fresh one on next launch.
If you didn't do that (and you make no mention of it) then I'd suggest you do so, and maybe even clean out your Project Cache as well (button in the Preferences > General section).
Instructions for deleting the Preferences folder for MAC users are found earlier in this thread.
15. Re: Can't stop recording in Captivate 6/Mac
Websmiths Feb 4, 2014 6:23 PM (in response to RodWard)Hiya,
Thanks very much for the response. Actually that's what I meant by 'deleting preferences'. However wasn't aware of the Project Cache thing, so will try that too.
Cheers,
J -
16. Re: Can't stop recording in Captivate 6/Mac
Mary_McGivern Jun 5, 2014 10:09 AM (in response to Websmiths)I just had this same issue and was able to end it by clicking on the captivate icon in the status bar at the top of the screen.
