0 Replies Latest reply on Nov 15, 2012 7:07 AM by jptoney7852
    Exporting H.264 problems
    jptoney7852 Level 1
      I have a client who needs h.264 video with mpeg4 as the container.  I have put my video settings and what the client provided below for review.  I need to match their requirements exactly.  Thanks
      This is what I export:
      General
      Complete name                  :
      Format                         : MPEG-4
      Format profile                 : Base Media / Version 2
      Codec ID                       : mp42
      File size                      : 4.02 MiB
      Duration                       : 29s 997ms
      Overall bit rate mode          : Variable
      Overall bit rate               : 1 124 Kbps
      Encoded date                   : UTC 2012-11-13 21:48:55
      Tagged date                    : UTC 2012-11-13 21:48:55
      ©TIM                           : 00:00:00:00
      ©TSC                           : 30000
      ©TSZ                           : 1001
      Video
      Format                         : AVC
      Format/Info                    : Advanced Video Codec
      Format profile                 : Main@L5.0
      Format settings, CABAC         : Yes
      Format settings, ReFrames      : 3 frames
      Codec ID                       : avc1
      Codec ID/Info                  : Advanced Video Coding
      Bit rate                       : 993 Kbps
      Width                          : 1 280 pixels
      Height                         : 720 pixels
      Display aspect ratio           : 16:9
      Frame rate mode                : Constant
      Frame rate                     : 29.970 fps
      Standard                       : NTSC
      Color space                    : YUV
      Chroma subsampling             : 4:2:0
      Bit depth                      : 8 bits
      Scan type                      : Progressive
      Bits/(Pixel*Frame)             : 0.036
      Stream size                    : 3.55 MiB (88%)
      This is what I need it to be:
      General
      Complete name                  :
      Format                         : MPEG-4
      Codec ID                       : mp42
      File size                      : 7.46 MiB
      Duration                       : 15s 115ms
      Overall bit rate               : 4 142 Kbps
      Video
      Format                         : MPEG-4 Visual
      Format profile                 : Simple@L3
      Format settings, BVOP          : No
      Format settings, QPel          : No
      Format settings, GMC           : No warppoints
      Format settings, Matrix        : Default (H.263)
      Codec ID                       : 20
      Bit rate mode                  : Variable
      Bit rate                       : 4 008 Kbps
      Maximum bit rate               : 5 785 Kbps
      Height                         : 720 pixels
      Color space                    : YUV
      Bit depth                      : 8 bits
      Compression mode               : Lossy
      Bits/(Pixel*Frame)             : 0.145
      Stream size                    : 7.22 MiB (97%)
